Polaroid LCD TV image problem
Somehow this wound up listed here under projection tv troubleshooting. Actually, it is a widescreen LCD.
Occasionally some portion of the screen on my Polaroid TDA-03211C TV/DVDcombo will momentarily display a low-resolution (large pixels)freezeframe. This may happen 3 or 4 times in the space of 2 minutes, or maynot happen at all for a couple of hours.
  • Floyd Pickering Aug 12, 2008
    Thanks for the response. I have read about capacitors causing other problems in Polaroid TVs. I'll see if I can find any bulging ones.
  • 3,037 Answers
Polaroids are known for their bad quality. The capacitors are known to go pretty quick which could be the problem you are having. I would first check them out since they are a cheaper fix. See http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_TV_black_screen
Otherwise your processor would most likely be causing this and needing replacement. good luck with this as Polaroid has horrible customer service but I bet you can find another one online if you find that it is the real problem. There are many online tv parts stores so if you need help finding one, let me know
Feel free to let me know of anything else you may need
my best to you
Posted on Aug 05, 2008
    Guru:
  • 1,894 Answers
Actually how is the problem occurring?
does the frame freeze totally in that portion?
Mau betulin polaroid dimana ya?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 03, 2014 | Polaroid Televison & Video
Polaroid tv problem
The most likely the TV has a power supply related problem.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
POLAROID TLA-04011C does not turn on
The most likely the TV has a power supply related problem or it maybe just a blown fuse inside the TV.
If by some chance the TV is still under warranty, go that route.
Jun 28, 2009 | Polaroid TLA-04011C 40 in. LCD TV
No picture on the t v
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
Jun 27, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Polaroid TV remote control codes for Tivo
As I understand it, Polaroid TV's sometimes work with the Mitsubishi codes. You may give this a try. You may also e-mail Polaroid direct at www.polaroidelectronics.com contact page to find out what codes should be used (may match a different manufacturer)
Jan 27, 2009 | Polaroid 4226TLMB 42 in. LCD TV
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
