Question about Radio Shack Cinego D-1000 Multimedia Projector
I just replace my lamp but it says lamp life time is up replacement suggested
  • 442 Answers
You need to reset the hours counter. look in the manual and it will tell you how to do it.
Posted on Mar 26, 2011
The projector came on for about 10 minutes and then shut off
Welcome to FixYa.
The projector could be overheating or the lamp has reached its end of life.
Solution:
1. Clean or replace the air filter. 2. Check the lamp run time. If the lamp time has reached its end of life, replace the lamp.
Use the manual to do the above steps. Keep me posted.
Jas247
Aug 03, 2011 | Radio Shack Cinego D-1000 Multimedia...
Panasonic PT-61LCX65 turned off while I was watching TV. Won't come back on. "Lamp" light blinks once every 5 seconds. Tried turning it on several times per the manual instructions--no change....
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Feb 25, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
The screen goes black and the green indicator lights flash, after a few seconds the picture comes back on. This has happened about 4 times w/in the last day. sony kdf-55xs955
Most common resolution to this is to replace the lamp. When nearing the end of life cycle for the lamp, it will either warn you with a "Low Lamp Life" on the display or cycle power on/off. Replace the lamp and the problem should stop. Other possibility AFTER you replace the lamp and have the same issue is the ballast board. Not as common, but it happens. Your lamp has a life cycle of approx. 6000 hours, give or take. Replace with ONLY the Phillips factory bulb. It should be The XL-2200 and can be found on EBAY Google Shopping etc. for anywhere from 120.00 for just the lamp to 190.00 for lamp and housing. It's easy to replace and comes with instructions. Hope this helps
Feb 13, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
The overall picture is not bright like it use to be. like about half the brightness. picture is fine just not bright
suggest replacing the lamp. when the lamps are reaching the end of their life the tv will take a long time to show a picture and you may see a drop in brightness. part number 915P061010 i would really suggest getting a mitsubishi original lamp there are alot of generics out there and they are junk. good luck
Jan 06, 2011 | Mitsubishi WD-65733 65" HDTV
My phillips tv big screen will say top left hand corner replace the lamp and reset the lamp hour meter what does that mean?
What it means is that you have reached the expected life of the lamp in your set. I would not suggest replacing the lamp at this time. But what you may want to do is search for a replacement lamp at this time and have one on hand for when it does fail. Most of the time you should expect to pay 100 U.S. dollars for an original replacemant bulb. This will save you time and money. Good luck, Russmann.
Mar 25, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Panasonic PT-AE900u no image
may i know now what is the age of your projector. have you done replacing the lamp of the unit before.
Lamp life varies by manufacturer and projector type. Lamp life also depends on the projector's environment: air flow, clean air, and also on the level of usage. Check the user's manual or specification pages for your projector to determine the exact lamp life.
Nov 04, 2008 | Panasonic PT-AE900U Multimedia Projector
Projector Lamp
Hi there
Does your Projector go in for regular services ?
Have a technician check out the fans of this unit as well.
I would suggest you hook up a UPS to this Projector , because eventhough you might not have power dips or failures - the power supplied to appliances is not spike free and Projectors struggle to handle this well.
Apr 01, 2008 | Toshiba TDP-TW90U Multimedia Projector
JVC AV56WP74
Replace the lamp, also the shut down time is correct the unit must allow plenty of time proper lamp cooling. otherwise the lamp life will be greatly shortend. normal lamp life is 3000 hrs.
lamp replacement may require an internal limp timer reset have a qualified tech replace the lamp.
Oct 06, 2007 | JVC HD-52G886 52" Rear Projection HDTV
Picture & Sound blink off 45 seconds, blink back on, repeats
If the lamp is foggy then you really need to replace it. The lamp life is typically 5 to 7 thousand hours. However if your tv gets a lot of dust inside which is pretty normal as most people don't vacuum the dust off from the rear cover on a regular basis then the lamp life will be drastically reduced. I suggest you replace the lamp and make sure the inside of the tv gets vacummed out to remove as much dust as possible. A Sony servicer should be able to check the amount of hours on your lamp. You'd be suprised how soon 5-7 thousand hours happens. If the lamp will not come on after replacing it the lamp driver may be at fault. You haven't said how may times it's blinking. If it's 5 then the lamp driver may be at fault.
Sep 11, 2007 | Sony KDF-E55A20 55 in. LCD Television
136 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
