Question about Hotpoint Washing Machines
Hi I have a Hotpoint Aqualtis AQXXL 129 PI. I put
Hi I have a Hotpoint Aqualtis AQXXL 129 PI. I put washing in and went out, then came back to find all the lights flashing and the door still locked. I tried turning it off and then tried turning off at the mains but the door still remains locked. I tried putting on the shortest spin cycle to get to the end of the cycle again, but the machine made noises but didn't spin. I have my daughter's school uniform trapped inside and there will be hell to pay on Monday morning if I can't get it out! Please help!
3 Suggested Answers
gittos73
  • 244 Answers
SOURCE: Faulty washing machine
if its no heat there only 2 items it can be heater element or the thermostats u could test the element by replacing the plugged in wires with wires that hasve a plug on place the wires into right places turn the plug on and if the element works it will start to glow turn it off as soon as u see it glowing from the inside of the washer also u can check the thermostats by dropping them into hot water and u should hear them pop
Posted on Nov 19, 2008
  • 25 Answers
SOURCE: hotpoint aqualtis washing machine model AQXXL 129 PM my doors not locking stopping in a cycle ,and water not draining , and lights flashing
find a dealer and get a manual for the washer it will have a trouble shooting section will tell exactly what is wrong
Posted on May 17, 2014
Washing machine won't take enough water and won't take washing powder and leaves bad smell inside
AH yes front loaders are bad about this type problem .change the detergent to liquid and run a coulpe empty wash cycles with bleach and or baking soda
Mar 21, 2015 | Ariston Technologies Washing Machines
Hotpoint aqualtis AQXXL 129PI
could be a bad timer? sticking at the wash cycle. it does agitate right? other wise bad water pressure switch
Aug 07, 2014 | Hotpoint Washing Machines
Hotpoint aqualtis washing machine model AQXXL 129 PM my doors not locking stopping in a cycle ,and water not draining , and lights flashing
May 17, 2014 | Washing Machines
Hotpoint aqualtis washing machine model AQXXL 129 PM , runs through the cycle then stops at times leaving water in the drum and all lights flash why ?
the pump could possibly be jammed. you will need to drain the machine and remove the filter to check for any obstruction
May 17, 2014 | Hotpoint Washing Machines
Hotpoint aqualtis error code F04
Indesit (Hotpoint Aqualtis, Ariston) 'F04' states 'pressure switch jammed empty, check pressure switch, wiring and module connections'.
It is not that unusual to find it cured by having the connections gently pulled apart and replaced, thus 'cleaning' the contacts back to correct operation ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 05, 2011 | Washing Machines
I have washing machine aqualtis aqgl 129 pm and the ligh start pause flask and the machine dont work
Have you selected a program? Is water available? You haven't selected delay?
Then I suspect it may be a faulty door sensor, it wont start if it thinks the door is not shut. Try opening and reshutting the door.
Jan 27, 2011 | Hotpoint Washing Machines
A hotpoint aqualtis aqxx149pm spinning loudly
Hi, This is a common problem with the hotpoint range. It will be the main wash bearings that have failed and need replacing. This is a very easy process but is quite time consuming. Remember tho change everything that is; Bearings, and bearing spider and front tub seal as you dont want to have to do it again in a short time or have leaks coming from the front.
Good luck and get back to me if you need any further help....................
Jan 02, 2009 | Washing Machines
Nov 18, 2008 | Washing Machines
Washing Machines Logo
290 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
