Question about Zanussi Washing Machines
MY WASHER MODEL ZWF16070W1.....I PUT MY WASHER ON AND WHILE IT WAS WASHING I THINK MY LITTLE GRANDAUGHTER PRESSED SOME BUTTONS BECAUSE THE PAUSE/START BUTTON IS FLASHING I CAN OPEN THE DOOR IV TURNED IT OFF THEN BACK ON AGAIN CHANGED TO A DIFFERENT CYCLE AND STILL ITS FLASHING AND WONT LET ME DO ANYTHING, AND IV LOST MY MANUAL I GOT WITH THE WASHER COULD YOU TELL ME WHAT THIS COULD BE OR HOW I CAN RESET OR RESTART IT
SOURCE: Washer pauses during spin cycle
Check the filter. I have the same problem and I found an string (slip) in the filter. The filter is back of the front pannel (under the door).
Posted on Oct 02, 2008
SOURCE: GE Front load washer WCHVH 6260F
I have the same problem. I found an string(slip) in the filter. The filter is back to the front pannel under the door. Open the plug and chek the filter.
SOURCE: ge front load washer pauses
has orderd a main control board seems easy enough to replace, and hopes this will do it. thanks for the nudge to what i was thinking the problem was
Posted on Oct 12, 2008
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
  • 56 Answers
SOURCE: WASHING MACHINE WON'T RESTART!!
try unpluggin unit for 10 or 15 minutes sometimes a computer will lock up. If this doesnt fix it there is a tech sheet located behind the lower removable panel (3 screws down on your knees and look up a little between the door panel and lower panel. Tech sheet can help you with minor problems but be careful parts are expensive and non-refunadable (electrical parts). always disconnect power before working on unit
Posted on May 30, 2009
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
How to calibrate samsung top load washing machine
there should be another 7 letters/numbers after wa14 maybe the full model number is on the back or in a manual
Sep 19, 2015 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
My he2t kenmore front load washing machine won't power on and there's a clicking noise
Vicki, i think that clicking sound is ok when you press start. TRY THIS.
1. close door securely 2. press power after putting detergent.3 After making your selction for different levels eg hot,warm cold, press START.
usually these buttons are pretty reliable, GL
Jan 12, 2014 | Kenmore Front Load Washer
Have a Kenmore Elite HE3T washer. Put appropriate detergent, fabric softener in, selected NORMAL cycle, spin speed, etc. Just sits there. Pressed START button several times. Nothing. Little cycle lights...
I own a 18-year-old Kenmore front-load washer so I'm not sure this will apply, but here goes... My washer requires me to press and HOLD the start button for a few seconds before it will start. At that point the door will lock and the washer goes through its startup phase. I think that is a "safety feature' to keep from accidentally bumping the button and starting the washer. See if that help. Good luck!
Nov 22, 2017 | Kenmore HE3T Washer
MHWC7500YW0 maytag washer will not start
I have had the same problem but in my case the button above the door latch was not getting fully depressed when the door was closed so the machine did not think it was closed. Temp fix, I used a paper towel folded in 4ths and put just enough inside the door to press in on the button a little further and that worked.
Aug 12, 2013 | Washing Machines
HOW TO CLEAR THE LOC CODE ON MY FRIGIDAIRE WASHER
This means that the child lock (control lock) feature is active. There will be a button (or pair of buttons) depending on the model that you need to press and hold to toggle off the feature. If it is a single button, there will be a tiny padlock icon on the button. If you need to press and hold two buttons, the padlock symbol will be in a line indicating both buttons.
A likely combination is the Select and Option buttons. These should be held together for 10+ seconds. (This is the combination for some Affinity washers.)
If this doesn't work and you can't see a lock icon, please add a comment with the model number of your washer. I'll be glad to check what the combination is for your washer. The model number is usually on a plaque on the rim of the door for front loading washers or at the back at the top of the drum for a top loading washer.
I hope this helps.
(the control lock prevents someone from accidentally changing the cycle or a child starting a wash cycle with the cat or another child in the unit)
Nov 23, 2011 | Frigidaire 14 Cycle Tumble Action Washer
What is the L5 red light that appears when I press start for wash
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
'test' displayed on washing machine
After pressing different buttons and waiting 10 to 15 seconds after turning the power off, I have finally found the solution.
When you have pressed the "Start/Cancel" button to start your wash programme the LCD shows "test".
You must then press the "Start/Cancel" button which will give you the normal temperature and washing time and then importantly you must depress both the "Start/Cancel" button with the "On/Off" button which will give you a different LCD message and then it will automatically resets itself.
ALL THE BEST!
Jul 31, 2008 | Hotpoint Aquarius WD640 Front Load...
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
Samsung washer P801 sticks/stops while tumbling. Have cleaned debris filter. Please help, thanks.
i got the same problem....i think it because the washer spin too fast and the washer start to vibrate...press on the spin button until its show 4...(its the rpm 4=400 , 6=600 and 8=800)
after the washer gonna less vibrate and your cycle gonna work well...sorry for my english
May 04, 2008 | Washing Machines
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
