Question about Freezers
Proline chest freezer - the alarm light has come on. What does this mean and what needs to be done to get things back to normal. Thanks
    Scholar:
  • 116 Answers
Hi this normally means the temperature got too high, could have a cooling problem or somebody had the door open too long.
Sean
Posted on Mar 26, 2011
  • Matthew Cross Jul 28, 2011
    Some of these freezers are manual defrost so owner neglect would cause "cooling problems"
    Look for a manual defrost switch in the unit somewhere.
    good as new
Alarm light Westpoint Chest Freezer
is it getting cold inside .why would you want MAX temp tho turn to mid point as a startingplace
Nov 22, 2015 | Freezers
What does the red warning light by the triangle mean on a blomberg
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
May 28, 2014 | Zanussi 10.31 cu. ft. / 292 liter Chest...
There are 3 lights on the front of the Zanussi Freezone. The green one on the left doesn't light up. What does that indicate? The red light on the right is on constantly. Does this mean that the freezer is...
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
Dado
Oct 14, 2013 | Zanussi 14.62 cu. ft. / 414 liter Chest...
I need an online manual for proline freezer CF6 37P see drection for temperture control
there a alarme light showing on my chest frezzer what dose it mean
Aug 02, 2011 | General Freezers
Electricity went out & audible alarm is going off. Would like to know if there is a reset button for this or will it reset itself when temp goes back to normal.
Will stop on it's own when it get cold again, but most generally have a manual alarm shut off (on back, near hinge on older models).
Apr 28, 2011 | GE 14.8 cu. ft. General Electric Chest...
RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, wgheaven@yahoo.com.au Russ
Mar 28, 2011 | Whirlpool Freezers
I just moved into a home with a kenmore chest freezer. This is a real dumb question, but which symbol means on. Should the circle be showing for "on" or should the line be showing for "on"?
Some freezer models feature a temperature
monitor that provides an audible
alarm. The temperature monitor alarm is
located near the temperature control
The alarm sounds if the temperature in
the freezer rises 10° F (12° C) or more
above normal for selected setting. Alarm
may sound if temperature control dial is
turned to a much colder setting or if a
large amount of unfrozen food is added at
one time. Alarm is controlled by a three
position switch
0 = OFF prevents alarm from sounding
when freezer is warm, such as during
initial start-up or defrosting.
• ✓ = TEST sounds alarm regardless of
temperature. Alarm system should be
tested at least once a month.
1 = ON is proper setting for normal
freezer use. Return switch to 1 after
defrosting.
Jul 07, 2009 | Kenmore Freezers
I have a GE chest freezer and the exterior green light has started flashing. The freezer is less than a year old.
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
Jul 07, 2009 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezers Logo
1,057 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
