Question about Kenmore 22422 Top Load Washer
I have a Kenmore 90 series mod# 110.26954691 it will go through the cycle but it is hardly agitate or spin. The clothes still has water in them when it is completed. Also, what is an inlet hose?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 112 Answers
This could be caused by a couple of things. The most likely is that the clutch on the drive system is failing - the other cause could be a slipping belt from the drive motor, though that would be rather noisy (just as a slipping belt on a car is noisy).
I recommend using a qualified repair service for this.
Posted on Sep 22, 2011
2 Suggested Answers
Jahn27
  • 1554 Answers
SOURCE: kenmore 90 series spins less than full speed,
The click is most likely coming form the motor control unit(MCU) and the dimming of the lights are caused by the starting current of the motor. It means the motor is being started and restarted repeatedly as the clicks indicates. It is a natural electrical phenomenon for lights to get dim when a motor on the same circuit starts. This is because the motor acts as "short circuit" at start-up drawing almost all current in the circuit.
Unplug the machine or flip the breaker off then remove the rear access panel to have a close view of the motor and the motor control unit on the bottom side. The MCU is where the motor connects to. Plug the machine in and run a spin cycle. Check closely where the clicks are coming from and for any sign of electrical damage such as burning smell and the like. Replace the MCU if it is where the clicks are coming and check also the motor winding resistance. You'll find a Tech Sheet inside the machine.
Please accept the solution should you find it helpful and/or informative. You don't have to rate in order to post comments or additional information. You can still communicate with the expert without rating should you need further advice regarding the issue stated her
Posted on Sep 10, 2011
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series fills with water but would not agitate or spin
You have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling". I probably replace 5 a week because these little guys break because of 2 reasons that i've found.
1) The break mechanism is too dry and causing the basket to stop at a holt, which puts a lot of strain on the coupler.
2) They break because of over-loading. I don't think you're over-loading though because it was find for 5 straight years.
Good luck to you. The repair is kind of hard to do on your own for the first time, so I would call an authorized technician. It will run you anywhere between $90 to $120 at most.
Best of luck!
Jul 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series slow spin
You need a repairperson. It is probably a belt or a switch problem.
Jul 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
