Question about Whirlpool Washing Machines
Not spining properly on daily load cycle - Whirlpool Washing Machines
  • 668 Answers
Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
I hope this helps.
Please reply with additional details for further assistance.
Shane
Posted on Mar 26, 2011
The Samsung swf 8005 washing machine ignores the spining cycle in the program
try to operate the machine with nothing in it... see if it spins.... if it does this means your loads are not balanced properly...
Feb 07, 2011 | Samsung Washing Machines
Holds water wont compleatly drain shuts down before spine cycle
Hello
If the washer shuts down before spin cycle it indicates that it is unable to drain properly. Please check the drain hose/drain pump filter for any clogs/blockages and try cleaning them to solve this problem. Also after cleaning check if the pump is working fine.
Kevin
Nov 10, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
Amana LW8303L2 will not spine
http://www.washerhelp.co.uk/washing-machine-repairs.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Belt replacement on these is a slightly intimidating job to the uninitiated, but possible.
http://www.american-appliance.com/se...stic-Chart.htm
http://www.applianceaid.com/amana-wash.html#belt
Lots of pictures and help at these sites.
Main thing is use ONLY the factory-authorised replacement belt on these. It is designed to have the right amount of slip/grip to enable your washer to work properly. This is CRITICAL on Amanas.
Apr 14, 2010 | Washing Machines
During spin, machine moves!
Did you remove the transport rods from the back of the unit? this will cause the unit to jump around a lot when it goes into the spin cycle. Also make sure the feet are all level and the unit doesn't rock from side to side.
Mar 22, 2010 | LG WD-16115FD Front Load Washer
On spine cycle washer thrashes around, hard thumps
Your load is probably unbalanced. Open and redistribute the garments or take some items out.
Mar 08, 2010 | Bosch WFMC 3200 Front Load Washer
Washer not draining properly.
your pup is not working properly it may have somethig inside or draining house coud be that problem too good luck
Nov 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Knocking, moving & won't complete spin cycle
you can remove the lower acess panel( 3 screws along the bottom front, form there youll see 4 suspension/ shock absorbers. make sure they are all attached, chances are they dislodhed in the move, they should snap right back into holders if need be.
Oct 30, 2008 | Kenmore Elite 45986 Front Load Washer
P801front load washer
put on prewash cycle. note which tray water enters and that is the prewash tray.
put on wash cycle which has no prewash. note which tray water enters and that is main wash tray. remaining tray is rinse
Sep 06, 2008 | Samsung WF337AA Front Load Washer
Spin cycle
hold cancel for 10 secs
hold end of cycle signal 10 secs.
one of them should reset it.
Feb 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
