Question about Nikon D90 Digital Camera with 18-105mm lens
When i look through the viewfinder its darker than usual, my lens wont seem to come off its stuck even while holding down the release button and trying to rotate it by force. When taking pictures on auto mode the pictures are very dark no matter how much light there is. When i change the settings an ' Err' message is displayed. Whats wrong with my camera???? Help.
    Champion:
  • 226 Answers
Hi tin_080 , the aperture actuating lever was bent or loose and is ahead of the control mechanism of the diaphragm opening in the camera body.
Check this: point the lens towards you notice that the diaphragm is closed.
To avoid more costly damage you take it to a workshop for servicing.
Best regards
Posted on Mar 28, 2011
I own an Olympus Evolt E-500. Unfortunately, it was dropped and landed on the corner of the case near the battery door. The camera turns on, lcd screen, flash, and shutter seem to work, BUT pictures are...
I found this camera available for purchase as brand new for $450. Spending nearly $300 to repair an older version may no be a wise choice. You may find there is a market for the camera in its current non-working condition on eBay.
With that said, to your questions. 1) It will be difficult to diagnose without seeing it, but I have a suspicion in mind.
The viewfinder picture is actually what the lens sees, bounced up via mirror to a prism that projects the image to the viewfinder. If the mirror has become dislodged and is stuck in an odd position, the image would not be projected in the viewfinder. You can see the mirror when you remove the lens from the body. The mirror should be centered in the opening but at about a 45 degree angle. If it is loose or otherwise in the wrong place, this could be the problem. If the mirror is stuck and preventing the image in the lens from projecting on the sensor (behind the mirror) no capture will be possible. Other than the optics inside the lens and the mirror, there are few parts that could obstruct the image in the lens from reaching the viewfinder. Is the aperture of the lens open? If not, there may not be enough light to see the image in the viewfinder. This would also indicate that the lens is not opening up to let you see, and may not get set to the correct aperture when taking a picture. The camera usually opens the aperture to allow you to have a nice, bright image in the viewfinder. When you press the shutter release, the lens stops down to what the program says (or your manual selection) and the mirror lifts up out of the way, and the shutter fires.
2) Can you fix it? Maybe. Again, without seeing it - its hard to know for sure what the problem is and I don't know your level of skill either.
My suggestion is to bypass the camera shop that "doesn't know what the problem is but will fix it for $270" (how is that even possible??) and deal directly with Olympus USA Service and Support by phone or email to get an estimate / factory trained tech perform the repair.
Mar 08, 2012 | Olympus EVOLT E-500 Digital Camera
When looking through the lens - it is dark and all photos are dark even in well lit setting...
Is there a filter on the lens? remove the filter and try that. What mode are you shooting in? Switch to "P" for program and the camera will balance the light meter to a correct exposure. When looking through the camera viewfinder yes things will look darker then the scene because of all the glass and stuff the light is traveling through to get to your eye. Sort of like looking at something then putting a pair of sunglasses on. That part is normal. Also the faster the F stop the brighter the viewfinder will be. So lets say your 18-55 is an F4 lens. A lens that is an F2 will be a stop brighter and a lens that is F1.2 will be even brighter then that. You might not be paying attention to the light meter in the viewfinder which for correct exposure the needle needs to be in the middle between the - and + symbols.
Jan 11, 2011 | Canon EOS-20D Digital Camera
My d5000 fell on the floor and the filter glass of the lens broke. i tried taking pictures to see if it's still working but the view from the viewfinder is darker than usual and it would not take pics even...
The filter should have nothing to do with the images recorded on camera (I assume it's an UV- or skylight filter).
I'd say there's some more serious damage to your camera and you should take it to an authorized dealer repair shop.
Jun 17, 2010 | Nikon D5000 Digital Camera
D90 and Nikkor 17-55 problem. Lens won't come off
It's obviously in crooked. You will probably have to force it off but there is always the chance of damage.
Jan 12, 2010 | Nikon DSLR D90 Digital Camera
Lens stuck
If the battery is fully charged, and you are able to turn on the camera but only the lens wont come out, then try doing this:
1. Hold the camera from your right hand with the lens facing down.
2. Hit the base of the camera to your left palm as you press the ON button to turn on the camera. Do this a couple of times until the lens comes out.
Chances are, your camera's lens is stuck inside because of some granule of sand or dirt stuck on the sides of the lens inside. Goodluck!
Oct 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Dec 24, 2008 | Pentax ME Super 35mm SLR Camera
Autofocus jumps around and often will not settle on the correct setting
what i do is usually put it onto manual focus then back to auto focus, what it may be is that you are using the wrong lens for your subject :/
Feb 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Depth of field preeview button
That's a really good question, Denise.
One problem is that a D70 viewfinder is dark to start with. I don't notice this when shooting with mine unless I pick up my old Pentax Spotmatic for some reason, and then I am reminded how bright an optical viewfinder can be. So, in many cases, you will find the DOF preview useless not because it isn't working, but because the scene is simply too dark for you to see the differences.
Second thing is to notice what DOF you are seeing when you DON'T have DOF pressed. I think all modern cameras give you viewfinder at wide open aperatures -- so until you press DOF, you are seeing the focal depth produced by your lens' widest aperature. So don't expect to see much difference if you hit DOF with the aperture set at 2.2 on a F/1.8 lens -- you're comparing very similar lens apertures.
In fact, I notice that with my F/1.8 lens, I don't see any differences in where my focus lies until I have closed the lens down to maybe F/8. But beyond there, I can clearly see that more and more of the scene is in focus.
If you're still curious but not seeing it, try some test shots. Change the aperture and using shutter time to compensate, and see if your photo DOF matches the preview.
Hope that makes sense!
-- eastpole
Nov 28, 2007 | Nikon D70 Digital Camera with 18-70mm Lens
Won't Take Pictures
contact nikon they know about the problem and will fix it for free
Sep 02, 2006 | Nikon Coolpix 5700 Digital Camera
Nikon D90 Digital Camera with 18-105mm lens Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
