Elllo iv got a lg 50pc3d tv the tv blink 16 time wont open ive test my voltage and thats what it give to me original value 3.3v ---> 3.2V in real time original value 5v -----> 6.2V original value 6v ------> 7.4V original value 12v -----> 14.7 original value 19v ------> 24V would it be a powersupply? can u help me with this
Not sure if it is a power supply issue for sure, but I've had a similar issue on an older model LG LCD TV. My symptoms were: in the middle of watching TV the screen blinked a magenta color for a moment and then the screen went blank, the TV would seem to turn off and on but could not get the screen to show anything, my power light would also blink 13-16 times and was delayed when turning off. after researching this forum I found a fix. Mine was a problem with a damaged capacitor on the power board it was a Samxon 2200UF 20V capacitor that had a slight bulge on the top. If you remove the back panel of your TV and locate the Power Board (the circuit board that the power cord plugs into) check and see if any of the capacitors on this board have any bulges at all they may appear very slight but will be on the top. If you you find any with bulges they are most likely defective. Remove the circuit board and de-solder the damaged capacitors with a soldering iron from the bottom of the board, and replace with a 2200UF capacitor (or whatever UF value is associated with the damaged capacitor) with a higher voltage rating of 25V or higher that way they will run cooler. Be sure to note how the original capacitors were put in (which side the negative connects to) to avoid damaging the new capacitors. I was able to find the capactitors at a local electronic store, but you could also find them online. The capacitors are $2-4 dollars each and a soldering Iron is approximately $10 at a local radio shack. This fixed my TV, cost me $12 with a soldering Iron and took approximately 1 hour to repair. If you do not see any damaged capacitors then it may be another issue, but it is a simple process to check, Again I did not perform this on the same model TV, but it was a similar symptom and an LG. Good luck!
Posted on Mar 26, 2011
  • frankgaz20 Mar 26, 2011
    ive changed 3 caps for caps with same uf and Voltage
    but it didnt works
    the tv open black , blink 16 times.
    im not able to chg channel , there's no display but a black screen
Led power light comes on but screen will not come on.
"Blinks a few times" implies the TV is flashing a fault code at you. If you can find a service manual for your model, count the number of blinks and look it up in the diagnostics section.
However, the most likely problem is a burned-out electrolytic capacitor in the power supply. These are usually easy to identify visually; the top of the can-shaped capacitor should be flat, but may be bulged out and may have brown or black material leaking from the vent scores. The photo below shows a bad capacitor to the right of a good one; both have black plastic sleeves.
If this is the case, replacement capacitors are relatively cheap. However, you should look for the following criteria in choosing a new part:
>Capacitance (uF): same as the original, or 10% higher if the original value is not available
>Voltage: same or higher
>Temperature: Maximum temperature should be same or higher
>Physical size: should fit in the space occupied by the original; if buying a taller unit, make sure it will fit when the back cover is reinstalled, and make sure the capacitor will not touch heat generating parts such as heat sinks, resistors or large transistors.
>Ripple current: get the highest available without compromising too much on endurance. Ripple current may be specified in mA or A; 1 A = 1000 mA. Sometimes you can get a better rating by going to a higher voltage part, but physical size may be a limitation.
>Endurance: Try to get 8000 hours or better.
I usually use Panasonic FR1 series capacitors, although United Chemi-Con EKZN capacitors are also worth a look. 25351068-tkog3zu3xmxabptjkcidpctj-1-0.jpeg
Jan 02, 2015 | Insignia Solutions Original INSIGNIA TV...
My L.G 50pc3d won't turn on and all I hear is
try to check all capacitors inside if looks like bulged on top try to replace it with the same value.
Apr 27, 2012 | LG Televison & Video
LG 50PC3D capacitors bubbled on the powerboard. Ordered original powerboard #6709900020B, was sent a CRB30626401. Installed the new powerboard. The powerboard comes up now and stays but no picture. Is...
Not familiar with your set but check for a separate, smaller power supply board or module that services the display itself. Plasma sets require a high voltage for operation and if it failed, it could cause the failure of the main supply from which it often receives its input DC. Since the plasma service voltage isn't always the same from one set to the next, can't give you specific levels to look for but it will be high enough to cause serious pain; use caution.
Sep 24, 2011 | LG 50PC3D 50 in. Plasma Television
Changed power board
That's why I say people, do not trust power blinks, trust service specialists with experience.
Any short in any board connected to the power supply would result in , well, short at the output of the power supply.
The monitoring logic would, in turn, read that as lack of voltages and would report is as bad power supply.
Except the problem is not in the power supply, but in the external module which has shorted!
I am about to write a short and helpful article now on troubleshooting plasma TV for problems like this; I am about to post it on my blog at www.coppelltvrepair.com .
Hope it will help you!
May 26, 2010 | LG 50PC3D 50 in. Plasma Television
I'm looking for a USB connector for my Fuji DX-7.
Your camera is intended for serial connection.
You can get RS-232 to USB adapters, but I'm pretty sure that they wont work with your camera. DX-7 was originally equipped with 5V Smartmedia cards. Newer (!) type cards are 3,3V. You can get a card-reader for 3,3V cards but not for 5V cards.
You can tell the difference between 5V and 3,3V by the missing corner of the card. Seen from the "golden side" 3,3V cards are missing upper right corner, while 5V cards are missing upper left corner.
I don't remember if DX-7 could use both types.
Dec 07, 2009 | Fuji DX-7 Digital Camera
LG 50PC3D not turning on
Without seeing the unit itself and opening it up/running tests I couldn't tell you exactly what is happening, however I can offer some suggestions as to what it could be.
1) your power supply is bad. That clicking sound is the power relay coming on and going off.
2) your main board is bad. It handles a lot of your signals for powering on your set. If it's bad, the tv won't turn on correctly as it doesn't recieve all the right signals.
3) your Y or Z boards are bad. These could cause the power supply to go into shutdown if the voltages on these things are too far out of whack.
Easiest way to tell if you're going to go into your tv is to try to unplug your Y and Z boards and turn it on. If it turns on and stays on chances are one of those two boards are bad.
Feb 18, 2009 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
LG Plama tv 50pc3d does not want to turn on.
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you could save $300 at least! Mahalo!
Dec 18, 2008 | LG 50PC3D 50 in. Plasma Television
Power problem with an LG 50PC3D Plasma 50" TV
YOU PROBALY HAVE A BAD Y SUSTAIN BOARD OR POWER SUPPLY. POWER NEEDS TO BE DISCONNECTED FROM THE Y SUSTAIN AND THE VA & VS VOLTAGES CHECKED.
Jul 29, 2008 | LG 50PX4DR 50 in. Plasma TV
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
192 people viewed this question
Top Televison & Video Experts
