Sony vaio pcg-frv27 turns off after a while, I'm using ac power charger with no batteries in it.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
Sounds like a classic over heating problem. The CPU fan and heat exchanger should be cleaned by blowing medium pressure into the fan OUTPUT and into the fan INPUT. The heat exchanger usually pulls air from the bottom of the laptop. Picks up dust from the surface and deposits it on the fins of the exchanger.
If that doesn't do it, then the heat compound on the CPU has dried out and should be replaced. This is a job for the pro techie.
Posted on Mar 26, 2011
  • 54 Answers
Problem with the fan. take of the back cover of the laprop and clean the fun
My Sony pcg-9c1l won't turn on!! When I press the
Could be your adapter, adapter socket - most common issues.
AC ADAPTER CHARGER POWER FOR SONY VAIO PCG 9C1L PCG 9D1L VPCCW14FX... Test your power adapter with a multi-meter. Example below
Hope this works to help you and your situation.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Mar 11, 2012 | Sony Computers & Internet
Sony vaio model pcg-61611L it turns on for 4 seconds and then it turns off using the ac adapter . help please
The charger may be bad, will it charge the battery? a common problem is the DC jack in the laptop breaks connection on the motherboard internittent operation or no power and shut down. If you can sub the charger that will tell if the power supply is bad or the problem is in the laptop. If the computer is the issue I recommend a professional because it will require extensive parts removal.
Mar 04, 2012 | Sony Vaio PCG-71318L
I hadn't charged my Sony Vaio model PCG-61611L for a couple days. Then when I finally plugged it in to charge, it won't turn on. I even left it plugged in for a few days and still nothing. It has...
Try A Hard Reset
Remove the battery and charger/ac adapter/power cord from your Sony Vaio laptop, press and hold the power button for 20 seconds to discharge any residual current inside the laptop.
This clears your RAM and is like a hardware reset.
Replace the battery and charger/ac adapter/power cord
and turn your laptop on.
If that does't work try removing ram and reinstall. Sometime this works with these laptops.
Sep 11, 2017 | Sony VAIO VGN-AW330J/H Notebook
Sony vaio pcg-frv27 turns off after a while, I'm using ac power with batteries not in it.
Most likely overheating, check if it is getting hot as it shuts off, by hot I mean hard to touch the base.
If it is, you will need to remove the bottom cover and clean out the accumulation of any dust by the heatsink
Mar 26, 2011 | Sony VAIO FRV27 Notebook
The battery charger of sony Lptop VAIO PCG-7T1L has become faulty, i m not able to get a support fron sony service center, so how to purchase or get it reapired in Delhi
can just buy a replacement in the link below
http://www.ebuybatteries.com/product/GBProduct.asp?id=973M69&item=Sony+VAIO+PCG-7R2L+PCG-7T1L+PCG-7V1L+ac+adapter+laptop+charger
Feb 26, 2011 | Sony VAIO PCG-7T1L Series Laptop Charger...
SONY VAIO PCG FRV27 I power on the laptop and the screen shows up but its very dark i adjusted contrast but it is not very visible
Diagnosis:
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen
Oct 06, 2010 | Sony VAIO PCG-FRV27 Notebook
Power can't turn on?
its not motherboard problem its ram problem
Jun 18, 2009 | Sony VAIO PCG-V505CP Notebook
Computers & Internet Logo
69 people viewed this question
Alun Cox
David Payne
David Payne
