Possible lines are starting to freeze unplug open doors for twenty four hours the freon isnt circulating
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_8b3f0f0fc5f566a7
I tried to look up your model,
Is the model Number correct?
21TFA ?
Klaus
SOURCE: Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
SOURCE: Water accumulating in top shelf of refrigerator
I solved this by emptying everything in the freezer and taking out the floor of the freezer (2 screws - simple) and finding the drain hole covered in ice. I used a blow dryer to melt the ice. Then I used a turkey baster to place boiling water into the drain hole, waiting 30 seconds, using the baster again to remove the cooled water and reapeating this until the ice in the drain tube melted. You can tell when the ice in the drain tube melts completely as you can hear the water falling into the pan in the bottom of the unit (under freezer and refrigerator).
SOURCE: Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
SOURCE: ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
SOURCE: Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
