Question about Numark Audio Players & Recorders
Not really a problem. I just want to know the correct setting of the power "slide". It looks like 3 different settings could be available. My question is: Does the smooth part of the slide align with the 120V or the 240V? If I were to reverse them as in plugging it into 120V while it is set for 240V would any damage be done? Thanks----Dan
    Brigadier General:
  • 8,546 Answers
Really? What does your gut and the plain labeling on it t tell you? Those settings are NOT ust suggestions.
The make and model number didn't display. What are they?
Posted on Mar 26, 2011
I have replace the rear brake pads and rotors and slide pins but they still squell really bad had two shops look at it and they cant find anything wrong with it
Stainless steel slipper replacement is mandatory with the service brake pad installation, even if the slippers appear undamaged. Make sure the slippers are correctly positioned with the slipper ends snug against the outboard end of the anchor plate rail. http://www.mazdabg.com/ftp-uploads/Mazda/--Repair%20Instructions--/2001-2007%20Maza%20B23/MAZDA_B23_01-07_Ch9_Brake_Pads.htm
Jul 08, 2015 | 2003 Ford F250 Super Duty Crew Cab
Tip
How to Mute Sounds Using Your Hand on the Samsung Galaxy S4
1) Go to the Settings app. Look for the gear icon and tap it.
2) Tap on the "My device" tab at the top to access your device settings.
3) Scroll down with your finger and tap on "Motions and gestures". It should be under the "Input and control" section.
4) Tap on "Palm motion". If it's not already done, activate the feature by sliding the switch until it turns green, first.
5) Activate the "Mute/Pause" feature by sliding the switch.
  • Optional: If you'd like, you can play the tutorial by tapping the text.
on Jan 10, 2015 | Samsung GALAXY S4
How do I set the timing?
Your timing may have skipped a tooth. This causes the glowing pipe. (Creates pre/post ignition) Pre-ignition leaves a lot of heat vented to the pipe. There are 3 positions that look like tdc. The flywheel has "I" "T" and range marks. This can be confusing. Put the "T" on the mark and you should be correct. If not you can set it up one tooth or down one from that position. Pre-ignition really robs power. Piston fires before TDC (Top Dead Center) and momentarily kind of acts like it's own break. Dial indicators that screwed into the spark plug hole used to tell us how may degrees from top dead center we had to be to line up the flywheel and pin hole for motoplat (Electronic Discharge Ignitition) Same here if you are on the "T Mark" the dial indicator should be about 1 1/2 degrees Before TDC. You may have to play with it a bit to get it right.
Jetting: You have 3 different jets for max power at RPM ranges. If you are loosing power in the middle it's the needle jet on the slide, If your loosing power on the top its the main jet. The middle is just a raising or lowering of the c-clip on the needle inside the slide. Fatter makes it blubber, thinner makes it hot and reduce power.
The main jet is a physical change of size. Pick up a couple of main jets (Over and Under what you have) at a local bike shop and experiment. Altitude and air temp make a huge difference. We used to sometimes go thru a 6 pack of pistons down in mexico before we got it right on the old two stroke Huskys. The stock jet is 115 I think.
Keep the wire tight and WFO,
TF
Jun 02, 2011 | 2002 Yamaha TT-R 225
When I want to set the settings to a different setting, I do not know how to confirm the setting by pressing "ok". I need to know where the "ok" button is.
if you are talking about saving the configuration in your Bios then press F10 and save the config it will ask you to save you press enter.. this should do the trick
If my answer help you then please like/rate , it will really help me.. thanks :-)
Jun 02, 2011 | Computers & Internet
I'm trying to connect my Kindle 3 to my wireless network (Cisco Linksys wireless-N broadband router) and I get the error message "unable to connect to wi-fi network. The password you entered is...
Four reasons come to mind that may prevent you from connecting:
  1. Wi-Fi Passwords are case sensitive. Please check again if you entered the password with proper casing and you did not put any extra white space in front or behind. I know, this sounds annoying, but it is really the most common cause for connection problems.
  2. Give your network a unique SSID. This is the network name that shows up in the list of detected networks. Default names like LINKSYS can be troublesome if a neighbor one block down the street happens to have a router from the same company.
  3. Some routers have a MAC address filter as a security measure, limiting service to devices specifically whitelisted. If your router is set up for this, add your Kindle's MAC address to the list of permitted devices. See your router's configuration under Wireless > Wireless MAC Filter. You can check the MAC of your Kindle from its settings page (press HOME, MENU, select SETTINGS, see paragraph headlined "Device Info".
  4. There are twelve different standards for Wi-Fi transmission collected under the hood IEEE 802.11. The four most dominant transmission modes are called a, b, g and n. They differ in radio frequency, modulation method and data rate. Kindle supports the two standards IEEE 802.11 b and g only, which is not really a problem because all wireless routers I ever encountered support one or both of these, too. However, the Linksys N-series can be set up to use 802.11n exclusively, not allowing for b or g connections. In the router menu Wireless > Basic Wireless Settings (Manual Setup), make sure the network mode is configured as "Mixed".
Please add a comment to this solution if one of these items resolved your problem. If you suffered from a different issue I did not think of, it would be nice to drop me a line, too. Other people will benefit from any experience you made.
Jan 15, 2011 | Amazon Kindle 3 WiFi
It appears that someone has set my type writer to print an alternate charector set. I need to know how to correct this. Lots of words that look like *&UYJH$#@> or similar.
Ckeck the pitch selector slide switch it should be in 10 or 12 not in PS. also slide it up and down a few times they do get dirty.
DickyO
Sep 27, 2010 | Olympia Mastertype 3 Typewriter
TV zoomed in
Look at your remote or On-screen menus for ratio settings. The remote might say zoom or ratio. The menus will probably have it under video and then Aspect Ratio. You'll probably need to hit go through several settings to get to the correct ratio. (some choices are 4:3, 16:9, Full-screen - the best choice depends on the set and the source video)
I hope this helps.
(my remote (slightly different TV) has the zoom just above mute so I hit the wrong button often.)
Apr 24, 2010 | RCA 36V550T 36" TV
Really Sharp/Blue/Ailen looking Pictures
Flash adjustement is also in camera menu and 3 kind of flash setting can be set, auto-flash, forced-flash and slow-flash.
Have nice time.
Jan 06, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
My Magnavox MWR20V6
If unit is still under warranty return it. If unit is still sold at the orginal place of purchase buy another and return the first one stating it wont work and get a refund
1) power source is good? (receptical on the wall or power unit. Locate DVD rec. to another receptical and check Rec. again)
2) power cord going to unit is good, no cuts or melted spots
3) power setting on unit is correct (small red slide type buttong for different country voltage settings)
4) internal fuse, change it even if it doesn't look bad.
5) Weigh the cost of a new one to the repair cost of the old one. If you buy a new one get a good brand RCA is still one of best and longest lasting.
Jul 18, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Konica 7115 copier
not familiar with that machine, but
most of these problems are simple, usually customer errors
1-some have sensors in the bak of the machine where the tray slides in, remove ray and look for paper in the back
2-is there any slides or something to adjust to say it is 8.5x11?
3-switch trays is it recording the correct size- if yes the sensors are ok
4-take alook at the other tray it is probably set for a different size paper, try switching it to letter and see if there is a difference in the way the trays are
4- it could be set wrong in the menu
5-bad sensors
Jun 20, 2008 | Office Equipment & Supplies
91 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
