Question about Fisher Paykel EcoSmart GWL15
Fisher & Paykel Pride 5.5 Smartdrive 8 not spining
Hi, My smart drive 8 Pride 5.5 (8 years old) top loader stopped spining after a brief grinding sort of noise. All other functions are fine, no beeps etc. In the spin cycle I can see it is tryingb to start rotating but not going. How can I fix this? Is this a problem with some sort of a clutch mechanism not holding ?
  • wetta Aug 06, 2008
    Hi, There is no inspection door in the back, only access is from the bottom. However, since the motor is running ok for washing cycle (assuming it is one motor that does wash cycle as well as spin cycle) I am having doubts in my mind whether there is anything caught in the motor.
    Problem Solver:
  • 19 Answers
There is a transmission clutch that engages for the spin cycle. A gear has worn or broken a tooth. Replacement of the transmission hispeed spin cycle assembly is required.
The other comments are of no use. You must get parts from an Authorized Fisher & Paykel dealer, or have an authorized repairman service the machine.
Posted on Apr 12, 2009
Hi as a guess there is some stuff caught between the magnet of the motor and the windings. if u unplug the machine open the inspection door and remove the magnet part and clean it it might help
Posted on Aug 05, 2008
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
Done a load of washing hung it out came in to do another load & have no power.
unplug the machine for five minutes and try it again. That is your RESET
Apr 24, 2016 | Washing Machines
I have a Pride 4 wheel Go Go Elite Traveller Scooter. It generally works fine, but I will frequently get an 8 beep error code and it won't go after a stop. I merely turn the key off and then
BEEP CODE CONDITION SOLUTION
2 Battery voltage is too low to operate Charge the batteries fully until charger and
the scooter. any meters indicate completion.
3 Battery voltage is too high to operate Contact your authorized Pride Provider for
the scooter. assistance.
5 Solenoid brake trip. The manual freewheel Remove the key, then push the manual
lever may be in the freewheel position. freewheel lever to the drive position and
restart the scooter.
6 Throttle trip. The throttle control lever Release the throttle control lever completely,
may have been depressed while inserting then reinsert the key.
the key.
7 Throttle trip. Throttle potentiometer Contact your authorized Pride Provider for
fault or speed potentiometer fault. assistance.
8 The motor is disconnected. Contact your authorized Pride Provider for
assistance.
9 Possible controller trip. You may be Shut down your scooter for a minimum of
attempting to install the battery pack while several minutes to allow the controller to
the key is inserted or the motor controller cool. Or, try reinserting the key into the key
may be in overheat protective mode. switch.
What you may be doing is mis-counting the beeps and it may be 9 beeps or its 8 and you have a bad connection between the motor and the switch? Good luck!
Jan 19, 2015 | Pride Health & Beauty
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
My fisher paykel top loader smart drive 053 has started to sqeak when spinning
drive belt may be loose and squealing just like a car will suggest re placeing it at that age.
Jul 09, 2012 | Washing Machines
Fisher & Paykel washing machine excellence 6.5 smartdrive 8
see this possible causes: God bless you
see the diagrams
Lid switch
test for defective or open
Motor coupler
replace coupler motor for defective
Belts
worn belt
Clutch
wears replacement
Drive motor
one winding burn , run with one winding in one direction and another with the other winding.
Drive pulleys
frozen pulley, worn.
Transmission
broken gear+ shifter defective
Agitator
worn agitator replace
5_16_2012_7_59_29_pm.gif5_16_2012_7_59_43_pm.gif5_16_2012_7_59_54_pm.gif5_16_2012_8_00_26_pm.gif
May 16, 2012 | Fisher and Paykel Washing Machines
How do I adjust the clutch on an ELBA Model WA50T54W1 top loader washing machine ?
Hi.
Unfortunately the service documentation for Elba is not available. Although the machine has been built by F&P and although is similar to a Fisher & Paykel Smartdrive there are some small difference. The clutch system may be similar to the smartdrive. I have uploaded the service manuals for two smart drive models below, see if that can help. Check section about disassembly.
F&P top load smartdrive smI.zip
Regards.
Ginko
Sep 05, 2011 | Washing Machines
I have a Frigidaire Pride Smart Drive top loader washing machine and I would like to give the bowl and inside where the powder goes in, a jolly good clean. How do I go about this? I'm worried that...
hi i have a fridgedair pride 5.5 wen i turn my washing machine on theirs know water going into the machine the water keeps going stop go stop go how can i fix the problem every thing else is fine.
May 26, 2011 | Fisher and Paykel Washing Machines
Fisher Paykel EcoSmart GWL15 Logo
1,323 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
