Question about Emerson Microwave Ovens
My Emerson microwave, model # MW8997W, won't start. LED shows data (elapsing time) but when I press START, nothing happens. I unplugged and plugged in again; no change.
MicrowaveSvc
  • 9098 Answers
SOURCE: I have an Emerson Microwave
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
When the microwave oven is plugged into an outlet,
the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
the oven is cooking or defrosting.
You can actually download your owner's manual here
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 11, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: emerson mwg9111sl microwave oven won't turn off unless unplugged
I would suspect a bad door switch or mount or a problem on the control panel.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020.
Get help locating a local authorized servicer at 1-800-695-0098.
Posted on Nov 24, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave key pad stopped working
Okay, thank you for that.
You have a failed membrane keypad, but on this model, it is not available separately.
You would need to order the control panel assembly, part # WB56X10817, which you can get here for far less than GE charges.
It costs more than just a membrane would, but is much simpler to replace.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you remove your circuit board from the old frame and install it in the new frame.
Posted on Jan 03, 2009
  • 3 Answers
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Posted on Apr 29, 2009
  • 4 Answers
SOURCE: KitchenAid built in microwave model #KHMS155LSS-4.
Whirlpool is conducting a safety recall on the Kitchenaid KHMS155L series (and similar models under other brand names) that display the F2 code or have been observed self-starting. Other symptoms may be additional codes or unintelligible info being displayed, and failure to execute the command entered into the control pad. To obtain free replacement of the control panel, call Ava at Whirlpool: 1-866-640-7146, extension 6337. She will want your complete model and serial numbers and a phone number and address where you can be reached. She will arrange for A & E Factory Service to contact you to set up an appointment to come out and replace the control panel at no cost to you.
Posted on Nov 02, 2010
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jun 14, 2017 | GE Microwave Ovens
I have an Emerson MW8168B 1100 watt Microwave. Start Button Problem.
the pads are touchy its probably been white knuckled too long
Apr 03, 2013 | Emerson MW8168B Microwave Oven
Bosch hmt8656gb microwave doesn't always start
The problem is in the keypad control board and usually means it must be replaced to fix the problem, and the part alone is expensive.
Jun 02, 2012 | Bosch HMT8656GB Microwave Oven
Plugged in my Emerson MW7300W. Light works, won't cook
there is a thermal (white ceramic) fuse located right under the cover on the top of your microwave replace it.
an electronics part store should stock it.
Feb 01, 2010 | Emerson MW8777W Microwave Oven
Emerson model MW8997w sparks when turned.
I bought a piece of mica from an appliance repair business and cut out a new piece. Microwave is working fine. Apparently food carbonizes on the mica and causes the microwave to spark. If anyone has this problem, call around and find a repair shop that buys mica by the sheet, rather than paying for a piece from the manufacturer.
Jan 09, 2009 | Emerson MW8987B/W Microwave Oven
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
SETTING THE CLOCK
Mar 10, 2008 | Microwave Ovens
Start
How many month the oven if cover by the guarantee report to Emerson call on line .
The only problem occure this oven fuse , door switch , diode .magnetron.
Jan 02, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
