Question about Yamaha Boating
How do i remove the starter from a 2001 25 hp yamaha outboard motor?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Yamaha Master
  • 1,190 Answers
Disconnect battery , remove red and black wires on starterthen remove the top 2 bolts on starter and 1 or 2 bolts at bottom , pending which model but it should come off now !
Posted on Jun 10, 2014
3 Suggested Answers
  • 7 Answers
SOURCE: The starter will not engage to the flywheel on a
Try spraying some CRC Light lubricant on the spiral where the pinion gear slides up and down. Can you turn the gear so it will move up to the flywheel? If it turns and stays at the bottom, you will need a new pinion gear! Does the starter motor spin?
Posted on Sep 07, 2010
SOURCE: I have a 2008 25
I have one of these tilters and it's on a 2009 25Merc. I had to modify it because the pull handle is located lower on the back of motor.
Posted on Jul 07, 2011
Hi, can you tell me the year model of my Yamaha 40hp outboard? Serial number 452214.
Search Results
Yamaha Outboard Serial Number Location and Model Identification ...
https://www.perfprotech.com/.../yamaha-outboards/yamaha-outboard-serial-number-l... The Yamaha Outboard Motor MODEL, PRE-FIX and SERIAL NUMBER are stamped on a plate attached to the transom clamp bracket. When ordering parts and/or accessories from our Yamaha OEM Online Parts Catalog it's important to properly identify the exact model you are dealing with.
Yamaha Year Models - Hunts Marine
https://www.huntsmarine.com.au/pages/yamaha-year-models This Yamaha outboard year model chart will only work for Asia Pacific distributed engines. If you have a Yamaha engine that has been bought in from America or E. ... For Asia Pacific engines your year model code is found on the bottom right hand corner of your serial number decal. It will be a single letter as per the ...
Decoding Yamaha Outboard Motor Model Number and Manufacture ...
www.murrayyachtsales.com/decoding-yamaha-outboard-motor-model-number-and-... Dec 30, 2015 - Decoding Yamaha Outboard Motor Model Number and Manufacture Date (MFG Date)
Yamaha Outboard Serial Number Lookup
uvgb.you4k.top/ By Darnell Zacharias. DOWNLOAD Yamaha 60HP (60 HP) Repair Manual 1984-2009 Outboards 8.8. By Michael Hornby. HOT. How To Decode A Suzuki Outboard Serial Number 8.4. By Ralap James. Mako 261 Center Console Boat For Sale at Unreserved Auction (Inv.3368) 7.1. By Aldrich Child. yamaha 40hp 2 stroke ...
Outboard Spares YAMAHA Model Year IDENTIFICATION CODES ' eBay
www.ebay.com/gds/Outboard-Spares-YAMAHA-Model-Year...CODES-/.../g.html Outboard Spares Yamaha Outboard Model Year Identification Details needed for ordering outboard spares parts On the Serial Number Plate on most Yamaha Outboards it will be in this format 6E9-L-675634 The...
Jan 15, 2018 | Yamaha Boating
Hello I have a 2004yamaha f15ELHC outboard motor GOOD BATTERY IN NEUTRAL PUSH STAT BUTTON and nothing no clicking
Likely a connection issue. Remove, CLEAN and replace all connections. Tighten properly. Could also be a bad starter relay.
Aug 26, 2017 | Clymer Marine Maintenance and Repair...
40 HP 2 cycle outboard. Tilt works, but engine does not turn over. Yamaha outboard should mention.
So either the battery needs charging, the starter button / key are faulty, or the starter/solenoid is faulty. You need a test meter.
Dec 30, 2016 | Boating
Yamaha 40 hp outboard
Look below lower mountings you will see the shift rod with along nut and a lock nut,undo long nut,do this with motor in reverse gear,some 40s have a stainless plate cover which you have to remove first
Aug 18, 2014 | Clymer Marine Maintenance and Repair...
My 86 yamaha outboard will not turn over
Bypass solenoid,put jumper from pos on batt to starter motor,but could be so many things,faulty battery cables,broken wire in loom,worn starter brushes,faulty solenoid ,start in gear switch or ignition switch
Feb 02, 2014 | Clymer Marine Maintenance and Repair...
Problem with yamaha 50 hp
Check the oil level to see if it's over filled... Use Google for other options.
May 11, 2013 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
50 hp yamaha outboard mid 1990's
2 stroke ?? choking up do you mean ? what oil make and mixture ratio ?
Yamaha 4HP outboard - cannot pull starter cord - jammed.
Engine or gearcase seized...
Remove the recoil starter ( 3 bolts and the startingear link)
If you can turn the flywheel slightly: Gearcase seized
If you can't turn the flywheel at all: Engine seized.
In both cases: If you can't disassemble and have the job done yourself, forget that motor...
Dec 09, 2012 | Clymer Marine Maintenance and Repair...
Starter motor on 130hp Johnson outboard won't
does it turn or can you hear a click as you try ? if its not turning check the starter brushes and if it clicks then replace solinoide !
Apr 04, 2012 | Yamaha Boating
Boating Logo
129 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
