Question about USA Spec Pa11-vol Ipod To Volvo Car Stereo Adapter
PA11-VOL is playing only on the right side speakers. cd and radio are ok. Sometimes it plays normally both sides but then stop playing on the left side with no apparent reason. Thank you
    New Friend:
Did you ever get a resolution to this issue? I'm currently having the exact same problem.
Posted on Jan 28, 2013
The radio in my 1995 jeep grand cherokee plays full volume on the right channel when turned on.
  1. bad radio amp
  2. bad wiring to speakers.
  3. or bad speakers.
the tests are easy, ask.
my guess is the weak side is bad, the load side is ok.
you can turn the volume down on the load side using volumn control
if yes that side is ok, fix weak side.
ask how, but make sure the wiring in all 4 corners are not damage
and at both ends of harness.
Feb 27, 2015 | 1995 Jeep Grand Cherokee
Only tweeters are working while playing radio. No other speakers are working. ...radio operates normally, turn on , cd, all options work. What could this be? It's a 2006.
all speakers r connected to the same wires on the radio
If left/right balance and front/rear fader work properly
and sound is coming out it is likely (but not definite) radio is ok and speaker wiring is the issue.
HOWEVER, if it sounds the same on both left and right, it could be the radio. It is unlikely both sides have the same issue at the same time without it being in the radio.
The only way to verify it to disconnect the speaker and substitute a known good speaker.
So back to troubleshooting.
Dec 09, 2014 | Cars & Trucks
Radio trouble shooting
It seem like the stereo for the radio is failing, either because of a weak radio signal or defective aerial
Jul 30, 2014 | Mercedes-Benz 1992 Mercedes 500SL Radio /...
I have a ford fiesta 2003 reg, when playing the
what type of cd it is? try to play another cd ,it could be problem with cd , cause if is problem with stereo system it should happen with radio.
Feb 09, 2010 | 2003 Ford ZX2
USA SPEC PA11-Vol unit will not play iPod using the iPod cable.
where did you plug this behind the radio ? or at the cd changer cable ?, the interface needs to be plug into the radio not the cd changer cable
Dec 20, 2009 | USA Spec (PA11-VOL) for iPod
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
Color codes wiring for delco bose radio replacement n a1992 installing a aftermarket brand thx.
1992 Cadillac Eldorado Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
Oct 07, 2009 | 1992 Cadillac Eldorado
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
USA Spec Pa11-vol Ipod To Volvo Car Stereo Adapter Logo
61 people viewed this question
Top USA Spec Car Audio & Video Experts
xxxxxx xxx
Are you an USA Spec Car Audio and Video Expert? Answer questions, earn points and help others
