Question about Vornado Circulating Fan
Can't remove the front piece to clean the blades.
  • 51 Answers
But a butter knife in the slot and peel it off
Posted on Mar 26, 2011
How do you remove the clear plastic cover on the crisper drawer of a Samsung Refrigerator Model RF4287HARS
Yes, the clear plastic front of the crisper drawer can be removed for cleaning. Using a thin-bladed, flat-head screwdriver, pry out at the clear plastic slot at the top outside of the drawer, where the clear front piece meets the tab of the white handle piece. Pry out just enough to get the blade under the slot, and then pry inward at the white tab to release the clear front piece at the top of the drawer. Repeat this procedure on the opposite side, so that the plastic front piece is free at the top of the drawer. Next, turn the drawer over on a counter and work the blade of th screwdriver under the tabs at the bottom of the front plastic piece. These should release easily. Notice the bottom edge has three slots and two sections that are interleaved with the bottom of the drawer. Once you have all three pieces separated, the while u-shaped handle piece, the plastic front panel, and the drawer itself, you can clean and dry them easily. To reassemble, first snap the while handle into place on the drawer, by lining up the top of the drawer to the while handle part first. The top of the handle fits over two plastic extensions on th top of the drawer, then swings down to cover the front sides of the drawer. Then reattach the bottom of the front plastic panel to the bottom of the drawer, interleaving the overlapping parts and snapping the tabs in place. Then snap the top of the front panel over the white handle at the top of the drawer, and you are done!
Dec 04, 2014 | Samsung Refrigerators
My minolta ep4000 giving black shad on one side of the paper
Usually caused by either dirty optics or a bad drum cleaning blade. If you lighten the exposure control to make the copy lighter, does the background go away? If so the the optics need to be cleaned. You just have to remove the large original glass by removing the 2 screws at the front and back side of the plastic guide that is at the left edge of the glass. Be careful not to lose the springs that are under the guide. Lift out the glass. With the POWER OFF on the copier just pull out the scanner bar that moves back and forth. There is one mirror on the first piece that slides out and 2 mirrors on the second part. Once cleaned just re-install everything and test.
You can do a test for the drum cleaning blade by running 10 copies of something. If the shaded area of the copy gets worse so that the last copy out is worse than the first copy out it is most likely the drum cleaning blade. Drum cleaning blades are like $30.00
Good Luck and Thank You for using Fixya.
Sep 16, 2010 | Minolta EP4000/5000 CS/PRO Copier
How to remove the grill to clean the Vornado fan?
You cannot with the clips... its impossible.. wound up breaking the clips... and STILL cannot get grill off. Don't ever by a Vornado if you cannot clean it!
May 10, 2010 | Vornado Circulating Fan
How to clean blades and/or how to remove fan cover for cleaning
I am certainly not an expert on this field; yet i have done this my self and this is what i did:
MOst fans have clips.
check where the from and back pieces attach. there should be several clips there remove them and voila.
if not there possibly check the centre pice of fan this may have a screw that holds front and back pieces together as well.
Pllease note you will also have to remove the legs from the side of fan as well. if the pic is the same one you have
Hope this helps
Roty:)
Never argue with an idiot
They bring you down to their level
Then they pummel you with experience
Aug 20, 2009 | Patton Electric U2-20 Box Fan
Printing a blue streak
your ink have been spoiled re-install the cadrige that you can print
Jul 11, 2009 | Samsung CLP 300 Laser Printer
Blade lock on Craftsman 10 amp recip
The guide foot comes completely out by wiggling and pulling a little harder than you would think. It is held in place by friction in addition to the two screws. Once the guide foot is removed, remove the front metal support piece by prying it out of the groove in the rubber boot. You can then access the pin and blade release lever. Make sure the return spring is in place on the rear side of the blade lock latch.
Apr 11, 2009 | Craftsman 8.0 amp Reciprocating Saw
Unable to remove!
The plug you described is supposed to be atached to the piece you have removed.
You will have to tease the plug out with a small flat blade screwdriver.
Hope this helps.
Jan 21, 2009 | Bosch Classixx WFL 2066 Front Load Washer
3F blade, took the blade out to clean, can't get back together
That's probably the blade guide. It goes on the "spring"; the piece that holds the cutting blades together.
The blade won't work without it.
Oct 29, 2008 | Oster 76076-010 Hair Trimmer
How do I replace the Cleaning Brush for the drum?????
why in the world are you replaceing the brush? In 25 years of copiers, i,ve never had to replce a brush. If its streaking on the copy, its the blade thats bad. only reason to replace a brush is if its broke,cause of a clog. just vacumm it out.
Jan 31, 2008 | Panasonic FP-7735 Black and White Copier
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Vornado Circulating Fan Logo
101 people viewed this question
Top Vornado Dryers Experts
Steve
Ian Summerfield
Ian Summerfield
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
