Question about FrancisFrancis! X5 Espresso Machine
My X5 won't turn on. I flip the power switch and nothing happens.
  • 100 Answers
Could be the thermostatic fuse on the boiler, the heating element died, many possibilities here...
Posted on Apr 02, 2011
  • 1 more comment
  • dconstant170 Apr 02, 2011
    Thanks! These were things I was afraid of. The lights don't even come on, so I'm wondering if there is a fuse somewhere that blew inside of it. I'm not even sure what the fuse would look like; the connections don't look like fuses to me; just connections. :(
  • matthew schwartz Apr 02, 2011
    Where do you live, this is not something you can repair or troubleshoot unless...you are familiar with electrical troubleshooting. We are here in Los Angeles, we repair these.
  • dconstant170 Apr 03, 2011
    Ah, I am in Iowa. A long way away from Los Angeles, sadly. I've heard the X5 can cost a pretty penny...or a lot of $$ to even have looked at, with a general cost of $150 to repair. If it costs that much, I will put that money into a new machine. I understand circuit flow to some extent. It's not rocket science, and I know to unplug it before playing. :) The innards look pretty straight forward, if I just understood what I was looking at and what to specifically look for. The only thing that looks suspicious in the machine is an attachment to the top of the boiler itself. The connections are covered with fancy plastic "insulators". There are two connections to the top of the boiler itself. One of the plastic insulators looked to be mildly melted. I don't know if that is a fuse or not; it looks more just like a connection. (Something I would cover with electrical tape and not the fancy plastic thing-a-majiggy.) Call me stubborn or stupid, but if it's an easy fix I would prefer to spend the $5 at home and not a lot for someone else to fix the $5 problem.
    Either I die a fast death from electrocution (unlikely...I know better) or I die a slow death from having to make espresso the old fashioned way...on the stove top. There are no radio-tubes that need to be de-energized prior to touching in the machine, so I'm safe until I try to fix it and plug it in. A good circuit-breaker and fire-extinguisher should take care of the rest if worse-comes to worse.
    Logic tells me it's a fuse and not the boiler. If it were the boiler (unless as it was dying it overloaded something), the lights should come on and it should power up to some degree. But since nothing comes on and doesn't even give a "sound" that power is flowing, it makes me think something blew in there so that the power isn't going far. If I could find my darn volt meter I would check the plug first to make sure there aren't any breaks in the cord causing the power to short, but I don't think that's the problem.
    Oh well, Gaggia Classic, here I come.
Linx Hoover platinum won't turn on
more than likely you'll have to order a new handle. Those machines are built in pieces so you just cant replace switch, motor, etc....
Feb 13, 2013 | Hoover Platinum LiNX Cordless Stick Vacuum
Won't turn on
If the front panel indicator turns on but nothing happens when the power switch is pressed, the switch may be defective or, more likely, the power supply has failed
Jan 16, 2013 | Sharp Aquos Televison & Video
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
Won't start
could be the neutral switch try and crank it while moving the shifter around also try and put power to the small terminal on the starter that will tell you if the starter is bad or the wiring or switches
May 23, 2012 | Cars & Trucks
Torro ride on wont start. Won't even kick over. Its like there has been a safety switched flipped as nothing is happening, when before I stopped for a moment it was working fine.
Insure you don't have deck engaged . There is a safety switch under the seat you can jumper it .If it is seat switch you will need to replace it.
Feb 04, 2012 | Briggs & Stratton Garden
My laptop was left with the top down and turned on. It was plugged in and when I opened it to use it again, the screen remained black. I tried using different keys but nothing would happen. I unplugged...
Hi, Nan.
Disconnect the power adapter, flip the laptop, unlock and remove the battery. Then, reinsert and lock the battery, connect the power adapter and try again.
Hope this helps.
Jul 30, 2011 | Toshiba Computers & Internet
My XL-15 won't power up. Everything seems to be in place but when I flip the power switch to the on position, nothing happens. I have looked at the fuse and it looks ok. Could there be another...
Hi Jan,
If the fuse is good and you are sure your outlet has power, then check the safety switch is being depressed. On the back is the lint screen, there should be a clip that depresses the switch. Hope this helps you.
Jun 30, 2011 | Alpine Air XL-15 Air Purifier
Z-70 copier won't turn on
Most likely the low voltage power supply had gone bad.
Less likely is a bad on off switch .
Jan 08, 2008 | Office Equipment & Supplies
FrancisFrancis! X5 Espresso Machine Logo
130 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
