Question about Custom Phones Animated Talking Mickey Mouse Telephone (TD/TS)
I need information on an animated, talking Mickey Mouse lamp. The lamp blew a fuse and there are no markings to identify the size and type of fuse it is. Are there wiring diagrams and trouble shooting information available? Where would I find them and what would be the cost. Thank you.
Why does it have so much amazing stuff in it? And why does it make me laugh?
Bethany, Mickey is just the coolest !!! what more can be said?
Mickey mouse is 88 years old now. Check the attached links cartoons, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
First Mickey Mouse Apperance EVER May 15 1928
Roughin It Mickey Mouse Cartoon Disney Shorts
Dancevidaniya Mickey Mouse Cartoon Disney Shorts
Movie Time Mickey Mouse Cartoon Disney Shorts
Apr 18, 2016 | Disney Fisher Price Dance Star Mickey...
I still have not been able to find fuse for brake lights. Looked on back of fuse panel, nothing, found hot wire on brake switch, no power on hot wire, but Haynes manual does not give enough information as...
Not to worry. Power for the stoplight switch comes from 20A fuse 5 in the power distribution center and is applied to the brake lamp switch (confusing, no?). Switch output is connected to a junction block and then to the center high mounted stop lamp. If you press the brake pedal, even with the engine off, the center high mounted stop light should come on.
Sep 21, 2012 | 2001 Dodge Dakota
Where is fuse for tail light of 2004 mercury mountaineer
Tail lights. Not exactly sure if you may be talking about like the park lamps when you turn the lights on or if you are talking about the brake lights. I just want to be sure I am giving you the correct information. If you are talking about the park lamps and you are just having problems with the rear ones, then you are dealing with an electrical issue. Below is a the location of the fuse panel as well as a diagram of the fuse layout. I have marked the fuse that covers the park lamps. The thing is this would also be the front, side and the power to the head light switch so if you are having just rear park lamp problems, again it would be an electrical wiring problem. If you are talking about the brake lights, in that same panel fuse number 25 would be the one to check (not marked with an arrow). Both of them are 15 amp fuses. Hope this helps....
Apr 07, 2012 | 2004 Mercury Mountaineer
Dance star mickey
I just had this same problem. Micky danced and moved his mouth but no sound. I opened up Mickey's outfit at the back of the neck up to the top of his head and found a broken wire. I spliced the wire back together and Mickey works again! The 2 wires go from the back center of Mickey's head to the top of his left shoulder. Hope this helps someone else!
Jan 08, 2012 | Disney Fisher Price Dance Star Mickey...
Mickey mouse dance star ......how does it work? I cant get it to play xifferent misic or anything
Hi krentch
After reading the solution to your problem could you please rate if my answer was helpful thanks...
You can download the manual at this link i have provided just click on the link to access the information you will need for operating dance star mickey...
http://service.mattel.com/instruction_sheets/V0797%20Dance%20Star%20Mickey.pdf
Cheers nikki
Jan 08, 2011 | Disney Fisher Price Dance Star Mickey...
My gold Mickey mouse Lorus watch was opened a part damaged by the person replacing the battery. This is not a digital watch, but has nthe mouse with hands and a second wheel at bottom.
You are probably going to have to look for an identical watch for parts.You might try this site:
http://www.esslinger.com/watchparts.aspx?gclid=COCr3t2F9KUCFcIKKgodgiARnA which is parts for watches. I'd have a look on ebay as well for a watch that is not working. Of course it does depend on the part you are looking for. I am also wondering if the inner parts for another Lorus mickey moue watch might fit, but maybe you don;t wish to change it out from the original.
Dec 17, 2010 | Disney Lorus Out of Production Collectible...
Can't delete pictures
To delete pictures....Use the right arrow button to highlight the the check mark that is on the left side of the screen & then press the red big red x button on the camera.
Dec 22, 2009 | Disney Mickey Mouse Camera - Mickey &...
The time delay fuse blew...I need to replace it but list the fuse
Fuses are designed to protect systems, TD fuses are also termed AS (anti surge) these are designed to absorb the surge from the transformer or other components within the amp.
It is very important to replace the fuse with the same size and type, as this will maintain the systems safety design. Wrong size and type of fuses can cause fires.
Now, it is possible that the circuit board has an ID (indentity print) on it, have a good look with a torch, it may well be marked. If not then contact the maker support team they will be able to help you. have the size (20mm or 1.25inch) ready, the model and serial number of the amp ready when you call anybody for help.
Hope this helps, thanks for using FixYa
Sep 24, 2009 | Technics SC-DV290 System
Custom Phones Animated Talking Mickey Mouse Telephone (TD/TS) Logo
409 people viewed this question
Top Custom Phones Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Custom Phones Lands Phone Expert? Answer questions, earn points and help others
