Question about CTX S551A (Black) 15" LCD Monitor
I want to increase resolution 1024*768 to 1280*1080. But message come signal out of range. How can i fix that. Help. Thanks in advance
    Guru:
  • 433 Answers
Monitor didn't support this resolution
Posted on Mar 26, 2011
Www helpouts google com
Try resetting your graphic to default and reset the monitor to factory default.
May 04, 2014 | Televison & Video
Monitor's resolution need to be increased, how?
Hi
You don't say which operating system you are using.
The monitor resolves images across a fixed range of resolutions and resfresh rates.
It is the resolution of the graphics card or graphics adapter that can be changed, not that of the monitor.
Right click on empty space on your desktop > properties > settings.
Left click and hold on the slider and slide to the right in stages.
Each resolution change offers you a test page to accept or reject.
When satisfied Apply > Yes > Ok.
To reset the Refresh Rate:
Properties > settings > Advanced > Refresh Rate.
Then restart your computer.
Be careful not to exceed the resolution/refresh rate range of your monitor (1280 x 1024) / 75.0 Hz because if you do, when you restart the computer, the monitor will be unable to resolve the image and you will get a blank screen and/or an Out Of Range error message.
An out of range problem might only be resolved by using a different monitor to reset the resolution back to within the range of the preferred monitor.
Hope this helps
Aug 22, 2011 | Northgate MONNG7NSS 17" Flat Panel LCD...
My samsung 22" lcd tv
The only thing that comes to mind, as you haven't said if you have had it working on it or not, is the fact that it is not capable of handling the resolution you have got set on your computer. to fix this set your computer to a low resolution, connect to your TV and see if it works. If it does increase your resolution setting until it stops working. (if you get it wrong it will revert to the setting before). Hope this helps.
Mar 04, 2011 | Computers & Internet
How can I fix an "Out of Range" display?
Please reduce display resolution of computer/ laptop to solve "out of range" error because laptop is producing high resolution video signal and monitor hardware is unable to show that much higher display resolution so causing that error message.
Let me know what Windows version (XP, Vista, 7) is running in laptop to provide you more info or check Display Properties in control panel and change it to lower resolution to get picture in monitor.
Thanks.
Feb 09, 2011 | Westinghouse L1975NW Monitor
Message of Unsupported video signal after attaching laptop to TV.
it sounds like the resolution the laptop is trying to send is not one of the resolutions that the television can display. TVs can display a range of resolutions, so try changing the laptop resolution, either increasing it (make the pixels smaller) or lower the resolution, try a variety of resolutions, one should work.
Jul 11, 2010 | Dell Latitude D420 Notebook
I have a dell 280GX and would like to increase it's graphics. I installed fsx deluxe but get out of range from monitor. I have done all the basics (settings advance and refresh). What is the suggestion?
This is a graphics card issue. I suggest you try say an Nvidia GTS250 card. If you are pushing up the resolution too high you will get this mesage. Short-term fix, try lowering the resolution in the settings of your current graphics card. This should help.
May 19, 2010 | Dell Optiplex GX280 (99301) Motherboard
Out of range in this wyse how to rectify
Here are thing that you can do to get a better range for this device:
* Relocate it, move it a higher location like on top of a desk.
* Make sure that there are not much obstructions around it.
* Check if you have other wireless devices that might interfere with the signal that his device is broadcasting, like a cordless phones.
* If there is really a problem with the distance between this device and your computers, a wireless repeater might help. You can check if this manufacturer has this type of device.
Feb 13, 2010 | WYSE WINTERM 9150SE
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
CTX S551A (Black) 15" LCD Monitor Logo
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
