Question about Canon Speedlite 430EX TTL Flash
MY FLASH FELL DOWN AND THE HOT SHOE WIRING CAME OUT...THERE ARE 6 WIRES INCLUDING BLACK..I DO NOT KNOW ON WHICH POINT TO SOILDER WHICH WIRE ON THE HOT SHOE...CAN YOU SEND ME A DIAGRAM..THANKS
  • 902 Answers
Please let me know if this helped
Posted on Mar 26, 2011
Wiring Diagram
Are you replacing 3-way switch?
EJ351 is single pole
You have to test these wires to see what each one does.
Two of the black-white wires will be Hot from breaker box... other wires will go to lights or forward to another switch or outlet box
The black hot wire will connect to one of the wires on timer....
The hot wire will also feed into the black wires that go forward to other switches and outlet boxes.
http://waterheatertimer.org/Basic-house-wiring.html
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-wire-timers.html
Gene
Water Heater Timers Save Money
Jun 11, 2015 | Hardware & Accessories
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
I have a intermatic ET1125C I have 30 amp fused load coming in,how EXACTLY do I wire it in and TWO independent outs for load 1 load 2 ? The diagrams are confusing I need to know color wire to #1-6 on the...
10-22-12
Intermatic ET1125 240Volt, two independent circuit Wiring absolutely shows on following link: Wire colors can vary. 240Volt line can be black-white, or red-white, or black-black. Non-code wiring can be white-white.
http://waterheatertimer.org/How-to-wire-Intermatic-ET-series-timer.html#1125
I have no idea what color wires you have. Or if circuit tests for 240V.
Include a photograph of your wiring, and list showing voltage on each wire, and color of each wire, and description where each wire comes from.
You should have two Hot wires L1 L2 coming from 30 amp breaker.
And 2 wires going to each Load (light, fan, motor).
Wire size should be at least 10 gauge.
Turn power ON, stand on dry boards, tape tester leads to wood sticks, and test each wire to bare ground.
240Volt circuit will have two hot wires.
Oct 22, 2012 | Hardware & Accessories
I have a dead short somewhere in the wiring for 6 recessed ceiling lights. How do I trouble shoot this to find the short
Test each light separately.
Black Hot wire arrives at one screw on the switch. The Hot black wire going to Lights connects to other screw on the switch.
The White Neutral that completes the circuit to lights is connected with other white wires that are covered with wire nut pushed to back of box.
Open up light#1, and the Hot and Neutral arrive from switch box.
The Hot and Neutral going to lights#2-6 are also located inside light#1 box.
Check each wire for signs of high heat and burning. Check each wire if the insulation has been sliced, or cut short, or if copper is visible because wire nut does not cover wires correctly
http://waterheatertimer.org/How-to-select-right-wire-nut.html
Disconnect Hot and Neutral going to lights#2-6, so switch is only turning on light#1.
Test if there is a short when turning switch ON.
Then repeat step, so switch turns on light#1 and light#2, but light#3-6 are disconnected.
May 31, 2012 | Electrical Supplies
My xti fell with the 430 ex II attached now it
The hot shoe was bent slightly causing the flash contacts to not touch those of the camera. By using a socket from a socket wrench set, place it over the grids of the hot shoe and tap firmly with a hammer to straighten it.
Jan 02, 2010 | Canon Speedlite 430EX TTL Flash
Vivitar 285 HV won't fire
If you know basic soldering, Open the old hot shoe from base
(4 screws).Note down the position of the wires.
Try to fire the flash with shorting two trigger wires,most ly it will fire.
If the springy contact is adjustable do it.If it is not repairable, you can get metal hot shoe from ebay easily.
Caution: metal hot shoe will short circuit 4 TTL contacts (on digital camera) ,so you need to put cello tape at bottom of hot shoe with only center hole.
Hope this solves.
May 12, 2009 | Vivitar 285HV Flash
Vivitar 285 flash and metal hot shoe
The red wire connects to the center contact and the black connects to the outside/ground connector. The other wires are to be isolated and insulated from everything else, tape those up and put them out of the way.
Jan 30, 2009 | Vivitar 285HV Flash
Sunpak 383 problem
Try to trigger it by shorting Center of shoe mount and the side terminal with a small wire.If it is firing the flash is ok.
If not there is open connection in the sync jack ,due to repeated inserting of sync chord.The springy part inside is not going back to its normal position.
You can fix it your self by opening it(adapter only)
.If you are new to this take a photo of the wiring immediately after opening the shoe adapter to see the position if any wire breaks later on.
Do not give up .383 is great flash
Nov 05, 2008 | Sunpak 383 Super Flash
Ricoh KR10 Super
Try a camera shop that still repairs obsolete camera's, if you have all the parts it can be fixed or replaced ( top cover ) with a good used one . If your KR10 has a flash socket on the front of the camera buy a flash bar and use that. Be sure the loose wire from the hot shoe is not touching anything.
Oct 08, 2008 | Photography
Gemini djm-1 gooseneck microphone repair question
No problem! 2=RED 3=Black 1=White The wire without a color is ground. It can be soldered to pin 1 if necessary. Hope this helps.
Nov 05, 2006 | Gemini Sound Products DJM-1 Microphone
Canon Speedlite 430EX TTL Flash Logo
198 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
