Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Cannot get channels with antenna - Sony FD Trinitron WEGA KV-32FS120 32" TV
  • Sony Master
  • 5,423 Answers
You need a digital-to-analog converter box to get over the air channels with this TV. The tv only has an NTSC (analog) tuner.
I hope this helps.
Posted on Mar 26, 2011
How can I get my channels set up
On what make and model TV using what system or service
Feb 02, 2018 | Televison & Video
I have a new hdtv antenna and my hdtv gets all the local channels except 8. The direction from my house is 171 and that is also channel 4. I get 4 fine but not 8. what's up?
hello,
There would be weak signal reception at your antenna so it can't get the other channel. So change the antenna direction. If there's no result then increase your antennas hieght means keep your antenna at higher position.
Regards,
Laxman
Sep 28, 2008 | Televison & Video
How to use an antenna box for more channels
Once the antenna is mounted and connected to the TV then you can go into setup menu and do a channel search. You will be prompted to set it up as CABLE or AIR/ANTENNA. Select ANTENNA and it will program all available channels for you.
Apr 19, 2016 | Televison & Video
Do I need an hd convert box to get free channels
If you have a digital tv then no. Go to menu, click on input, click tuner or tv, click antenna, run auto scan for channels. Make sure antenna is hooked up. Digital antenna is preferred but not mandatory. If you're not getting channels move antenna re-scan for channels. Hope this helps!
Jan 29, 2016 | Televison & Video
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
I CAN ONLY RECEIVE 2 OR 3 RADIO CHANNELS ON MY INSIGNIA RECEIVER
Radio tuners receiving AM and FM channels/broadcast MUST have some sort of antenna connection. For local channels a paper clip will work, but for more distant channels, use either a better inside antenna or purchase a outside antenna as needed.
Jan 30, 2013 | Insignia 200W Stereo Receiver
I can't seem to get any digital channels
Before scanning for channel, check to see if the Antenna input is set to Cable or Antenna. If you have rabbit ears or and outside antenna then set it to antenna. If you have cable then set it to cable. Then rescan for channels. If this has already been set then the next step is to check the antenna or cable feed. If possible plug the antenna or cable feed into another TV that is known to be working correctly. If it is capable of receiving digital channels then the problem is likely the Samsungs ATSC tuner and will require service.
If neither TV is getting Digital channels then I will need more info on your antenna setup and where you are located. I am a pro on TV antennas and reception.
Hope this helps
Have a great Day
Mar 31, 2010 | Samsung SyncMaster 2333HD 23 in. LCD TV
GE Model 20GT360 TV and digital antenna problem
Are you connected to a digtal converter or just a digital antenna? If only to an antenna then yes you will most likely pick up one or two low power UHF stations that are still able to broadcast in analog.
Nov 17, 2009 | Televison & Video
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
TV antenna problem
Hi peter9,
It is possible channel bad reception is come from the signal of the tv channel not on your antenna. Just forget channel 10.
Best regards,
Philip
Oct 24, 2007 | Televison & Video
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
