Question about Saitek Pro Flight Yoke System Flight Simulator
My Saitek yoke system suddenly seems to loose the roll axis center. without touching the control, the ailerons move by themselves to an extreme right turn position. On the panels of all aircraft equipped with an aileron trim wheel, the wheel will constantly turn on its own towards the right turn stops. In order to fly straight, I have to compensate with the yoke towards the left end stop position. Could there be a rheostat problem? I have tried plugging and unplugging but nothing seems to work. It is only about 8 months old. Please help. Thank you H.Baumann
4 Suggested Answers
SOURCE: When the yoke is pushed/pulled (the y axis of the
although this did not solve my problem, it is worth a try to reset the calibration settings stored in the windows registry.
These are the steps for it:
To recalibrate, first unplug the controller.
Go to start/run and type 'regedit'
The registry editor will have a list of folders on the left hand side. Go
down into the following folders in order.
HKEY_LOCAL_MACHINE (HKEY_CURRENT_USER if on VISTA)
System
CurrentControlSet
Control
Media Properties
Private Properties
Direct Input
Inside the Direct Input folder, delete any folder that begins VID_06A3.
Once done, close the editor.
Plug the controller back in and move all the
axes (including throttle) through their full range of movement 4 times.
Now go to control panel/game controllers/properties to see if there are any changes to the test screen?
If it helps you, it didn't do it for me ;) but I reckon it's worth a try
Posted on Jun 12, 2009
SOURCE: Using fs9 with Saitek yoke - aileron control
The Saitek joystick yoke used to work perfectly. It was only recently that I experienced the aileron drift!
I un-installed and deleted averything related to FS9 and then started to load FS9 and all the add ons etc. The yoke works perfectly again. I have no idea......!
Posted on Dec 27, 2009
  • 11800 Answers
SOURCE: My Saltek flight yoke is not functioning anymore.
This is a hardware defect , nothing to do with the drivers, software or the OS you are using in .
The position and movement of the control elements is recorded by a simple rotating potentiometer. The analogue signal from the potentiometer is converted to digital by a simple AD converter circuit inside it. If one of the control elements no longer reacts properly the first thing you must check is the corresponding potentiometer - open the unit, access the potentiometer and see if you can repair or replace it. Then check the status of the components on the control board and finally the wire connections between all of them - a wire might have been broken.
Posted on Apr 07, 2011
In FSX (Win7 64bit) couldn't get enough speed to take off! Found that when Saitek proflight quadrant set at max only around 85% power delivered. Had to use mouse pointer in virtual cockpit to advance...
Hi Alf,
This sounds like a deadzone setting not allowing the throttle axis to go full.
There are 2 places in which the deadzones can be set:
In FSX: Settings> Controls> Calibration, there select your Yoke and then set the NULL to the left, which is 0.
Or in windows in Input Devices (Win Xp - is in Control Panel, Vista or Win7 go to Games Explorer>Tools>Input Devices).
In Input Devices->Select the Yoke and click Properties, then go to the Deadzones Tab and set the deadzones for the Throttle. Mixture and Prop to 0.
Hope it helps...
Apr 29, 2011 | Saitek Pro Flight Yoke System Flight...
Saitek pro flight yoke problem
This is a know fault on Saitek yokes that is now cured. take it back and explain that it is suffering from "Ghost button pushing" and they should change it for a unit that has been updated. This problem is well documented on the web.
Jun 05, 2010 | Saitek Pro Flight Yoke System Flight...
Using fs9 with Saitek yoke - aileron control drifts to the right. Had the yoke for several years - it didn't use to do this. Reinstalled fs9 after a year of none use and now have this drift trouble.
Dec 26, 2009 | Saitek Pro Flight Yoke System Flight...
Saitek yoke's accuracy prroblem.
Try uninstall and reinstall software,
if that doesn't solve then try on different pc
still not working repair/replace unit.
Try Microsoft unit with force feedback or you can buy without FFB for less than £10
Aug 02, 2009 | Saitek Pro Flight Yoke System Flight...
When the yoke is pushed/pulled (the y axis of the yoke affecting the elevators of the plane) it also affects the x axis of the yoke or the ailerons of the airplane. In my case I want to gain height (pull...
System
CurrentControlSet
Control
Media Properties
Private Properties
Direct Input
Jun 11, 2009 | Saitek Pro Flight Yoke System Flight...
Aileron control
You didn't say what game you are using this in. Many flight sims allow you to setup controls more specifically and to your liking. I would look for such a menu in game and reverse that axis.
Oct 23, 2008 | Saitek ST290 Pro PC Flight Stick [ PS23 ]...
X-axis trouble
I had the same problem with my X52 and searched high and low on the internet for a solution. What I did was pop the base off and found a loose connection on the x-axis wires. I re-routed both the x and y axis contact wires underneath the p/s2 port and put it back together. Seems to be working fine now. I will not that opening up the controller will void your warranty and it also could be possible that your x-axis problem could stem from something completely different from what was wrong with mine. You may contact me if you need any help with it. mynameisbob AT gmail DOT com.
Jul 19, 2008 | Saitek (PS28) Joystick, Throttle
X52 calibration
have the same problem with my X52; cant get the rudder control (twisting control) work fine, but it goes on its own way to the right and can't be calibrated no way. this is my 3rd SAITEK X52 (2 X52PRO, 1 X52), and all I can say is: SAITEK IS THE WORST **** I EVER HAD IN MY LIFE.
Mar 03, 2008 | Saitek (PS28) Joystick, Throttle
Saitek Pro Flight Yoke System Flight Simulator Logo
136 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
