Question about Nixon 5130 Chrono Watch Black Watch for Men
My second hand stopped working it was ticking and staying still in one spot, everything else was working fine, then a day later everything stopped working, please advise, thanks :)
Why does my seiko sne039 only work in direct light and the second hand advances 2 seconds with each movement
Its ticking in two second intervals because it is very low on power. It should keep correct time and eventually settle down. It needs a long exposure to a nice bright sunny day and it will be fine once it has a good charge for definate.
Jan 15, 2013 | Seiko Watches
I have a sport watch fossil CH2470. the second hand is not moving, stuck on 12, but everything else works. how do i fix this?
Your watch is Chronograph watch and the big centre seconds hand is for chronograph function only - not day to day seconds counting. Check the small dials and you will see that the small seconds hand is already counting seconds- this small one is seconds counter. To engage chrono hand push the upper push button once. To stop it - push the same button again. to return to zero- push lower button. For users manual use this link: http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html Rate me, please.
Feb 28, 2011 | Fossil Watches
I replaced the battery in my watch. About a week later, it started getting slow. I watched it and noticed that it would tick for 2 seconds then stop for a second, tick for 2 seconds then stop for a second,...
It sounds like one of the hands is pausing as it brushes against something. It sounds like a treasured watch. I would take it to a professional watch repair shop. Mine was losing a minute or two per hour from the hand being slightly bent. Good luck!
Sep 03, 2017 | Timex Indiglo Analog Watch
In reading the movado 800 quartz chronographic instruction manuel there are 3 settings for the crown. the first is the one in which you generally wear it. the second position states it will stop the watch...
The time should only stop when the crown is pulled all the way out in the third positiion... In the second position the 2nd hang should continue to tick and you should only be able to move the hour hand on the watch
Aug 22, 2010 | Movado 800 Performance watch
Second hand stops, then ticks four ticks very fast then stops,
It may be that the battery is getting near the end of its life.
May 05, 2010 | Tag Heuer WAH1112.BT0714 Formula 1 watch
I reset the date and now the second hand ticks at
This is END OF BATTERY LIFE warning. Replace the battery and everything will be fine. Rate me plz.
Mar 04, 2010 | Tag Heuer Watches
Hands unable to move. battery is fine though.
Hands are probably misaligned slightly. They will require adjusting.
Jul 11, 2009 | Watches
Seconds hand starts ticking then stops
Your band may be too loose. This is the model that moves when worn correct?
May 12, 2009 | Tag Heuer Automatic Chronograph Series...
Techno Marine MO4 Watch, Seconds hand doesn't reset to top cente
You do not need to return the watch. It has self adjusting features (operated by the owner). Pull out crown to the first click, then push and hold the pushbutton at 2 o'clock to adjust the hand. When done - push crown back in.
If it doesn't work, pull out crown to the second click and do as described above.
Rate me, please.
Mar 22, 2009 | TechnoMarine Ceramique Watch TCB02C
Watch stopped after not being used for several days
The shaking is not the best way to restart the automatic watch as it puts slight strain on watch balance wheel and hairspring (most delicate part in watch).
As watch balance wheel is positioned paralel(leveled) to watch dial, you have to spin your watch back and forth a few times quite quickly.
(Imagine you are turning steering wheel in your car- thats the right motion). Before doing that wind up your watch a few times manually.
Right after doing that observe the seconds hand and if it is ticking just a little bit or ticking back and forth and then stops- your watch has jammed gear train and this is the reason why it stops.
If you don't have seconds hand- after shaking your watch listen for ticking and again- if it stops after short run, the gear train is to blame. In this case you will need watchmakers help as special skills and tools are needed to sort this out.
Do not forget to rate, please.
Jan 10, 2009 | Rado Diastar Anatom Jubile watch
Nixon 5130 Chrono Watch  Black Watch for Men Logo
263 people viewed this question
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
