Question about Vivitar ViviCam 8018 Digital Camera
It wont turn on with brans new batteries - Vivitar ViviCam 8018 Digital Camera
    Scholar:
  • 118 Answers
New cameras and devices in general, usually have small plastic or tape on the batteries that you must remove before the first use.
also, sometimes the batteries do not come pre-charged, and require a long charge time before the first use. check with the manual or store, if you are unsure.
try turning it on while plugged in and charging..
this camera is considered very bad with users who have posted online about it. it is notorious as being cheap and breaking easily, you may simply have to return it.
Posted on Mar 26, 2011
Battery is charged but wont run
Check that the wires for the motors on the rear tires are connected. If they are connected check with a multimeter and make sure that they are showing 12-13.8 volts
Apr 26, 2015 | Polaris Ranger RZR Ride on Toy
My vivitar T028 camera wont turn on
i also have a Vivitar ViviCam t028 and i just changed the batteries and it wont turn on i was just about to empty the memory card but it wont turn on so i can't i don't know what's wrong with it.
Dec 25, 2012 | Vivitar ViviCam X327 Digital Camera
2003 yukon xl turns over fine wont start.
Someone will need to figure out if you are lacking fuel to the injectors or spark to the plugs to proceed.
You say the pump is fine, have you checked the fuel pressure, and do you know if the injectors are getting voltage and ground pulse from the computer ?
Dec 11, 2012 | 2003 GMC Yukon XL
Nikon d3100 bran new battery wont finish charging !!
You have one of a few problems. Either your new battery is defective, which does occasionally happen, or there is a problem with your battery charger. The other possibility is that your camera has a problem; possibly a short circuit that is draining the battery. If you have a spare battery and it will take a charge, your new battery is probably bad.
May 17, 2012 | Nikon D3100 Digital Camera with 1855mm...
Bran knew bat. starter was checked,ok wont even turn over ,just clicks
Make sure the connections to the battery are shiny and clean.
Aug 27, 2010 | 1995 Dodge Dakota
Mustang wont start check engine line shows up but wont turn over battery is bran new starts for 2 mins then stals then wont turn over no more think its ecm but its starts somtimes
Try this website to download a free manual
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
May 01, 2010 | 1994 Ford Mustang
I have a bran-new alternator. But my car still
CHECK ALTERNATOR FUSE + FUSE LINK TO MAIN BATTERY FEED WIRE.MAKE SURE YOUR BATTERY CABLES IN GOOD SHAPE.IF THEY ARE OLD REPLACE THEM.BECAUSE THEY WILL CAUSE HIGH RESISTANCE IN CIRCUIT CAUSE CHARGING PROBLEMS. AND CHECK ALTERNATOR POSITIVE WIRE AND VOLTAGE REGULATOR WIRE.MAKE SURE DRIVE BELT NO SLIPPING.ALSO MAKE SURE YOUR BATTERY IS 12.5 VOLTS.IF BATTERY IS WEAK ALTERNATOR WILL NOT BE ABLE TO CHARGE IT.IT WOULD BE LIKE A BUCKET WITH LARGE HOLE IN IT.KEEP FILLING IT WITH WATER IT WILL LEAK OUT.IT WONT HOLD NONE.
Jan 30, 2010 | 1990 Toyota Corolla
Vivitar ViviCam 8018 Digital Camera Logo
54 people viewed this question
Top Vivitar Cameras Experts
SHARCNET-USA
SHARCNET-USA
James Woodgreaves
James Woodgreaves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
