Question about ASUS M51A-A1 PC Notebook
Hello there... Thank you for listening. Power turn on and the asus logo freeze on the monitor. No access to bios at all. I can not boot from cd any hard drive. Please help me
    Genius:
  • 1,288 Answers
Try removing the hard drive, see if that allows you access to the bios. If it does, suspect the hard drive is damaged
Posted on Mar 26, 2011
  • 823 Answers
Try pressing control (ctrl) alt & delete keys on your keyboard when you get the screen that shows asus logo. Press all three keys at the same time. Do it two or three times fast in a row and tell me if it makes your computer turn off and restart again? You can answer my question by going to the problem you posted on fixya and click on the comment or reply link in blue.
if you can control the netbook by hitting those three keys then its possible to put the pc in safe mode with keyboard commands. If your using win xp - press and hold F8 or f2 right when you start up your computer. Sometimes you have to try this two or three times in a row to get it to respond on go into bios. On win xp - it takes three failed attempts in a row to automatically go to safe mode on a computer. if you pause inbetween start ups, it wont count them as together.
Some computers need the delete key pressed during start up to go into the bios system.
In recovery mode and lost power, then battery went dead. Now turn laptop on get the ASUS logo , in center, and Intel Logo, lower right corner, on black screen. Then black screen comes on again with...
Take disk out. Power down. Restart. See if will start up without a disk in it. Might be confused by your disk. Did you try to F8 or F9 while restarting to get into BIOS (trying to remember which one will boot you to BIOS). Then see if the CD/DVD was disable for boot up. Turn that back on if you can get into BOS so it will boot up you recovery disk.. If your OS is completely gone, you will have to reinstall...
Sep 24, 2013 | ASUS K Computers & Internet
My Acer Aspire 7741G freezes at the logo screen. I cannot access BIOS or SETUP. I have tried to cold boot with the battery, without the battery, after turning it off and holding the power button for
the bios needs to be replaced as it seems to be faulty, its on a chip in the laptop and that chip needs to be changed. check with electronicpartner.ie they also offer free collection
Feb 19, 2013 | Acer Aspire 7741G3647 (LXPXB02046) PC...
How to access bios for ASUS E4574
When the asus logo comes up press F2 that should take you in the bios screen, check bottom left of logo for the F key number that is assigned for bios to be sure.
Jul 03, 2012 | Computers & Internet
HI, ive been having a problem with my Asus A9RP. Been trying to fix it but it is still futile. Everytime i open my laptop, it just stays on the logo. no response from any of the keyboard. i tried to remove...
Bios is not operating properly. Either it is corrupted or you have a bad peripheral causing issues. Disconnect all you can, (hard drive, optical disk, etc) and then see if it still freezes on boot up. If you have 2 memory sticks disconnect one and try again till you check out both chips. If all disconnects do not change anything then my original comment re bad bios stands.
Apr 08, 2017 | ASUS A9RP Notebook
I turn on my Asus N50V and it hangs at the initial ASUS splashscreen ... if I hit F2 to entr the BIOS it goes through basic post but then hangs on the BIOS "Wait..." screen
Please remove any external devices (if connected) to your laptop
Remove the power adapter cable
Remove the battery
Push and hold the power button for 10 seconds, this will remove unwanted charge from the laptop electronics.
Then connect the power adapter cable alone and switch the laptop on and check if it is working fine.
If not remove the power adapter and connect the battery alone and try if it works fine. If it still does not then we have to remove the other components that are detachable from the laptop like
1. CD / DVD drive
2. Hard drive
3. Memory modules (if you have 2 remove one)
4. PC cards
even after checking with all the above options, if the computer is freezing we can definitely confirm a core hardware issue.
Feb 02, 2011 | ASUS N50Vn Notebook
I have the identical problem as chrisdangelo
hello
I have read your problem and the solution to your problem may be following.
  • The BIOS setting may have changed.You can reset the BIOS settings.
  • The hard disk type may have changed..look for SATA and ATA.
  • Or your window got corrupt.Reset the BIOS setting and reinstall the windows using boot able CD.
  • if nothing work out then may be your hard disk connector is loose or your hard disk is gone.
thank you
Jul 29, 2009 | ASUS Eee PC 900 PC Notebook
When i turn on my Notebook it freezes at the asus logo i can enter my bios but it wont let me boot my recovery cd so if you know how to fix this problem and make my pc work again this would be great thank...
If you can enter the bios setup screen than set your boot priority at boot from CDROM. Save the settings, put in the recovery CD, let the computer start, and it should boot from the CD. If it still does not boot from the CD, than the CDROM drive itself my be the problem. If you had some work done on it recently, then chances are who ever did the work did not connect the CD Drive right, this is just a possible cause of the problem. Or it could be the drive itself is dead.
Jun 30, 2009 | ASUS N80VN-C1 Intel Centrino 2 Core 2 Duo...
Mother board freezes on abit logo wile starting....
Hello Carlos,
Did you open the powersupply and check? I have recently worked on a PC with a similar fault and I found that the circuit board is partly charred and couple of capacitors leaking. I advice that you check it and post back..( I can't forget that repair coz I got one hell of a shock while working on it)
Sai.
Mar 02, 2009 | Abit Computer-model:AN78GS Motherboard
VISTA uninstal
the first thing you have to do is go to acer support website to see if your model supports downgrade to XP, in other words XP drivers for the model you have, if it does get back to me for more help, if it doesn't your stuck with vista i'm affraid
kind regards
Nov 17, 2008 | ASUS Eee 4G Notebook
ASUS A6R HANGS AT STARTUP
Use original win xp cd and reapir it but befor that unplug hdd + ram and wait 20 min then repair ur hdd if not take live asistance with me and i will help u to fix it
Oct 12, 2007 | Computers & Internet
ASUS M51A-A1  PC Notebook Logo
226 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
