Question about Ignition System for Mercedes-Benz B-Class
Hi: my b200 wont start if it has been running for a while, no alert messages, if it's cold it starts up fine, just had oil change, filter etc. Could this be the cause, I know in the MB workshop they will say it's the whole ignition sistem and charge me $2000, but may be something different. Thanks
    Genius:
  • 1,066 Answers
Its your fuel injector system, and it will be expensive. look for a junked model that you can salvage from.
Posted on Mar 26, 2011
2002 Ford Mustang GT, CAR STARTS UP FINE WHEN COLD. Hard to start when warm No Check Engine lights come on.
Think about how the vehicle is acting. Starts fine when cold, hard to start when warm. In these computer operated systems, the computer runs everything. Starts fine when cold: the computer has the engine in cold start mode putting more fuel in till it warms up. Temperature sending unit in the manifold sends a message to the computer telling it to stop the cold start mode and it stops dumping excess fuel into the cylinders and it runs fine. IF, mind you, IF the temperature sending unit is faulty, it's not telling the computer to stop the cold start mode and is flooding the engine with fuel cause it's sill in cold start mode. This is my take away on your situation and the temp sending unit is something to check to be sure it's functional. Check it out. I hope this WAS the answer to your problem my friend. It's typical. Luck to'ya Bro.
Jun 06, 2017 | Ford Cars & Trucks
What does a loud clicking noise indicate that seems to quiet as the engine warms when cold starting a fuel injected dodge pickup indicate
The oil may be to thick or a partially blocked pick up (check the sump for a big dent) Lack of oil changes will also cause it as the oil starts turning to sludge & partially blocking things. As the oil warms it gets thinner allowing it to pass around the motor easier. I DON'T recomend the oil flushes. The motor may have to be partially disasembled eg: sump off to clean pickup or tappet cover off to replace lifters etc... Start by changeing the oil & filter with the recomended grade.
Jun 27, 2012 | 2005 Dodge Dakota
91 diesel trouble starting chevy suburban
I would be more suspicious of the fuel system. Have you changed the filters lately? Do you have a 6.2 or a 6.5?
Aug 10, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Will start up run for awhile then stall and wont restart
Hello, I would start with a general tune up. Spark plugs and wires, Fuel Filter, Oil Change and Filter Change, Air Filter Change, Some injector cleaner would not hurt eirther. Be sure to lubricate your high mileage car and also use a farily good oil for your motor as well. The run for awhile problem sounds like bad spark plugs. I would change your spark plugs, wires, distributor cap, and rotarty button.
May 20, 2009 | 1993 Honda Accord
No cold start
in cold tems you need to make sure that you use a block wormer it will help alot
Feb 02, 2009 | 1996 Ford F250 Crew Cab
Starts fine when cold, after running dies on idle then wont start
Sounds like the fuel filter is dirty and needing to be changed. It's cheap and easy to swap out.
Jan 12, 2009 | 2002 Land Rover Discovery Series II
Ignition System for Mercedes-Benz B-Class Logo
453 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
