Question about Evga P55V SLI Motherboard w/ SuperSpeed USB 3.0 PCI-Express Card Bundle (P55VSLIW100U3EU30TR)
Hello, I will try to explain my problem as clear, however, as short as I can. I am building a machine off the P55V Sli motherboard (1156). Case mounted the board proberly, S-ATA's had a few issues with the labeling, eventually figured it out, and the solution fixed the inital problem. However the raid S-ATA on the board don't face the the side like the ROM versions that face towards the front panel of the case. I am wanting to run a raid0 config x2 500gb 7200rpm 12mb cache seagates. love em. work perfectly. And because i have to use the slots that face straight out, the 260 Maxcore video card will not seat correctly in the top PCI-e slot. and when its in the lower slot it gives a POST on boot-up 1 long 8 short. Which as us overclockers and builders know, thats a video read error. I fitted a 5670 radean inside on the p55v in the top position, and boot up went without a hinge. So..it may be a faulty card, but i am hoping there is a solution in a BIOS update perhaps one that swaps the PCI-e slots around or turns off SLI mode. I will be running a single card for the time being. the 260 maxcore is over 14 inches long, so fitting 2 on this board will be a cooling nightmare. other notes about the build not mentioned: 550 PSU (SLI and Raid) 4gb ram x2 500gb hdds x1 DVD burner/CD burner
  • 902 Answers
There must be a video card in the first pci x *usually running x16* and the 2nd usually runs at x4. the motherboard will not post at all if there is a card in the 2nd slot but not the first (hence the beeps) you can buy right angle adapters for sata connectors if that helps and makes sense?
Posted on Mar 26, 2011
Testimonial: "thanks, i had to trim down to a smaller vid card, but worked in the end."
When I try to boot my EVGA P55V micro mother board all it just goes beep beep beep, repeatedly I'm using a EVGA e-GeoForce 9600 GT card nothing apears on my screen it doesnt even look like its booting, the...
that beep (1 long and 2 short) indicated your ram has problem, from your suggestion i can know that your ram was died, change your ram with new one it will solve your problem
Feb 25, 2011 | Evga P55V 120LFE651TR LGA 1156 Intel P55...
1 long and 3 short beebs
Indicates a memory error, if you have more than one ram/memory you can try them one at a time in the machine (i always advise using anti-static wrist band when handling sensitive components) Ensure memory slots are clean/ free from dust If there is more than one stick of ram check they are compatible
Nov 21, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
1long 2 short beeps, No POST/Visual display
Hi there
One Long and Two Short Beeps = Video (Mono/CGA Display Circuitry) issue.
If you are using a PCI Express graphics card remove it and use the on-board VGA/DVI port
If it is the on-board graphics you are using clear the cmos
d015d7b.jpg<<<<< you will see in the picture a plastic jumper (in this case coloured green), move it to the other position and hit the on/off button, then put it back in its original position and power up the machine again. Hopefully the issue will have been sorted.
Good luck and thanks for using Fixya!!
Feb 18, 2009 | MSI K8N Neo4/SLI Motherboard
Asus |M2N-E SLI Reeboot issues
Hey, I own the same motherboard and I don't have your problem.
I would suggest trying to update the bios, i think its more of a bios problem / motherboard issue, not windows related.
you can get the newest bios from http://support.asus.com/
Oct 20, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
P5ne-sli
Try with only one RAM & isolate the problem
try with different slots
Aug 06, 2008 | ASUS P5N-E SLI Motherboard
Describe your ASUS A8N-SLI Deluxe nVidia video card
Yes, you do. Your board was built with the idea to use 2 graphic boards to get great video
NVIDIA® SLI™technology revolutionizes PC performance by combining multiple PCI Express GPUs in a single and scalable system! Gamers and hardcore enthusiasts know that dual GPUs mean increased, supercharged 3D graphics and performance
Dec 09, 2007 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
New pc build
Yes windows needs to install one primary driver first and decide which is the primary display.
Nov 28, 2007 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
New build computer wont turn on (ASUS A8N32-SLI Deluxe Socket 939)
The ATX power supply needs to have pin16(PS_On#) to be connected to COM for it to work. When you press the power switch on the front panel of the computer, you are essentially making this connection. Check that the cable from the power supply to the motherboard is making good connection. You can verify operation of the power supply by shorting Pin16 to pin17 on the powersupply output, with a paper clip. Pin16 is usually a green wire and 17 is black. Hope this helps. -Vish
May 04, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Evga P55V SLI Motherboard w/  SuperSpeed USB 3.0 PCI-Express Card Bundle (P55VSLIW100U3EU30TR) Logo
119 people viewed this question
Top Evga Computers & Internet Experts
David
David
Larry Rider
Larry Rider
Josh Levin
Josh Levin
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
