Question about RCA D52W19 52" Rear Projection Television
Replacement Lamp I need a replacement lamp for my tv. I have tried everywhere to find one. If anyone knows where to buy this I would greatly appreciate it. Thanks, K.T.
  • RCA Master
  • 8,617 Answers
If your model is the D52W19 you dont have a lamp you have three CRTs ( picture tubes) instead. What is the symptom? I have a good source for RCA parts. Please respond to this same post and if D52W19 isnt your correct model number please post that as well and I will assist you with your set.
Posted on Aug 04, 2008
Lamp unit Type: Y67-LMB The Lamp Burnt
If You are look to buy one Try TV Repair Kits.Com
Aug 19, 2011 | Toshiba 50HM66 52" Television
I just replaced the lamp on my Samsung HLS5087 and now the TV won't power up. The 3 LEDs are lighting which indicates that the lamp needs to be replaced. I put the old lamp back in to make sure there is...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem,,,,
Dec 06, 2010 | Televison & Video
Tv stays on for a few minutes and then goes off;after 30 seconds,blue light flashes,and tv goes on again;
If it is Sony Grand WEGA KDF-55XS955 tv then it needs lamp replacement as existing lamp in tv has reached at end of its working hours life and causing this problem.
If lamp in tv has not been replaced in last 2-3 years then it is time to replace it. Lamp replacement procedure is easy and written in user manual.
Required lamp part number for tv is as follows:
A1085447A .... LAMP BLOCK ASSY XL2200U
Available in Sony Accessories Store for $200
Please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Nov 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a sony Vega 55" kdf-e55a20, It is 3 years old, and now the picture and sound fade away for 10-15 sec every hour or so and comes back! Anyone knows what the problem is?
Lamp is getting weak and TV shuts off and turns on itself because of weak lamp in TV that you see picture and sound fades away for some time until TV reboots.
Replace lamp in TV to solve this issue. Lamp replacement procedure is written in user manual and its an easy work.
Please buy Sony original lamp for your Tv safety.
Dec 23, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
I heard a pop and screen wet black. red lamp
Lamp inside TV is broken and requires replacement. Pop sound was its breaking sound.
Lamp replacement procedure is written in user manual, pretty easy.
Please buy Sony original lamp for TV safety and avoid aftermarket/ cheap lamp.
Let me know if you need to download user manual copy.
Sep 12, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have 42in Kdf42e2000 and it keeps cycling on and off. it stays on for 45 sec and the shuts off power light blinks for 42 times then it goes back on and the cycle starts again. Does anyone know what could...
Its symptom of weak lamp in TV, please replace lamp.
Lamp replacement procedure is easy and mentioned in instruction manual, if you need copy of manual, click Sony Support.
You can buy replacement lamp from Sony Accessories Store under following part number..
F93087500 Lamp Block Assy XL-2400
Jul 09, 2009 | Sony KDF42E2000 42" HDTV
Sony KDF-50E2000 50" Lamp replacement have 10hrs can find them everywhere try eBay
3. It is easy except one thing you must have the original remote to reset the lamp counter
May 16, 2017 | Sony KDF-50E2000 50" HDTV
Realistic Lamp Cost ??
139.00 seems reasonable for a replacement lamp. is that the only problem that you are having or are you hearing a squealing sound and then the tv cycles off?
Aug 29, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Lamp Replacement on Sony Wega TV
Please explain the location of the lamp for a sony kf-50we610 50 inch tv. Note same problem as above.
Apr 07, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Replacement lamp/bulb sony kp-61hs10
that model number doesn't use lamps it uses cathode ray tubes projection tubes. the CRTs for that tv are probably no longer available.
Feb 22, 2008 | Sony KP-61HS10 61" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
190 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
