Question about Hitachi Televison & Video
The blue on the color is not lined up. We cant get it to move even on the auto focus
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
The "Magic Focus" is really a auto convergence that tries to adjust at about 16 points on the screen; if it will not correct the convergence the two convergence IC chips need to be replaced along with any bad resistors around them (total parts cost on EBAY would be under $25.00).
The chips are black and will have a number in white on them like STK-392-110 or a similar number, they are mounted on large metal heat sinks or a single sink with fins.
Whenever convergence will not adjust one of the chips is bad (always replace both at same time).
If you have questions or need further assistance let me know with a comment here.
SD TECH
Posted on Mar 26, 2011
It is like looking at 3d in all three colors. i
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 30, 2010 | RCA D52W19 52" Rear Projection Television
I pressed the auto convergence button now it looks like its in 3d
  • Screen looks 3D
Oct 16, 2009 | Zenith R57W46 57" Rear Projection...
Tv out of focus
  • Screen looks 3D
Aug 03, 2009 | Akai PT4298HD Rear Projection Television
Blue color out of focuse
Replace both of the STK392-110 Convergence ICs. You can get them at the following link with free instructions on how to replace them.
http://servicemanuals.vstore.ca/
May 22, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Auto focus and manual focus(red+will not move left
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 17, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
I have a Nikon D200 camera. It's now 2 years old and I'm having difficulty with the auto focus. The camera focuses but it comes in and out and I have to depress the shutter several times to get it clear....
the auto focus works on the basis of contrast. If you aim your chosen auto focus square at an item that fills that square with only one color or shade of color light a blank wall or a solid blue sky the camera can't focus because it is trying to compare the contrast in order to focus the camera. try to make sure that you choose an item with contrast to aim your auto focus square on like someones eye and part of their cheek so the camera can see somre contrast to evaluate then focus. Obviously you depress your shutter half way to activate the auto focus let the camera do its thing keeping the shutter half way depressed move your field of vision to where you want it then fully depress the shutter to take the picture. the camera relys on seeing some contrast within your autofocus square in order to auto focus
Jan 14, 2009 | Nikon D200 Body Only Digital Camera
PICTURE HAS DISTORTED HORIZONTAL LINE IN CENTER OF SCREEN.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 03, 2009 | Toshiba 55H70 55" Rear Projection...
Sony KP-WS500 bowed picture and colors seperated and out of focus
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Nov 22, 2008 | Sony KP-51WS500 51" Rear Projection...
Magic focus
you need to replace the convergence Ics thats why youre unable to align the blue. If youd like me to post a link where you can get replacement ICs as well as free tech support and instructions let me know and I will post the link.
Apr 08, 2008 | Hitachi 51F500 51" Rear Projection...
42H81 touch focus error
check for bad solder connections on the connvergence ics if that dont fix it then replace them
Nov 01, 2007 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
