Question about Vivitar ViviCam 5022 Digital Camera
If i put my camra on self timer win i print the pictures will the time show up on the pictures
  • 823 Answers
The time it took the picture? You want to know if the camera will show the time it took the picture using the self timer?
My answer is Yes and No.
Do you have your camera set to showing the date and time on the pictures now? If you do, then using the self timer would not change anything.
If you do have it set to showing on the picture and you don't want the date and time to show then change the setting on the menu function of the camera and turn this option off.
If you do not already have the camera set to show the date and time, using the self timer option is not going to make it suddenly appear.
Posted on Mar 26, 2011
I want to put date on picture its self so when its printed it shows date.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Mar 17, 2014 | Kodak EasyShare Z1012 IS Digital Camera
I recently installed windows 7 as replacement to my windows xp OS, after installation my web cam cease to function. i tried for the driver but couldn't find one. pls. help. thanx
your camra installed but win 7 will not showing check from device manager if device manager show the image device then installed. this will work on when you r using camra for chatting
Mar 16, 2011 | Computers & Internet
Want to shoot a timed pictures ie, a pic of myself and my sister together and me setting the camera on a timer and getting into the pic...what do I do? Don't have manual with me. I have a Canon EOS 40D
Did you know there are two firmware updates available for your camera? For a timer picture, here are the instructions: 1Press the <o> button. (
9)
2Select either <j> or <l>.
Look at the LCD panel and turn the
<5> dial to select <j> or <l>.
j:10-sec. self-timer
l:2-sec. self-timerN
3Take the picture.
Focus the subject and press the
shutter button completely.
The picture will be taken after the
self-timer delay elapses.
You can check the self-timer
operation with the self-timer lamp,
beeper, and countdown display (in
seconds) on the LCD panel.
Two seconds before the picture is
taken, the self-timer lamp will stay on
and the beeper will sound faster.
Do not stand in front of the camera when you press the shutter button to
start the self-timer. Doing so will throw off the focus.
Feb 02, 2010 | Cameras
Trying to figure out how to use the timer on my Nikon Coolpix S570
Press the self-timer button (left of OK).
Press up or down to choose either two second or ten second delay.
Frame the picture and press the shutter release halfway to set focus and exposure.
Press the shutter button the rest of the way. The self-timer starts, the remaining number of seconds shows on the display, and the self-timer lamp blinks.
After the picture is taken, the self-timer reverts to OFF.
To cancel the self-timer, press the shutter release button again.
Fuller details can be found in the manual under "Taking Pictures with the Self-timer."
Jan 15, 2010 | Nikon Cameras
Describe how to use the self timer on the samsung S830 digital camera
Make sure you're in a recording mode other than VOICE.
Press the Self-Timer button (right button) until the display shows the desired mode. Your choices are 10-second mode (the camera takes a picture ten seconds after you press the shutter button), 2-second mode (the camera takes a picture two seconds after you press the shutter button), and Double-self-timer (the camera takes a picture ten seconds after you press the shutter button, then takes another two seconds later).
You can cancel the self-timer mode by pressing the Self-Timer button again.
The 10-second mode allows you to run back for a group picture. The 2-second mode is useful when you want to take a picture without fear of camera shake; simply place the camera on a steady support such as a tripod. The Double mode increases the chances of getting a picture with everybody's eyes open.
Jan 11, 2010 | Samsung S830 Digital Camera
How do I get to the self timer?
Press Home key and see Clock icon in list, its self timer, select it and press shutter button to take picture, camera will take picture after 10 seconds.
Below image shows Timer Icon in your DSC-T70 camera.
Dec 20, 2009 | Sony DSC-T70 Digital Camera
Setting date on Canon elph Jr.
To set the date:
1. Press the Date button (rear left button on top of the camera)
2. Press the Select button (small round button up and to right of date button, may need pen point to press), display may show 97 1 1, with the 97 blinking.
3. Press the Set button (below the Select button) to change the value of the blinking character.
4. Press the Select button again to change to the next character. Use Set again to change. Repeat until date is set.
5. Press the Select button when all characters are set.
To set time, press the Date button again and the display should change to time (24 hour mode). Use the Select and Set buttons as above to set the correct time.
C, H, and P indicate the type of picture you want to take. C stands for Classic, and the picture will be in a standard aspect ratio. H is the wide angle setting, and the printed picture will be printed wide angle. P is panoramic, and the printed picture will be even wider angle than H. All this depends on the processor who develops your pictures for you. Ask if their equipment can read and process according to the instructions your camera will automatically put on each exposure on your film.
The three buttons on the left side are:
Top -- Flash setting. On (lightning bolt) or Off (lightning bolt with line through it).
Middle -- Film rewind button. Film should rewind automatically when fully exposed, but you can rewind before the film is fully exposed by using this button.
Bottom -- Self timer. Pressing this button puts a clock symbol on the display. When this is set, the shutter will delay 10 seconds after the shutter button is pressed. Press this button a second time to turn off the self timer.
Mar 17, 2009 | Canon Elph Jr. APS Point and Shoot Camera
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Self timer
There are two identical sized small buttons on the top. Push the one nearest the picture-taking button until it says self-timer. Push the picture-taking button. The display should show a countdown until the timer takes the picture.
Feb 18, 2008 | HP Photosmart 435 Digital Camera
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Nov 26, 2007 | Samsung Digimax S730 Digital Camera
Vivitar ViviCam 5022 Digital Camera Logo
108 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
