Question about Taylor 632-27 Ice Cream Maker
My Taylor 754-27 on the right side will stop workng just as the porduct gets up to consistancy. Do you think it is a weak or bad motor. The motor just stops and then when the product starts to warm up I can get it to work again by resetting it. Thank Lori
  • 3,740 Answers
Hi Lori and welcome to FixYa. I am Kelly,
If you have someone capable of swapping controllers between units move the controllers side to side by exchanging positions. I think you have a controller problem. Via the viscosity control (soft / hard) it senses amperage of the motor while in use. You either have a bad controller or a bad temp control. If you swap controllers and the problem persists then the temp control is bad. If the symptom changes to the other side then the controller is bad.
Thanks for choosing FixYa,
Kelly
Posted on Mar 27, 2011
I have a Taylor C707-23 that is freezing the product in the barrel and not dispensing. Then the drive motor trips. Had the sensor probe changed same thing.
If this is an ongoing problem that you have had for a while, it sounds as though your viscosity may be set too high. You can adjust the viscosity by removing the 4 screws that hold the face plate on. You will see 3 potentiometers. You want the left most potentiometer. It Should be labeled "Viscosity". You need a tiny screwdriver to turn it. Turn it counter clockwise about 1/16th of a turn. If your Ice Cream is already frozen, You will have to let it cycle a few times before the ice cream reaches consistency. If its liquid, then you will know as soon as the machine finishes the initial freeze down cycle.
If this is a new problem, then it is highly likely that your beater motor is going bad. To check this you would want to test the amperage of the motor when you initially draw product from the machine. A single phase 1.5HP motor in the taylor ice cream machines should not draw more than 7 amp on an initial draw right after freeze down. Its normal to draw around 6 amps then drop for a few second. In order to trigger the reset, the beater motor has to draw more than 6.3 amps for an extended period of time. Your reset may be set higher than 6.3 but that is average.
Jan 16, 2018 | Taylor Ice Cream Makers
Standby keeps turning on when in standby but auto works turns itself on and off fine. Both sides of unit
I don't think you have a problem... I have a Taylor 8756p-27. In standby mode with my unit the beater motor turns on for about 15 seconds every 15 minutes and the compressor turns on as needed to keep the mix at a safe temperature. This is what standby mode is supposed to do. If you don't want it to turn on and off so much in standby mode, perhaps leave it in AUTO mode and it will turn off and on as it needs to to keep your product at the proper temperature.
May 06, 2015 | Taylor 754-33 Ice Cream Machine Soft Serve...
On the soft Serve side of my Taylor ice cream machine it is freezing up and not letting any product come out pump still works don't know what the problem is I take everything apart clean it put it back...
if the product is frozen in the barrle for sure then you have a bad micro switch that is telling the compressor to keep running, but that product would be super frozen and come out in the shape of the barrel. if it is the consistancy of ice cream then your pump gasket might be bad and not properly pressurizing your barrel and giving you the impression of a frozen barrel.
Feb 19, 2015 | Taylor Ice Cream Makers
How to recognize why 339 raylor is not giving good product viscosity
If the machine runs and runs and can't satisfy your viscosity setting there is a refrigeration problem. The longer the machine runs the more the product breaks down, so you're problems get worse as the day goes on. It's not uncommon for these machines to lose refrigerant. I would guess that is the issue here.
You will need a refrigeration repair person to put gauges on the machine.
Here is some information I put together about the logic board adjustments on your machine. I think you might find this helpful.
Taylor Softech Control Boards
May 28, 2017 | Taylor Ice Cream Makers
How to find why 339-27 taylor not good product viscosity?
It could be a couple things. The most common is worn down scraper blades. Try new ones first. Worn scraper blades don't scrapers the cylinder walls and the ice cream that's stuck on the walls acts like insulation and it will take a lot longer to freeze this ice cream. If that doesn't solve the problem then you are likely low on refrigerant on that side. Your machine measures the viscosity by reading the amp draw of the beater motor. The harder the ice cream gets, the harder the motor works. If the ice cream isn't getting hard enough because of one of the reasons above, your machine wont shut off.
www.softserveparts.com
May 26, 2017 | Taylor Ice Cream Makers
I have a Taylor 794 soft serve machine. The left side is too soft.
Viscosity adjustments should not have to be made frequently on these machines. If you change products a lot, such as flavors of yogurt, minor adjustments may be required. If your machine uses 3 phase electricity and it machine has been moved or any electrical work performed you may want to check the beater rotation, the beater should rotate clockwise inside the barrel viewing from the front, if you look at the gear box from the back, the pulley should be turning clockwise as well. Otherwise, there is a fine tuning potentiometer on the control, you must remove the front cover to see it. Clockwise is colder/thicker. I recommend small adjustments. It is best to read the amp draw on the motor to see what type of amps it is drawing. If your mix is soft and your motor is drawing 4 amps, you may have another type of problem such as a bad motor. The board and control can also fail giving these problems. There are many things to check in addition to these. Hope this will help you get started.
Apr 05, 2013 | Taylor Ice Cream Makers
Taylor 754-27 runs good until ice cream is made then trips-not able to restart in auto or wash-able to turn beater with hand-not binding - after ice cream becomes liquid able to start again in auto or...
It is possible that your viscosity is set too cold. You should check the temperature of your product to see if it is too cold. Is the Ice Cream hard? It sounds like maybe the beater overload is tripping. Some of the overloads can reset on their own. If you have and know how to use an ammeter, it would be beneficial to check the amp draw of the beater motor to determine if you are exceeding the overload or not. Ice cream is generally good at a temp between 16 and 20 degrees F. Temps vary with product and product brands. I hope this information helps, it is hard to determine exact problem without being there.
Oct 04, 2010 | Taylor 632-33 Ice Cream Maker
I have a 754 Taylor with 404a refrigerant The side I am having the trouble with will not stay running long and stops. The product is to soft to use. I have tested the prob that tells the unit it is cold...
The probe is not used to determine viscosity. This model determines viscosity by reading the amp draw of the beater motor. The viscosity setting on the upper control board is for fine tuning. You need to check the lower board. There are jumpers on that board that determine the amp range of the upper board adjustment. Most machines running soft serve are on the five range. Your machine may be on a lower range setting. All you have to do is remove the jumper and place it on the desired setting. Of course, there could be other problems that cause this issue such as a bad beater motor etc. Hope this helps.
Sep 03, 2010 | Taylor 632-27 Ice Cream Maker
Ice Cream Makers Logo
343 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
