Question about Proform Crosswalk 500 Treadmill
I have a proform crosswalk (500E I believe). Anyway, I was having problems with the belt. I thought it just needed lubrication b/c it was like my foot would come down and make the belt stick to the deck. So I figured there was some friction there. After lubing it and tightening some I am still having this problem. Any advice is much welcomed!
    Top Expert:
  • Proform Master
  • 12,223 Answers
How do I get the belt unstuck from the right side?
You will need to loosen up the right side one revolution, then run the belt at .5 revolution. Watch the belt then retighten the right side slowly until the belt stays in the center. Once its running in the center for at least 1 min without moving over more to right you can stop tightening.
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
Jul 17, 2015 | Proform Crosswalk Advanced 525x Front...
Proform crosswalk 515 control board works but belt won't move/
lube the deck belt, you have deck worn, proceed in according with the instruction manual maintenance. 2) check the drive belt and replace it if necessary and tight 3) tes the input voltage motor, if there are the motor need repair or replace 4) test the output voltage from main board, for input voltage for the main motor, if there are NOT, the board is faulty.
Try if you can RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you.
Apr 28, 2012 | Proform Crosswalk 500 Treadmill
My proform crosswalk 590 circuit breaker keep turn off after run for five mins
Have you lubricated the walking belt & deck?? Are the deck and/or belt worn out and require replacing??
Check the deck for damage and wear, check the belt (feel the outer edge and then the center. Is the center fuzzy??)
If the deck and belt are good, lubricate them and try again.
Is the belt to tight??
Are you using an extension cord??
The machine is drawing too much current, usually deck & belt or defective motor will cause your breaker to go..
Dec 14, 2010 | Proform Exercise & Fitness
When i try to run, it stops and then goes. Its like its trying to hard to go, you cant even run. its a proform crosswalk caliber.
hi it seems like the belt on the motor has either slipprd or needs to be tightened, i had the same problem. i just tightened the belt on the motor and its working fine!
Nov 20, 2010 | Proform Crosswalk 500 Treadmill
Treadmill squeaks
There's a special silicone-based treadmill lubricant that you put between the belt and rollers See this treadmill accessory kit
Jun 24, 2010 | Proform CrossWalk TreadSoft Treadmill
My treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
May 08, 2010 | Proform Crosswalk 500 Treadmill
It keeps shuting down
If your on it and the duration is every 15 min then the unit needs to have lubrication applied between the belt and deck with a silicon base lubricant. If that does not fix the problem then you may have damage the belt and deck and they need to be replaced. Since not knowing the manufacturer' name refer to your owners manual for contact info
May 04, 2010 | Proform Crosswalk 500 Treadmill
My treadmill turns off after 1/2 hour what's wrong with it?
If it's exactly at .5 hours, that sounds like a programming issue. No if it just around 30 mins, this sounds like it could be a lubrication problem. Try lubing the walk belt to see if there is a difference. With belt going that long, lubricating should solve the problem.
Nov 16, 2009 | Proform Crosswalk 500 Treadmill
Proform Crosswalk 500 Treadmill Logo
61 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
