What to do to get images from my computer to a XGA projector. (I have a DVD with video on it and a projector hooked up but I need to know what to "click" or whatever to get my computer in the mode to send the video to the projector.) I have a Toshiba computer with XP as the OS.
    Genius:
  • 1,447 Answers
Hi-
Check the ports from the back of your projector, look for an s-video port then check the available ports as well on your computer, so you either use an S-video cable or VGA cable, then when you connect your computer, if its a laptop press fn key then double tap f5 or f7.
keep me posted
Posted on Aug 04, 2008
Sharp Notevision PG-C30XE problem with computer display
There are 3 different types of analog video signal ports on your projector; s-video, composite video, and RGB. Which one of the three are you using to connect your PC to?
The projector's resolution rate is XGA [1024 x 768]
If you are using a VGA cable designed and capable of handling 640 x 480 resolution; then it will not support XGAs 1024 x 768 signal. On the other hand, if the coaxial cable you are using is a multi band one that is capable of supporting VGA and XGA resolution signals, most likely the problem is not with the cable- although I have come across brand new cables that are defective.
Please let me know if this helps or else we'll try another approach :)
Nov 25, 2013 | Sharp Notevision PG-C30XE Multimedia...
Infocus lp425z projector pushes latop display to left quarter of output image
Usually this is a hardware acceleration setting problem on the 'advanced' properties setting in your 'screen resolution' properties on your computer. Re-set the hardware acceleration to the 2nd setting and this should fix your issue. We have this regularly when we project on a double projector system and the one projector keeps shifting everything left until we adjust the hardware acceleration settings on the computer. No more issue.
Mar 11, 2013 | InFocus SOFTCASE, LP425Z Multimedia...
Proper PC Adjustment Parameters?
Hello,Instead of replicating your laptops desktop can you please try extending the desktop. This way your laptop can keep its native resolution and so can the projector. Let me know how it goes.
Nov 17, 2011 | Sanyo Office Equipment & Supplies
Computer image does not cone out through the projector. the image goes blank immediate i connect it to the computer
try doing a Reset All on the projector, which should be located within the User menu. i'd also check the VGA cable connectors on each ends, make sure there are no bent pins
May 21, 2011 | InFocus LP530V Video Projector 2000 ANSI...
I just bought a top-end MacBook Air 13.3" 4 GB/256 GB for presentations. I also have a Dell M410HD projector, also quite new (a few months old), which works great with the two PCs (one new, one old)...
They (Apple) might be right. It could be that the projector is damaged, like the bulb, or it could be incompatible with your computer, but I don't think that is the case. Try taking the projector to a computer repair place.
May 17, 2011 | Apple MacBook Pro Notebook
In focus x3 projects computer start up screen, then just searches
the resolution may have changed. reselect the computer or auto-image.
Jan 20, 2009 | InFocus LP640 Projector Multimedia...
Infocus 120
swap the cables, toggle the f4 on the computer, and reset the settings to factory default to make sure the resolution matches.
Jan 09, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Projector Image Problem
Hi There
Your Projector switches to a 16:9 ratio when hooked up to a Video signal and to a 4:3 Ration when hooked up to a PC signal.
You can manually change this in the Menu functions if this bothers you.
Simply go to Aspect Ratio in your Menu's subfolders and press left or right once you scrolled down to it.
Sep 21, 2007 | BenQ MP610 Multimedia Projector
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
