Question about Whirlpool Dishwashers
Whirpool dishwasher DU909PWKQ0 dark food type stuff on inside of machine and all over dishes when cycles are done what is wrong?
jsrock516
  • 5911 Answers
SOURCE: black stuff in the bottom of the dishwasher
That black or gray stuff you're talking about is actually a combination of old food particles and soap deposits. The stuff builds up in the corners of the lower front areas of the tub and right under the inside of the door where it closes over the tub front. These areas can develop "scungy" deposits because these are areas that the dishwasher doesn't always clean and/or water remains pooled. A little routine cleaning about once a week around the bottom lip of the door and the door gasket with a damp sponge will prevent this build up. Hope this helps you.
Posted on May 12, 2007
SOURCE: Food Deposits left on dishes
I had an old machine with a similiar problem & I found that food had somehow entered into the arm that spins & sprays out water. The food blocked somewhat the holes which of course means less cleaning.
Posted on Mar 05, 2008
captaynkyrk
  • 170 Answers
SOURCE: KITCHENAID DISHWASHER NOT CLEANING PROPERLY;
there's a filter at the bottom of the inside of the washer. remove the rack and spray arm and you can get to the filter and clean it out. once cleaned you will notice a difference after each cycle.
Posted on Jul 07, 2008
plnolte
  • 62 Answers
SOURCE: Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
Posted on May 12, 2009
dnewcombe1
  • 1564 Answers
SOURCE: I think my Bosch dishwasher might be a "lemon". I
Don't be afraid now, but , what I'n going to tell you works VERY often. Pour two cups of bleach into the washer and let it run a potscrubber cycle. They do this all the time at restaraunts, yes really! Let me know how this turns out. P.S. leave the machine empty when you run it. Thanks, Dana
Posted on Aug 22, 2009
I accidentally put Mr. Clean in my dishwasher instead of Jet Dry. So far no problems. The dishes even look cleaner. I'm just wondering if it's hurting us by eating off the dishes, or if it's hurtin
It depends on the food that's on the plates. Deep fried, fatty stuff is bad for you.
As long as the plates and the machine has rinsed with clean water (run a cycle with no soap) all will be well, well, except for your arteries if you keep wolfing down greasy stuff.
Oct 14, 2014 | Kenmore Dishwashers
Whirlpool adp252 not rinsing clean
Hello
Clean the internal parts of the dishwasher. Use a clean wet cloth and wipe down the inside including the racks and the sprayer arms. Remove the upper arm by unscrewing the center bolt. Clean both sides before replacing.
Check the water pressure. The dishwasher requires inlet water pressure between 20 to 120 psi. If the water pressure in the line is too low, proper rinsing will not occur.
Check the water temperature. The dishwasher performs at optimal levels with 120 degree water. Check the hot water heater for needed adjustment.
Use the right detergent. The dishwasher requires detergent designed specifically for dishwashers. Other detergents will leave spots, residue or food on dishes.
Set the machine to the proper cycle. The dishwasher offers a variety of cleaning cycles. Select the appropriate cycle for the type of cleaning required.
Load the dishwasher properly. An overloaded machine will result in dishes not being cleaned thoroughly.
Sep 12, 2011 | Dishwashers
My dishwasher is a frigidaire FDB345LFS2. when we run it, it leaves gritty food patical residue on everything. It is inside cups, in bowls and on the surface of stuff. I have tried every type of...
You have to do a thorough cleaning. You have built up food and maybe some sort of non-food object that cannot be degraded by the disposal and flushed out (mine was a cheese wrapper).
This is going to take about an hour, but you are going to be disgusted and amazed when you see all the stuff that is built up inside. If you are a do-it-yourselfer and have a bit of mechanical inclination, this shouldn't be a problem for you. FYI I'm a 35 year old woman with no appliance experience. But, I do know how to get things CLEAN!
1. Unplug the dishwasher
2. Pull everything out, Dishes, baskets, etc...
2. You will need a hex key to take out the bolts. Most of the various hoses are clipped in. Pull those out gently. Take care to lay things out methodically so you will remember how to put it back together.
Your goal is to get to the disposal under the water blade. My blade is held in by a plastic knob-type screw on top. It's a little tricky to get off. Then, under that will be a couple more hex bolts to unscrew to get to the disposal and drainage of the machine.
Once you get there, you will find all the food and debris that has built up. I've found everything from nutshells to plastic wrappers. If you have a wet-vac, start there and vacumn all the stuff out. Then just use elbow grease and a cleanig solution to clean out all the gunk. While you're in there, spray the insides of the dishwasher and wipe clean.
Put it back together and plug it in. Be disgusted that you were "washing" your dishes in that sludge, but pat yourself on the back for fixing your own problem! :)
Feb 05, 2011 | Dishwashers
Dishwasher says dishes are clean but is still stuck in cycle. tried resetting the breaker but no luck. the green light that goes on when clean is constantly flashing but dishwasher is non-responsive. any...
Some dishwashers have some sort of float switch. They can stick , try rocking dish washer if stuck mid cycle, I would make sure the food collect grid at bottom is clear, try flushing machine through with an empty load now and then, you can buy stuff for cleaning dishwasher insides too.
pete
Nov 08, 2010 | Kenmore Dishwashers
My dishwasher is not cleaning the dishes.when the dishwasher is done there is still stuff on my dishes. if you cancel the cycle the water in the dishwasher is cold
If the machine used to work fine then I'd suggest running the hot water in your sink before starting a cycle to ensure the water entering your dishwaher is hot. If you then are getting hot water and still dirty dishes try reposting for a a solution. When re-posting, include your make and model for a better answer.
Feb 02, 2010 | Dishwashers
Aug 22, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Whirpool dishwasher
Ours does the same thing. I have been suspicious that it is the melting plastic stuff used in the dishwasher tabs that the wife uses.
Let me know if you use that same tab to wash you dishes.
We dont have any problem with the stuff getting on dishes (and we use all white diner type dishes.).
Jan 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Dishwasher is leaving food particles everywhere
Dishwashers need cleaning too :) Take a look inside your dishwasher: Click here http://www.appliancepartspros.com/partsearch/model.aspx?model_id=41284 then click on PUMP AND MOTOR diagram on the left. Number 47 on that diagram is a filter. Make sure that filter is clean. Then, using a dishwasher cleaner (see below) run your dishwasher through the entire cycle on empty. This should help, post back if it doesn't. Dishwasher cleaners: 1. Vinegar - good cheap solution, if you don't mind the smell :). Dump a gallon inside an empty dishwasher tub and start up the regular wash cycle. 2. CLR - I've been told it works, but never tried myself 3. Dishwasher Magic - This stuff works pretty good. One bottle per use. http://www.appliancepartspros.com/accessories.aspx?part_id=2675393&cat=62&rdr=%2faccessories.aspx%3fcat%3d62 Hope this helps, APP tech http://www.AppliancePartsPros.com
Aug 03, 2006 | Admiral 24 in. DWUA800AA Built-in...
Dishwashers Logo
55 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
