Question about Samsung Washing Machines
Wont spin out sansung front load modle wf218anb/aao1
  • 1 more comment
  • mhull981 Mar 27, 2011
    done did this
    does spin in both direction but slow have not tried empty but will try
    ran empty cycle work fine going to wash aload see what happens
  • Samsung Master
  • 2,605 Answers
Hello, Welcome To FixYa. Have you inspected the coin trap in the drain pump ? This applies to all SAMSUNG since 2008. Though the location varies from left to right hand side below the main door. The washers have a coin trap and manual drain. In the event you forgot to retrieve any small items such as coins prior to washing, the rubber hose inside the coin trap allows you to drain out the water allowing you to remove the trap for cleaning, but also to keep the inside as water-free as possible when not in use. ( which helps reduce odor build-up ). Let me know if this is something you've already attempted and we can go from there. Good luck and thank you for choosing FixYa. Regards, Macmarkus :)
Posted on Mar 27, 2011
  • 1 more comment
  • Mark MacDonald
    Mark MacDonald Mar 27, 2011
    Hello again,
    Thank you for the reply. Since you done did that, obviously it didn't work...but you didn't say ?( correct me if I'm wrong or misundetstood ). Does the unit go into a spin when empty, i.e. Drain and then spin without clothing in it ? How about the action during wash/agitation, does the drum turn in both directions ?
    Again let me know and we can move forward...it can be tedious from afar, so please be patient if you already know the answers to these questions.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Sounds good,
    I will await your reply/results.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Before you run a load, I would suggest running that load without the addition of detergent to see what happens. This will rule out the detergent being a factor if it doesn't spin.
    Regards,
    Macmarkus :)
Samsung vrt front load washer WF218ANB/XA Burned up the drain pump. Installed a new one, now washer will work until the spin cycle. In spin cycle the door lock clicks and it will not drain or spin
Make sure the drain filter is not clogged. Most Samsung have an access door in the lower right hand corner to access and clean out this filter. If this is clogged or the drain hose is clogged, you will have these spin and drain problems.
Nov 10, 2016 | Samsung Washing Machines
Won't fully spin and alarms nd as a code
You may want to check your drain to be sure there's not a clog/partial clog when draining out the water. Also, you may want to check the filter and possibly clean it. A partially clogged filter may cause this problem. And, you might try...turning off the unit for 10 seconds and turn back on...select Spin Cycle...press Start/Pause to drain the water. Good luck and hope this helps.
Walt
Apr 26, 2012 | Samsung WF218ANB 4.0 Cu. Ft. Front-Load...
MY WF218ANB/XAA WON'T DRAIN BETWEEN WASH AND SPIN CYCLE, AND GIVES ME AND ND CODE
Hi gumby323,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 09, 2011 | Samsung WF218AN Front Load Washer
I Have a Samsung Washing machine model number WF218anb. I can't get it to go through the complete spin cycle. I have taken all the clothes out and put it on spin only and it stays on 9 minutes for a very...
Wow, I have the exact same problem. I reported it under my extended warranty, and the repair shop replaced the drum/bearings without fixing the problem.
I was looking at Consumer Reports today, and some of the people there reported the same thing. Interestingly, some also reported that Samsung told them they couldn't use this washer in places where the temperature got below 60 degrees because it's temperature sensitive, somehow.
But the overwhelming reports on this model are good. I got the whole sequence to run by putting it on perm press -- it spun OK!
Jan 31, 2011 | Samsung WF337AA Front Load Washer
Need to read owners manual for samsung wf218an washer
WF218ANB: http://www.samsung.com/us/support/downloads/WF218ANB
WF218ANB/XAC: http://www.samsung.com/us/support/downloads/WF218ANB/XAC
WF218ANW: http://www.samsung.com/us/support/downloads/WF218ANW
Aug 30, 2010 | Freestyle Mongoose Bmx & Owners Manual -...
Samsung washer wf218anb/xaa has code dc and wont spin clothes they are still wet
The DC error code is an unbalanced laundry error. Try putting less clothes in and if that doesn't fix the problem, then replace the hall sensor( located behind the drum, underneath the rotor).
Mar 03, 2010 | Samsung WF337AA Front Load Washer
WF218ANB noise like a bag of rocks being shaken.
This is a direct result of Samsung's Vibration Reduction Technology(VRT). There is a hoop at the front and the back of the drum holding 18 ball berrings in each hoop (36 in total). These balls use centrifugal force and automatically move to the opposite side of where the load is unbalanced and balances it out. It is only in the washing machines, not dryers.
Dec 16, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Admiral Washing Machine not spinning
y Admiral washing Machine modle # lnc6760b71 will fill with water and agitate. But when it come time for the spin cycle it wont spin. I can hear the motor making noise. and now stop and it does not work, does not smell to burned What should I do??
Jan 06, 2008 | Admiral AW22 Top Load Washer
Kenmore Mod 110.26712693 Wont Spin
Pop off the trim pieces on the front edges of each end of the console. You will see the screws that hold the console down under them.
You can go to sears.com, click on parts, enter your model number and see a parts diagram of the washer.
Post back if you need further help.
Nov 17, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
78 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
