How can i pull out my memory stick t of my cer laptop
    Sergeant:
  • 236 Answers
The memory card is ejected by just pressing it in until you hear a faint click then letting go. The card will pop out by itself about 1/8 inch and you can just grab it and easily pull it out the rest of the way. A word of caution. If you have written anything to the memory card from your laptop, you should not eject the card until you left-click on the tool bar icon "Safely Remove Hardware and Eject Media" then click on the pop-up list item to "Eject Mass Storage Device" which will reply with a "Safe to remove hardware" message. This insures that the contents of the buffer used for writing the memory card or stick has been completely written to the memory card or stick before it is removed. Because the card or stick is much slower to write than it is to read from the laptop's hard disk, there will always be a chance for an incomplete write causing card or stick corruption unless the "Safely Remove Hardware and Eject Media" is used.
Posted on Mar 26, 2011
How to reinstall authourity certificates of nokia
1. Create a New Folder on your desktop and call it whatever you like.
2. Open notepad on your computer.
3. Copy the text below into the Notpad file. (I got this from some website as they were using it for smething else but it does work so thanks to them or thanks to you if this is yours)<?xml version="1.0"?>
<!DOCTYPE html PUBLIC "-//WAPFORUM//DTD XHTML Mobile 1.0//EN" "http://www.wapforum.org/DTD/xhtml-mobile10.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>Install root CA</title>
</head>
<body>
<p>
<a href="der1.cer">Download a CA Cert1</a>
<a href="der2.cer">Download a CA Cert2</a>
<a href="der3.cer">Download a CA Cert3</a>
<a href="der4.cer">Download a CA Cert4</a>
<a href="der5.cer">Download a CA Cert5</a>
<a href="der6.cer">Download a CA Cert6</a>
<a href="der7.cer">Download a CA Cert7</a>
<a href="der8.cer">Download a CA Cert8</a>
<a href="der9.cer">Download a CA Cert9</a>
<a href="der10.cer">Download a CA Cert10</a>
<a href="der11.cer">Download a CA Cert11</a>
</p>
</body>
</html>
4. Save the Notpad file as type ALL FILES but when naming it just call it cert.html and save it to the folder you created on your desktop earlier.
5. Now downlaod the Root Certificates you need to the same folder on your Desktop.
6. When saving the first Certificate to the folder call it der1 ((make sure not to take out the file extension eg .cer))then the second der2, third der3 and so on and so on till you get to der11. (Dont worry this will not rename the certificate when it installs on your phone.)Example of what the files in your Desktop folder should be called der1.cer, der2.cer etc etc.
7. Now transfer the whole folder from your Desktop to your Mobile phone. (I did this by using Nokia PC Suite.)8. When the folder with the certificates and hmtl we made have been transfered to you phone navigate using your phone to that folder.
9. Go into the folder and open the cert.html file. (Your browser will now open a page with 11 download links available)10. Now all you have to do is click on each link and accept each certificate remembering to save and they will install on your phone. (On my 6500 Classic i can check this by Navigating through my phone to Menu>Settings>Security>Authority Certificates)Notes:- Some errors you may receive when trying to download the certificates through your phone browser may be Already Exists, Expired Certificate and the most annoying is Corrupted Certificate.
Already Exists - Shouldt allow you to save (DO NOT SAVE IF IT ALLOWS YOU)
Expired Certificate - (DO NOT SAVE)
Corrupted Certificate - Install the certificate on your computer first, then go to Tools>Internet Options>Content>Certificates.
(save the certificate to other people tab) Browse for the certificate you installed then export it in DER format to the Desktop Folder you created then start process over again to get it onto your phone.
Remember to delete any certificates as you go that you have already installed so you dont get mixed up
Oct 21, 2014 | Nokia Cell Phones
Laptop beeps4 times but doesn't come on the monitor or start-up. ights on front of laptop and start button come on but nothing else happens.
In most cases this means bad memory stick. If you are able to, flip over the laptop, find the panel that has the memory under it, unscrew the screw(s) to get the panel off, and pull out the top stick of memory. Flip the laptop back over and power it on. If it works fine again, then that stick was the problem, and you can go buy a replacement and install it back into that slot. If that doesn't fix the issue, turn it off, flip it over, pull the other stick of memory out and put the first stick into that slot. Flip it back upright and turn on again. If that fixes the issue, then the second stick of memory is bad and you can just replace it as well. If neither of those fix the issue please reply on here and we can do further diagnostics.
