Just purchased new Belkin N+N 300 x 2. Have 2 PCs connected and 2 PS3s (1 mine, 1 my sons). Why does my PS3 (newer model) play on-line for about 2 minutes and then losses connection? help help help
  • 902 Answers
Sounds like a ip address issue. as in it might be assigning the same ip address from your ps3 to another wireless device (its fairly common) i would set the ip manually for your ps3 in the settings area to somthing like 192.168.1.139 or something higher in the last set of numbers (anything above 110) should help you out. also if your wep encrypted that may play a role in it. i sset mine to no encryption and just M.A.C. address lock. so no ip conflicts and no slow down.
Posted on Mar 26, 2011
How do you adjust casio px 300 when connected to ipad2
Newer Casio models that have "class compliant" USB interfaces such as the PX-330 would work (plug and play) since they now have "class compliant" drivers.
Unfortunately PX-300 is an older model that would need specific drivers and Casio only made drivers for Windows PCs.
May 01, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
My son wants a ps3, but i understand you cant play ps2 games on it. is this true?
Newer model PS3 systems are not backwards compatible. but if you can find the very old original model used then it will be backwards compatible with some of the PS2 games but not all. Older models are hard to come by though.
Best bet is to just keep your old PS2 along with any new system you might buy.
Xbox 360 is compatible with a large selection of its older Xbox games but recommend you get a new slim model Xbox 360 if you go that route.
Jul 16, 2011 | Sony Playstation 3 (PS3) Console
How do you set up playstation 3 to play playstation 2 games
One Surefire WayThe only way how to play PS2 games on PS3 is to have the correct version of the console. Either your Playstation 3 can play PS and PS2 games or it can’t, and there’s not much to do about it. Most of the PS3 models simply cannot play older titles as they lack the necessary hardware and firmware. However, a few models do have backwards compatibility. The 20 Gb, 60 Gb, and original 80 Gb models all have backwards compatibility, either through hardware or software emulation. The other models lack backwards compatibility, so even knowing how to play PS2 games on PS3 won’t help you out much here.
However, if you do have the correct console model, then there isn’t much to know for learning how to play PS2 games on PS3. Simply insert the game CD or DVD (many original Playstation games are also supported thankfully), and the game will start up. Sometimes, it will tell you that you can’t play the game, but simply hook your PS3 up via wireless or ethernet connection and update the firmware (which also provides improved compatibility with newer versions of Blu-ray discs). Often, this will fix the problems, but not all PS and PS2 games are supported (although most are).
There you have it. Learning how to play PS2 games on PS3 is easy, but if you just randomly picked a Playstation 3 model out at your local retailer, you might have a model lacking in backwards compatibility. One reason they didn’t include such compatibility with all models is an issue of cost, as it saved Sony some money to not include such a feature on all of the models. When they first started selling PS3s for $400, they were losing several hundred dollars (although they are at least breaking even now). Unfortunately, both the new 80 Gb and 160 Gb PS3 models are lacking in such compatibility, so you’ll need to find older models to support your older games.
Please rate my solutions! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
Game does not display message indicates format not supported
if your trying to play a ps2 or ps1 game then your ps3 is not backwards compatable so it will only play ps3 games that goes for most ps3's that are 20gb or 40gb cause we have 2 ps3s in my house my sons is 40 and mines is 80gb and his wont play ps2 games but mines will and thats the reason why.
Mar 06, 2010 | Sony Playstation 3 (PS3) Console
Can ps2 games be played on ps3
on the first ps3s but not now......im not sure bout the slim......mine plays ps1 2 3
Nov 11, 2009 | Sony PlayStation® 3 (60 GB) Console
How do i connect ps3 to belkin adsl2 modem with high speed wireless g router ? We have just changed our old belkin (cut out every time the phone rang) for this model and its working 10 times better with...
Network status can be checked in PS3 settings - it says whether the PS3 is connected to the network or not. If you see that it is OK, then you can check the router - it usually lists attached devices, also enable UPnP option if it is not ON yet.
If you have a problem with PS3 in wireless mode - try to connect it to the router with a Ethernet cable (configure PS3 network settings correspondingly) - if it works this way the problem most likely in wifi configuration either on the router or the PS3 side.
I hope this can help
Oct 05, 2009 | Belkin Computers & Internet
Connection lasts about 5 minutes
Basically if you do a connection test on the ps3 and it comes back as NAT3 then you will have problems. You need to forward some of the ports of your modem to get to NAT2. You will need to assign static ip addresses to your PS3s so that you can set up port forwarding
You may have interference from a nearby cordless phone (keep these away from router), could be interference from neighbor, try changing channel you use on wireless router.
Some people have reported success just by turning off SSID broadcast in the wireless router.
PLAYSTATION®Network Guide
Jan 26, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g router is not connecting to the ps3
I assume this is another post for the same problem?
Jan 10, 2009 | Belkin (F5D7231-4) Wireless Router
Dropping Connection
All the LED except power should be flashing, that indicates traffic flow, power should be steady.
If all wired and wireless connections fail it is unlikely the router, more likely the cable/adsl modem that is dropping connection. Test by connecting a pc directly to the cable modem, watch for dropouts. If fails, contact your ISP service dept for line check and do a cable speed check from an online source.
Check also terms of service for the package you bought, many low end services restrict speeds below dialup if you go over your transfer limit. Multiple pcs playing online games use a lot of bandwidth. the speed restriction may put you below the threshhold for game server
Jun 08, 2008 | Belkin (F5D5231-4) Router
Connecting PS3 via Belkin router to internet, wirelessly
I HV COMCAST AND THE BELKIN ROUTER AND I WANTED TO NO HOW CAN I CONNECT MY PS3 TO THE ROUTER.
Oct 28, 2007 | Computers & Internet
Computers & Internet Logo
71 people viewed this question
Alun Cox
David Payne
David Payne
