Question about Marshall Music
Can I connect my Marshall JMD:1 Pre-amp out put to my Marshall 100 watt MG instrument input?
    Genius:
  • 1,066 Answers
Yes
Posted on Mar 26, 2011
Low volume on my marshall
I am very new here and don't know how to answer a question to a specific problem so I will write about the most common problems that I have had over the decades doing guitar amp repairs. If you find that your amp is extremely low in volume and then suddenly comes back to normal- check out the effects return [or power amp in] jack. Especially in Marshall amps-these corrode and your signal dies. If there is loud noise such as hissing and crackling with no guitar patch cord in the input jack- the input jack is likely at fault. They normally have switching contacts that ground part of the input circuit when the 1/4 inch male plug is disconnected. When this in is corroded or too weak to make normal contact, you can get these symptoms. If your amp is a solid state Marshall or Fender and there is a random buzzing sound with no guitar signal connected- hit the side of the amp and listen for the buzz to go away or become louder-if it does, this usually means that the connections are loose at the two large filter capacitors. In one or more Marshall amps, they use a filter circuit in the low voltage power supple for the preamp tubes. If you encounter a dead Marshall[the model escapes me now] remove the circuit board and resolder the four connections at the bottom of the bridge rectifier. If you have any other amplifier repair questions you can email me direct at computerlen@hotmail.com.
Nov 14, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
How to fix an output jack for a marshall mg 100 fx. Came loose and is inside the amp
You have to remove the amp from the case. These jacks are JUNK and it likely will have to be replaced. In any event, the amp has to come out to work on it. Several screws in the case and OFTEN the screws holding the handle. Be careful of the speaker leads.
May 23, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Can i connect 2 jbl 300 watt speakers to the mg 100hdfx 100 watt amp head ?
Yes you can as long as the speaker impedance when paralleled doesn't go below the rating of the amp. Marshall seems to hide their design lowest output impedance. Possibly you can find that in your owner's manual. Then find the impedance of the JBL. If half the JBL impedance is equal to or greater than the lowest impedance the Marshall is rated, you are fine to use it. The speaker Watt rating should always be bigger than the amp rating which it is in this case.
Dec 11, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
So, i think I've blown the fuse in my Marshall MG 100 HDFX head (I tried to run 2 speaker cables out of the head into a quad...stupid >.<). What type of fuse do these heads use? How can i access...
The fuse is inside the unit so as to force you to open it and look for damage.
The fuse is likely a 3 amp/250 volt type.
Replace the fuse and then put a 100 Watt light bulb in series with the hot side of the power input. If the lamp stays lit with no load on the unit, then there is damage that requires repair before use. If you just replace the fuse repeatedly you may damage further components.
In the future obey the minimum resistance load on your amps.
Aug 22, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Hi i am john... i have a 100dfx mg series... it is
There are MANY more likely components than the transformer that will cause the fuse to blow.
Most common are filter capacitors, rectifier diodes, and shorted components in the power amp section.
Transformer failure is very UN-likely. Have a competent electronic tech troubleshoot the unit.
When testing the unit, put a 150 watt light bulb in series with the power line... saves fuses during troubleshooting. This limits the current so one can analyze the real cause of the problem.
Jul 12, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall mg 100hdfx fan
Some of the Marshall equipment uses computer size fans and even on occasion the same connection.
Take the bad fan with you to a computer repair shop it will be much cheaper than a marshall part they should be able to help you out
Sep 09, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Music Logo
77 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
