Copier Lanier 5618. Misfeed "B" indication on both trays and bypass feed. Everything looks clean. Paper starts to feed about 4-5 inches then stops. I replaced toner cartridge with a new one but no change.
  • 4schuh Mar 26, 2011
    This is a Lanier 5618 copier, not a printer. It gives me a Misfeed "B" indication. Everything seems clean but the paper stops just before entering the drum area.
  • 4schuh Mar 27, 2011
    Still no success. Still get the misfeed "B" which is prior to the paper entering the drum area.
    Guru:
  • 1,833 Answers
If you face same problem after replacing toner cartridge, then you should check another thing, that is make sure there are no tiny scraps of paper lodged anywhere. The tiniest piece can cause a jam. Also, make sure all the sensors are clean, they look like two little eyes, and make sure your paper tray is set to the right size and direction of paper.
If you still face the problem, then you should call your service person, because it may be a bad sensor or any other parts that needs to repair.
Posted on Mar 27, 2011
  • 844 Answers
Welcome to FixYa!
Try to reset the copier.
  • Switch off the machine at the red power switch
  • Unplug the power cord.
  • Wait for five seconds then plug the power cord and switch back on againCopier Lanier 5618.  Misfeed - jas247_24.jpg
I hope this helps.
Thank you for using FixYa and keep me posted.
Jas247
    Genius:
  • 1,570 Answers
Hi
Is that a printer? If yes, you need to uninstall and reinstall the printer driver and set up once more the printer. I believe the printer driver is corrupted.
Post comment for more help
Posted on Mar 26, 2011
2 Suggested Answers
  • 67 Answers
SOURCE: Lanier 5618. Misfeed "B"
check registration sensor actuator
Posted on May 31, 2011
BYPASS MISFEED, FEED FROM TRAY IS OK
the bypass tray does not have paper sensors, so when you print you need to specify the dimensions of the paper ion the print driver and in the machine system features-tray paper settings..
Jan 20, 2013 | Ricoh Corp Aficio SP 6330N Laser Printer...
Mar 26, 2011 | Office Equipment & Supplies
Copier Sharp AR-M237 a Misfeed Occurred message
First try a different tray to see if it works, if it does than the paper tray you are using may have dirty feed tires or look for something obstructing it.
Mar 24, 2010 | Kyocera CopyStar CS-3060 Black and White...
Paper misfeed
Hello sir; Pull out the paper tray ,check the paper senser is moving freely,clean the paper pick up roller, it will take care the problem.
Aug 21, 2009 | Lanier Office Equipment & Supplies
I JUST CHANGED THE TONER AND THE COPIES ARE PRINTING OUT WITH A HEAVY THICK LINE ON THE SIDES
Indication Cause and remedy Page
Drum replacement
required indicator
Steadily
lit
Replacement of drum cartridge will be needed
soon. Prepare a new cartridge. 70
Blinking Drum cartridge must be replaced. Replace it with
a new one. 58
TD cartridge
replacement
required indicator
Steadily
lit
Replacement of TD cartridge will be needed
Blinking TD cartridge must be replaced. Replace it with a
new one. 57
Misfeed indicator Blinking
A misfeed has occurred. Remove the misfed
paper referring to the description of "MISFEED
REMOVAL".
63
SPF misfeed
indicator Blinking
An original misfeed has occurred in the SPF.
Remove the misfed originals referring to the
description of "D: Misfeed in the SPF".
67
Power save indicator is
steadily lit.
The unit is in the preheat mode. Press any key to
cancel the preheat mode. 54
The unit is in the auto power shut-off mode.
Press the start ( ) key to cancel the auto power
shut-off mode.
54
The paper tray indicator is
blinking.
The paper tray is not installed properly. Push the
tray into the unit securely. –
"CH" is blinking in the
display.
The TD cartridge is not installed. Check if the
cartridge is installed. 57
"CH" is steadily lit in the
display.
Side cover is open. Close the side cover
securely by pressing the round projections near
the side cover open button.
"P" is blinking in the display.
The paper tray or multi-bypass tray is empty.
Load paper. 15, 17
A misfeed has occurred in the paper tray or
multi-bypass tray. Remove the misfed paper. 63
A letter and a number appear
alternately.
The scan head locking switch is locked. Unlock
the scan head locking switch. 9
alternately.
The unit will not function. Turn the power switch
off, remove the power cord from the outlet, and
contact our Technical Assistance Department at
1-(630)378-3590 in the USA or 905-568-7140 in
Canada.
May 13, 2009 | Sharp Office Equipment & Supplies
Misfeed on lanier 7320
I like your pictures.... Have you tried to clean the feed roller with a slittly damp rag with Simple Green or WD-40? You can try that and wipe the extra off. They both clean the rubber roller's. If that works good, that means the feed rollers are worn and need replacing. But you may also need the paper pick-up feed clutch. You said you can still run paper throw the by-pass. Good Luck
Dec 11, 2008 | Office Equipment & Supplies
Paper Misfeed Problem
When you close the doors does the message disappear? If so then the paper pickup roller is worn. Open the cassette remove all paper apart from one sheet. Spray a alcohol based cleaned on the leading edge of the paper. Try and do a copy this will issue a jam and also clean the pickup roller. repeat a few times then clean out the cassette and dry off place new paper in the cassette and try. Also there maybe a piece of paper behind the cassette. Remove cassette and reach in and remove paper lodged at back.
Thanks Jason
Aug 16, 2008 | Office Equipment & Supplies
Card Stock is Not Fed from the Bypass Tray
Check the inside of the printer, ensure that there is no paper or foreign object stuck, sometimes they go undetected and they can affect normal printer feeding.
Try pulling out the paper tray and check the paper feeding mechanics underneath the printer.
Usually feeding problems are mechanic, if you cannot fix them in this simple way you will need to take printer apart and check feeding traction mechanics, this is usually a job that is better done at a repair shop.
Aug 11, 2008 | Ricoh Aficio CL2000N Laser Printer
Misfeed indicator
It could be comming from the paper feed mechanism above the paper tray. Make sure its installed properly. It could be as simple as cleaning the feed tires.
Jul 12, 2008 | Sharp AL 800 Copier
Sounds like a dirty sensor or a small piece of paper stuck. Check the feeder, left side, underneath. There should be a switch actuator
in the paper path that is visible. Also, on the right side, check all of the openings for anything stuck. If you have no luck, get some canned air and blow out everything. If its still jammed, it can be easily unplugged in the back of the machine, and the machine section will still operate.
Apr 23, 2008 | Lanier 1205 Copier
981 people viewed this question
k24674
jasbo
jasbo
