Question about Electric Lawn Mower
I cut the chord, where can I find place to fix it
  • 8,404 Answers
Fix it yourself. Green to Green, White to White and Black to Black. Solder the connections. Use "shrink wrap (available at electronics stores of the Big Box place). One small piece on each and one large piece over the whole patch.
If you don't want to fix it, take it to a place in your town where they repair lawn mowers.
Posted on Mar 26, 2011
Used it last year.This year the chord to the extension chord frayed in two places.From the handle.And where the outside extension chord connects
I take the old wires out and replace them An electrical shop should have the cord you need. The switch on the handle should come apart and go back together again Just becareful you put it back together the same as you took it apart.
May 01, 2015 | Garden
Rice cooker retractable cord
Either go to the manufacturers web site and locate the particular model of your rice cooker- check for a schematic and/or parts list. Or call them and ask if they have replacement parts for the particular model of the rice cooker you own.
Nov 24, 2013 | Kitchen Appliances - Others
Can't get my tablet to power on at all
make sure your power chord is connecting properly my daughter has one and if she wiggled it around she would b able to power up also check your chord for cuts or nicks in it
Sep 25, 2013 | Toshiba Excite 10 Tablet
Dishwasher contuallycuts out through entire run cycle
Hi Andrew - Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the dishwasher. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: wiring failure, damaged cord, faulty door latch assembly or control board. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Jun 01, 2013 | Electrolux 23 in. ESL624 Built-in...
I cut my chord electric lawn mower
If it is a clean cut, and not all mangled up. You can get a male or female replacement plug at any hardware store to replace the cut off end. Hope this helps you.
Mar 28, 2011 | Electric Lawn Mower
Had a bad place on the chord about 6 feet from the end, cut the chord back to that point, put on a new plug but now it won't turn on. Is there a reset switch or fuse somewhere?
Yes, there is. It's a small white button located near on the back, near the left wheel. Unplug vacuum, then use the end of a paper clip to push in and reset.
Aug 12, 2010 | Riccar 8955 Upright Vacuum
I need a new chord .
The cord is item #26 in this parts diagram. You can order it from Kitchenaid, or you can cut the old plug off the end and put on a new plug.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Pull the plug from the wall outlet. Remove the mixer's end cap and you will see the wire coming into the mixer thru a strain relief bushing. Push it in and then the cord will be easy to remove.
Apr 06, 2010 | KitchenAid K45SS Classic Stand Mixer
No sound
check if the A/V chords are firmly in place. (The yellow, white and red plugs). If it is firmly in place, and the sound still does not come out, the problem is that there is a loose chord. Try slightly bending the chord while testing if there's sound. This way, you'll know if it really is the chords that have a problem... hope this helps!
Jun 22, 2009 | Sony PlayStation 2 (PS2) Console
Electic chord
the plug has a large and a small prong, the large one is the neutral or ground. test the ends of the cut chord to the metal of ref. the one that has continuity is the neutral and the large prong plug.
Nov 23, 2008 | Frigidaire FRS3R5EMB Side by Side...
Wont charge
Look at your phrase "it only charged when i placed the chord in a certain position" ... This points to some kind of fault inside your phones charger-plug.
You can try fixing this by yourself by using this guide to dismantle your phone :
http://www.uselessinfo.pwp.blueyonder.co.uk/explodenok6670.htm
Only expanded view, but it should show you where to look.
Otherwise take it down to your local Service-Center and let them have a look at it, seems to be a pretty simple "operation"
Oct 09, 2007 | Nokia 6670 Handheld
Electric Lawn Mower Logo
22 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