Jun 30, 2011 | Toshiba Satellite M55-S135 Notebook
Memory stick is stuck in my compaq laptop. How do I get it out?
You can use a tweezer to pull out the memory stick.
May 19, 2010 | HP Compaq nc6320 Notebook
Laptop freezes. Turn off. Wait. Turn on. 3 beeps. Small light on lid lock lights for about 12 secs then flashes 4 times. Cycle repeated.......No screen picture.
The most common cause of the '3 beep issue' is memory or RAM failure. Generally, only one memory stick goes bad (you only need one stick for your computer to work) so here's what you do:
Step 1: make sure the MacBook is off then remove ONLY 1 memory stick. After you remove it, place the battery back in the battery bay then try powering it on. If it works, you'll know that memory stick is failing and you can buy a new one fairly cheap.
Step 2: If step 1 didn't solve your issue, replace the 1st memory stick and pull out the 2nd. Replace your battery in the battery bay then power up. Usually one of the memory modules is bad. If neither step works for you, try getting a compatible memory stick that you know is working just so you can rule out both memory sticks being faulty. Here is my email adress: i_Patch,securepath@live.com Don't forget to vote if this helps you and good luck! Contact me if you have further questions.
Apr 18, 2010 | Computers & Internet
Having a problem installing new memory. I'm not
Make sure to open up the RAM compartment and pull out the memory sticks. Once you pull out the memory sticks, be careful to replace the memory sticks properly as the previous memory sticks were located before you removed them. If you are unable to do that, then you may need to take it into a shop for a professional to place the sticks in properly.
Nov 19, 2009 | Fujitsu LifeBook N6100 Notebook
Lg viewty screen smashed would like to connect it to a computer to get the data off but cant see what im doin My LG Viewty was in my pocket and all of a sudden when I took it out i was suprised to see a...
Now if only your screen is damaged then you can make an connection via USB.
conect your phone with the usb port.
start in windows the program EFS MEDIA BUILDER by AKOM1976
you have to see that the folder already exist on your phone
LGAPP now make a swich. Rename LGAPP >>> TOTO.
Now the hidden files will apear in the EFS exporer.
Now you can backup the folder TOTO to your pc. Choose a
folder where you want to place TOTO. Stay on TOTO click right
and choose read. When its finished. The folder written to your pc.
So this you can do vice versa to Fix the backup of the files.
after that reset automatic by the EFS explorer the phone start up
normaly. A new screen you have to find it at google I am sure there
will be a loal dealer where you can buy new parts for LG KU990.
The files you need to see on your phone with EFS explorer looks like this:
LGAPP
LGAPPCommon
LGAPPDRM
LGAPPDRMCERT
LGAPPDRMCERTCERT
LGAPPDRMCERTCERTdevelopcert.cer
LGAPPDRMCERTCERTdevicecacert.cer
LGAPPDRMCERTCERTdevicecert.cer
LGAPPDRMCERTCERTdevicepkey.cer
LGAPPDRMCERTCERT ootcert.cer
LGAPPDRMCERTcmla
LGAPPDRMCERTcmladevicecacert.cer
LGAPPDRMCERTcmladevicecert.cer
LGAPPDRMCERTcmladevicepkey.cer
LGAPPDRMCERTcmla ootcert.cer
LGAPPDRMDPRO
LGAPPDRMDRMCERTTYPE.TXT
LGAPPDRMID
LGAPPDRMIDSYS
LGAPPDRMISAMDB
LGAPPDRMISAMDBCertDB.bin
LGAPPDRMISAMDBCertDBKey_CTYPE.bin
Etc.
