Question about GE Refrigerators
GE Monogram refrigerator accumulating under bin.
  • susan_martin Mar 26, 2011
    Yes water is accumulating under the bottom bin. Condensation is forming under a louver (which is half way up on the left side) then dripping down. Temp is set at recommended 37 degrees and freezer at 0. This is a side by side 2005, model #ZFSBZ23DRG SS. Any ideas? Thanks!
    Scholar:
  • 116 Answers
Hi do you mean you have water accumulating? If so you might have a leak in your evaporator drain pain, its located in the back of the refrigerator on the inside behind the shelves. Or it needs defrosted possibly a bad defrost thermostat/heater if tihs model has a heater. I would need the model to be more certain, these problems arent too serious.
Sean
Posted on Mar 26, 2011
  • Sean Miller Mar 26, 2011
    Yes like i said you either have a frosted up coil or a leak in the drain pan under coil, this is located in the refrigerator on the bottom in the back. Right behind where the water is.
    Sean
GE MONOGRAM Icemaker: ice melts and re-freezes, resulting in a large frozen piece of ice in the bin
Are you sure icicles are coming from ice bin? Remove ice bin and look above it and see if they are coming from ceiling area of freezer. Side by side monograms have had problems with drains causing water to back-up into freezer. This causes icicles from ceiling. If that,s the case you have to purchase the kit for this. This is not an easy fix and can take a couple hours, even for a pro who's done it before.
Mar 06, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
Why can't I select cubed ice on my ge monogram fridge, all of the other buttons work fine.
the reason for this problem is a jam of ice inside the ice bin that will not let the knives that crush the cubes,and cant release to let cubes go by uncrushed,remove the ice bin,put the remaining cubes in a bucket,or toss,then check the ice auger in the bin and if theres a build-up of ice melt it with hot water,then thoroughly dry it,then replace this unit into the freezer,but do not use it until its cold again from melting the ice jam,then resume the ice making cycle
Nov 24, 2012 | GE Monogram ZISS420NRSS 42" Built-In...
Need to replace my ZISB42DCA should I go with latest Monogram or a comparable Profile or switch to Kitchenaide. We have had a lot of problems with this one but it came with the house.
I have a 42" GE monogram refrig: ZISB420DMC. Water dispenser has had all kinds of problems and I've already had it fixed once. Same for ice dispenser. I just get ice directly out of the bin rather than have it dispense ice. This refrig also doesn't seem to have very much storage space. I can't even put a large pot in the refrig because of that silly light in the back of the refrigerator. I don't like GE refrigerators anymore. I've seen friends and family buy the Samsung refrigerators. They are really nice and I would get a Samsung. Here in Hawaii, Lowes seemed to have the best prices on the Samsung refrigerators.
Aug 17, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Icemaker water overflows into freezer
the condensate tube is run incorrectly on this model and goes uphill into the area above the refrigerator where there is a condensate pan. This will plug and back up and cause this problem. I have fixed ours several times but it always came back. The last time I bought a new clear plastic tube and reran the condensate out the back of the refrigerator and down through my floor. It's all downhill now and seems to have fixed the problem.
Nov 28, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
GE Monogram refrigerator ZFSB26DRE - ice bin stuck
their has to be a release botton on it look around inside
Jun 06, 2009 | Refrigerators
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Door on Monogram ZIR36N won't pull closed and stay shut
The spring is actually a door closure , are the wheels that the bar closure mechanism goes through and attaches to the spring moving freely? It is entirely possible that a bin in the fridge is keeping the door open.
Nov 14, 2008 | GE ZICS360NMRH Monogram® 36" Built-In...
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
