Question about Samsung LN55C650 TV
My 2010 Samsung LN55C650 started to have an issue with it flickering. It's not the picture but more like a black and white shading. It gets lighter then darker then lighter and so on. It started about two days. If we close the tv for awhile then put it back on it stopped but after a few hours it would start again. Let me know what could be done with it. Thank you.
  • 192 Answers
SOURCE: Flickering dots
The symptom you described is called diffusion. A simple alignment, normally in the power supply takes care of this problem. For the nearest Authorized Service Center near you contact Toshiba online at: http://webmail.tacp.com/service/servcntr.nsf/$$Search?OpenForm Hope this helps
Posted on Jun 03, 2007
SOURCE: Samsung LN-T3253H LCD Sound Problems
PEOPLE, YOU NEED TO GO BACK TO THE STORE, BUY THE SAME TV AGAIN, SWAP THE TV'S AT HOME AND RETURN THE "OLD" TV IN THE "NEW" BOX WITH THE NEW RECEIPT. IN THE CASE OF TOO MANY RETURNS, HAVE A FRIEND, MOM, DAD, SISTER, GIRLFRIEND TO BUY ONE FOR YOU AND DO THE SWAP LATER.
NOTE: I REALLY HATE DOING THIS TO THE STORES, BUT IF YOU PAY FOR SOMETHING IT SHOULD LAST LONGER THAN 30-40 DAYS. PROBLEM SOLVED! :)
Posted on Feb 29, 2008
  • 2336 Answers
SOURCE: Flickering
I would suggest to call Samsung to get the Plasma repair under manufacturers warranty. The flickering will not go away until the hardware failure is corrected.
Good Luck.
Posted on Apr 15, 2008
  • 644 Answers
SOURCE: Samsung LN-T4661F with black shaded area.
The back light is beginning to fail, thats why it goes shaded but you can still the picture on one side, do a google search for back lights for your make and model, there a few how to's to help you with changing the back light.
Posted on Feb 18, 2010
toolkits
  • 1099 Answers
SOURCE: I have no color on my Samsung Flatscreen TV
This means absolutely no color - equivalent to a black and white picture. Not even a hint of color.
First, confirm that the source is actually in color - try another channel or input device.
Next, check the settings of the color control - it may have accidentally been turned down. If your TV has some kind of automatic picture mode, try turning if off and adjusting the color control. Try adjusting fine tuning if you have such a control and the problem is with a broadcast or cable transmission.
At this point with a confirmed color signal source, there is a problem with the chroma circuitry.
Note that to the average person, the obvious question becomes: is my color picture tube bad? The answer is a definitive NO. It is virtually impossible for a defective CRT to cause a total loss of color. A defective CRT can cause a lack of a primary color - R, G, or, B or a short between two colors which will mess up the color but is not likely to result in a black and white picture.
Some possibilities in no particular order:
Weak signal or defect in tuner/IF causing loss of signal strength.
Coler killer set too high (internal control) if it has one.
Defective part around the chroma chip/circuit. Faulty color oscillator.
Bad connections in area of chroma chip/circuit.
Defective chroma chip (don't suspect this first just because it is probably very expensive).
Try prodding the main board around the chroma chip with an insulated tool to see if you can make the color come and go.
I had one set where a $.02 resistor decided to open up causing just this problem - perfect BW picture, no color. Another had a coil with a broken wire.
Posted on Jun 14, 2010
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung LE40R71B flickering problem
appears other people are having the same issue with Samsung TV's.
Try calling Samsung or wherever you bought it from.
I've been dealing with Samsung on this issue.
We got a 40" LCD in October 2010 and it started flickering January 2012.
Changing it from 'standard' to 'movie' helped (natural and dynamic flicker)
Then it started flickering in 'movie.'
I called Samsung and told them this issue is all over the internet. They agreed to pay for repair, parts and labor, even though it's out of warranty.
The guy just left and this is what I know. He said that in the 46" and larger, the issue is a jumper. In the 40" and, I think, smaller, it's the panel. He's ordering the panel and will be back to replace it when it comes in from the warehouse in CA.
Try calling Samsung and good luck!
Dec 28, 2013 | Samsung LE40R71B 40 in. HD-Ready LCD...
Ln55c650 flashe s
The Problem is with the power supply. It needs to be replaced. It is having abiasing problem that causes the backlight to flicker or strobe
Jul 22, 2011 | Samsung LN55C650 TV
Ln55c650 keeps flashing bright to dim very fast after about 30 minutes of being on if i shut it off for a few minutes it goes away til about 30 minutes the picture never goes away just gets bright and dim...
I had the same issue occur on my ln55c650 (screen flickering, not the actual image but the front lights flashed which was too distracting) and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Screen has started to flicker constantly. tv is 9 months old. When switched off flickering stops for about 5-10 minutes and then starts again
I had the same issue occur on my ln55c650 and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Feb 23, 2011 | Samsung LN55C650 TV
BLUE screen problem(monitor)
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but blue shaded screen, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 26, 2010 | SAMTRON 55V 15" CRT Monitor
Feb 17, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Samsung LN55C650 TV Logo
143 people viewed this question
Jerry Greenberg
Jerry Greenberg