[ File Renamed ] LGAPP->TOTO
These files are on the pc:
TOTO
TOTOCommon
TOTODRM
TOTODRMCERT
TOTODRMCERTCERT
TOTODRMCERTCERTdevelopcert.cer
TOTODRMCERTCERTdevicecacert.cer
TOTODRMCERTCERTdevicecert.cer
TOTODRMCERTCERTdevicepkey.cer
TOTODRMCERTCERT ootcert.cer
TOTODRMCERTcmla
TOTODRMCERTcmladevicecacert.cer
TOTODRMCERTcmladevicecert.cer
TOTODRMCERTcmladevicepkey.cer
TOTODRMCERTcmla ootcert.cer
TOTODRMDPRO
TOTODRMDRMCERTTYPE.TXT
TOTODRMID
TOTODRMIDSYS
TOTODRMISAMDB
TOTODRMISAMDBCertDB.bin
TOTODRMISAMDBCertDBKey_CTYPE.bin
TOTODRMISAMDBDCtxDB.bin
TOTODRMISAMDBDCtxDBKey_DID.bin
Etc.
and its fine to have these as my back up.
If your folder LGAPP on the fone is emty don't worry write the files from your pc to the phone Make a folder named TOTO.
and write all the files include the foleders in to TOTO at your phone.
When you fineshed. Rename LGAPP >> XLGAPP
Rename TOTO >> LGAPP.
Delete the folder XLGAPP.
Refresh and disconnect and you will see the phone startsup in
a normal mode. As you can see I delete th folder LGAPP that was empty.4f0b046.png
Now I read the folder that is back it up on my pc to the phone.
Now when its finished I renane that folder to LGAPP.
When yo finished diconnect the phone by clicking disconnect.
So the phone start automatical again and now its running in norma
mode asual. I hope this will work for you.
May 06, 2009 | LG KU990 Viewty
HOW TO FIX YELLOW REFRESHING SCREEN AS MY LOCAL MOBILE PHONE SHOP HAS FAILED TO BE ABLE TO RE FLASH THE FIRM WARE PLEASE HELP
a2ee4a7.gif LG_Authority
start in windows the program EFS MEDIA BUILDER by AKOM1976.
select connecton and after that you choose efs explorer select connection.
Now you see the files on your phone
maye there is a folder named as TOTO
be sure that this folder is on your phone!!!
If it does delete the folder named as LGAPP
after that rename the folder named TOTO to LGAPP
richt click and choose refresh.
now exit the efs program.
Turn your phone off and then after a few seconds on
the phone will startup normaly as always and its normal asual.
I hope this will work or you have to back up with the LGMDP euro
an after that choose restore and choose the image file *.nv2
This will work!
you can try a software update at http://nl.lgmobile.com/web/web.product.manualSoftwareRF.laf
This software update is at your own risk.
Choose your model of your mobile phone and download it.
Fallow the instructions by the software update be patience
if you don't see anything it take a few moments.
Comment posted on May 04, 2009 No you have to see that the folder already exist on your phone
LGAPP and a nother folder TOTO if the phone starts up and you didn't switch the folder it make a new folder LGAPP without the programs so all the folders in the folder LGAPP are emty.
So thats why you have to be sure that the folder TOTO is already exist on your phone.
And if you have a backup of the folder TOTO you can check if the maps are empty or not.
These files have to be in the map toto on your pc.
These are the file names that is logged by EFS explorer, you can see the folder names and the files that are in the folder map exist
Check if these file are located in the folders of your phone if not
delete the emty folder LGAPP and make a new folder named TOTO open that folder.
Now read the files that is on your pc in the map TOTO.
This folder have to be the files in it and doesn't suppose to be empty.
LGAPP
LGAPPCommon
LGAPPDRM
LGAPPDRMCERT
LGAPPDRMCERTCERT
LGAPPDRMCERTcmla
LGAPPDRMDPRO
LGAPPDRMID
LGAPPDRMIDSYS
LGAPPDRMISAMDB
Etc.
TOTO
TOTOCommon
TOTODRM
TOTODRMCERT
TOTODRMCERTCERT
TOTODRMCERTcmla
TOTODRMDPRO
TOTODRMID
TOTODRMIDSYS
TOTODRMISAMDB
Etc.
Wach videos without beeing blurry?
cer Aspire 5315 PC Notebook acer laptop model no icl50 activate windows product key
Aug 27, 2008 | Acer Aspire 5315 Notebook
Memory stick stuck
Some tape can help that! I had the same problem with a Memory Stick PRO Duo. You can see photos of the fix here:
http://lloydandlauren.com/2008/11/21/getting-a-memory-stick-pro-duo-out-of-an-acer-aspire-one
May 25, 2008 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
