I need a wiring diagram for a MARS 10469 Hp 1/3 max V208-230 air conditioning moter.
  • 37 Answers
SOURCE: no air condition
go to honeywell.com and get tech support number
Posted on Apr 25, 2009
SOURCE: wiring diagram for portable air conditioner
I think the wiring diagram is on a printed sticker on the side of the water collector, just pull it out of the right side as you look at it. There should be one on there hope this helps as i have the same unit in the other room. regards Richard
Posted on May 29, 2009
shastalaker7
  • 1515 Answers
SOURCE: I have lot wiring diagram for Panasonic window air
Hi, you would have to tell me the colors of the wires that are off and where they come from. How many capacitors also.
Shastalaker7
Posted on Dec 04, 2009
  • 1262 Answers
SOURCE: schematic diagram of central air conditioning
Several types out there. 99% of them use the same basic wiring.
Red is power from transformer to t'stat. Sometime there is a wire for common from transformer to t'stat too, but not always.
While is for heat. Green is for fan. Yellow is for cooling.
These 4 to 5 wires go on the terminals that are maked with letters: C=common, RH/RC is for power, W=heat, Y=cooling, G=fan.
In most cases, 2 wires from the indoor unit will go to the outdoor unit to power it for cooling. Usually connected to the yellow wired, Y terminal and common or grounded to the unit if the transformer is done in the same fashion.
If you have a heat pump, totally different animal and different wiring too.
Hope this helps you. Good Luck.
Posted on Dec 20, 2009
  • 82 Answers
SOURCE: i need a wiring diagram for a tempstar gas pack
Go here - http://www.gotempstar.com/go/index.asp?t=86&s=477
enter PGAA in model box.
Posted on Mar 14, 2010
Do you give advise on Home HVAC air handlers Blower Motor wiring or just on Vehicle wiring?
Can you take a picture of the wiring diagram on the moter and post it here?
Sep 17, 2014 | Heating & Cooling
2001 suburban air condition wiring diagram
I would change the pressure switch and it just turns in and out and it won't loose R134a. The one switch should be on the dryer bottle with two wires plug.
May 22, 2017 | Cars & Trucks
1995 pontiac bonneville 3.8L temp gauge maxed, engine norm temp
Possible bad sending unit or shorted sending unit wiring.
Jun 07, 2013 | 1995 Pontiac Bonneville
A/c unit wireing digrahm
how many wires does the fan motor have and what colors? also, i assume there is no diagram on the motor itself? are you using a dual capacitor or a separate one for the compressor and one for the fan?
Jun 06, 2013 | Heating & Cooling
Mars blower motor diagram?4 wires
Gentlemen,
I have a GE P547BS fan motor. I find replace it with a Mars 10584 fan motor. GE has five wires, BRN, YEL,PUR,BLK,RED. Goes through the capacitor with the yellow going on to 200 V the purple and black go to 220 V. Mars motor as a six wire connection two Brown's go to the capacitor. yellow I'm assuming goes to the hot/neutral and a black I would say would be high-speed blue is medium and red is low. Now when I connect with this way it blows the fuse. Anybody run into this problem before? Any help? By the way, it's a 240 V single phase system.
Jun 05, 2012 | Heating & Cooling
Mars motor has no white (common) wire??
You are looking for the nuetral wire,look on the mars motor it should have a wiring diagram stamped on it to answer your question
Jul 20, 2010 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
461 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
