Question about Troy-Bilt Garden
I own a Troy Bilt Pony Tiller #135297 with B&S engine 5hp. I cannot get it to start. I have put in new gas, s.plug good, new oil, ... the sticker has worn off of the lever positions (2 levers) and I don't know where the levers should be to start it. Also don't know if it needs a key to start it. ANY HELP?
SOURCE: tilller will not run
Get the model # and serial # off of the sticker. Got to the Troy Bilt site and use the owners manual link. Need to leave off the last 3 numbers of the model #.
If that site does not have the manual, I've found them on the MTD site. I enter only the first 2 numbers of the model # and then hunt for my manual from the list.
If all else fails, you can call Troy Bilt at their # provided on the site.
Hope this helps.
Posted on May 20, 2009
#1 Taper
  • 1041 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
  • 376 Answers
SOURCE: ryobi gas chainsaw- chainsaw brake is stuck on. How do I release
You just have to pull the lever back, like it was on the saw, until it clicks/unlocks. It may be hard to do, but thats what has to be done.
Posted on Jun 11, 2009
  • 3 Answers
SOURCE: my poulan chain saw sat for about 2 yrs with gas
Empty out the gas and replace with proper gasoline mixed with oil in the proper proportion. Always use a good quality 2-cycle oil that contains a fuel stabilizer.
To start the generic chainsaw, follow these steps:
1. Pull the choke all the way out
2. Press the fuel bulb serveral times to prime the carb - you can feel when the fuel flows into it.
3. Set the lock on the trigger to full speed.
4. Now, pull the starter rope until the saw sounds like it tried to start.
5. Press the choke in to the 1/2 way position.
6. Pull the rope until it starts.
7. Release the trigger lock and push the choke all the way in.
If starting it when it is warn, skip steps 1 and 4.
It is unlikely that the spark plug is the problem. If you replace it without properly setting the gap, you may make it worse. If you start trying to adjust the carb without knowing exactly what you are doing, you will make it much worse, You can try spraying some carb cleaner into the carb and pulling the rope to such the cleaner into the jets.
In the future, always add fuel stabilizer or oil with a stabilizer to you gas/oil mix. This prevents the varnishing caused by aging gasoline.
Posted on Jul 11, 2009
  • 1129 Answers
SOURCE: How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Posted on Jul 14, 2009
What is a 1969 troy built tiller worth in great shape?
I sold my pony 5hp in good shape in Canada for 275.00. At that price I had a number of people wanting it. Cheers to you!
Sep 21, 2014 | Troy-Bilt Garden
Troy bilt pony 5hp rear tine tiller is leaking behind muffler on side of motor
Head bolts are probably loose, check the 3 nearest the mouffler and of course check all of them.
May 09, 2011 | Troy-Bilt Pony Garden Tiller
I have an older Troy-Bilt tiller (model & serial # unknown) that when I start it (manual pull) it runs for a second and then shuts off. I checked the spark plug, fuel line and inline filter, fuel, oil...
could be bad coil. does it stay running with choke on? or half on, if so its a gas problem. could be the main jet is plugged in the carb. Or water in the carb bowl. Remove the bowl nut and let some gas run out the put it back in and try it. just guessing as not much info to go on.
Apr 26, 2011 | Troy-Bilt Pony Garden Tiller
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
Pony Garden Tiller: does a tiller with a briggs and straton engine nee...
The pony tiller with a Briggs and Stratton engine only uses gas do NOT mix oil with the gas.
Frank
May 18, 2010 | Troy-Bilt Pony Garden Tiller
I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Jul 17, 2009 | Troy-Bilt Pony Garden Tiller
Tilller will not run
Hope this helps.
Apr 29, 2009 | Troy-Bilt Pony Garden Tiller
What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Feb 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Garden Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
