Question about Sony VAIO FRV27 Notebook
Sony vaio pcg-frv27 turns off after a while, I'm using ac power with batteries not in it.
    Genius:
  • 1,288 Answers
Most likely overheating, check if it is getting hot as it shuts off, by hot I mean hard to touch the base.
If it is, you will need to remove the bottom cover and clean out the accumulation of any dust by the heatsink
Posted on Mar 26, 2011
Sony vaio model pcg-61611L it turns on for 4 seconds and then it turns off using the ac adapter . help please
The charger may be bad, will it charge the battery? a common problem is the DC jack in the laptop breaks connection on the motherboard internittent operation or no power and shut down. If you can sub the charger that will tell if the power supply is bad or the problem is in the laptop. If the computer is the issue I recommend a professional because it will require extensive parts removal.
Mar 04, 2012 | Sony Vaio PCG-71318L
Sony vaio pcg-frv27 turns off after a while, I'm using ac power charger with no batteries in it.
problem with the fan. take of the back cover of the laprop and clean the fun
Mar 26, 2011 | Computers & Internet
SONY VAIO PCG FRV27 I power on the laptop and the screen shows up but its very dark i adjusted contrast but it is not very visible
Diagnosis:
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen
Oct 06, 2010 | Sony VAIO PCG-FRV27 Notebook
Power can't turn on?
its not motherboard problem its ram problem
Jun 18, 2009 | Sony VAIO PCG-V505CP Notebook
Hi guys, I keep getting an error message that says: Stream reading error when I try to use the sony vaio recovery wizard. My computer is the sony vaio pcg-frv27 notebook. The first problem was that...
Try rebooting and hitting the F8 repeatedly as soon as the boot sequence starts. When it comes up to an options screen select repair. From there you can let windows try to repair or select to install to the factory settings.
Mar 14, 2009 | Sony VAIO FRV27 Notebook
I have a sony viao pcv-frv27
are you on your battery or plugged in? It's not likely to make it as dark as you described but if you press the function key 'fn' key and usually the up arrow key (which has a sun symbol) it should brighten. From there if this dioesn't work you can try downloading new graphics drivers as last ditch effort but after that will require opening and checking connection to make sure screen hasn't died.
Jan 02, 2009 | Sony VAIO PCG-FRV27 Notebook
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
Sony VAIO FRV27 Notebook Logo
141 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
