Question about Garden
I need to replace the ignition switch on a 2002 Huskee lawn tractor along with all the connected wiring. Last fall, enough leaves got into the engine compartment to cause a fire. I need an electrical schematic diagram to make sure I rewire it correctly. Colors are useless now because the fire made all the wires either black or bare.
  • 246 Answers
SOURCE: I need an electrical diagram of the snapper lawn tractor
Hello:
Try this Site Addy;
>>You can View a Breakdown of the Mower at this Site Addy; http://www.snapper.com/manuals/ . Enter your Model Numbers in the Box Provided and Click Find Manuals. Select Illustrated Parts List from the Manual List Provided. Now Download the Manual for Online Viewing.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 26, 2009
SOURCE: need wire schematic for starter switch
I am holding the switch part (INDAK 681064) with the black pushbutton switch to the right.
The two wires on the top are Red then White. The two wires on the bottom are both black.
Posted on Jun 22, 2009
  • 3 Answers
SOURCE: Huskee 25 hp lawn tractor with briggs & stratton motor wont start
Most all manufacturers have the Users Manuel available on line you will need the Make and Model to pick the correct one. Have you replaced the battery. It can show the correct voltage but have no cranking amps. I believe if the solenoid is trying to engage the Dead Man switches are closed. With the starter disconnected from all power sources do the teeth on the starter turn or are they locked up? If they refuse to move do you have an Auto Zone around or another parts store or electrical engine repair store that can test the starter. Make sure the mowing deck is not engaged while you are trying to start the engine. I hope these rudimentary suggestions help.
Posted on Jul 18, 2009
  • 21 Answers
SOURCE: Huskee LT 42 Lawn Tractor's mower blades drag on
check blade to see if it is bent or perhaps the blade spindle is bent are the tires properly inflated on a flat surface ceck to see if the deck is level good luck
Posted on Sep 12, 2009
RonInFla
  • 86 Answers
SOURCE: Loud knocking sound
bad connecting rod in engine...eventually it will go completely, and cause sever damage
Posted on Apr 10, 2010
Huskee Lawn Tractor Manuals LT 4600
http://www.partstree.com/parts/mtd/mowers-lawn-garden-tractor/13aj771g031-huskee-lawn-tractor-2009-tractor-supply/
Apr 19, 2017 | Garden
Replaces battery and spark plugs in my huskee lawn tractor it cranks over but won't fire has full tank of gas and battery is charged what could be the problem?
No spark? Check out ignition coil. Make sure the fuel is turned on if you have an on line hose switch for that.
Mar 28, 2017 | HP Garden
Transmission repair or replace
Jim, The links below are what I found on the Net., You could also do a search with your year, make and model# for possible better results. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Rebuilding lawn tractor transaxle Part 1 of 2
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
Tractor hydro transmission rebuild part 1
Part 1 K46 hydrostatic drive Removal
MTD Transaxle Basic Rebuild Replacing all Bearings Part 1 of 2
Aug 20, 2016 | Huskee Tractor Replacement Riding Lawn...
My lawn tractor,I was moving and it just quit running. Sounds like no spark or no fuel. Safety switch problem or something else
Check all of the safety switches and make sure they are all closed. Any one open will not allow the ignition to work. And check the wiring - if one of the wires going to a safety switch is loose or falls off that all will shut down the ignition.
Sep 01, 2015 | Garden
Tora Lawn Tractor Won't Start . Wheel Horse 13-38 XL
It is not uncommon for a safety switch to get misaligned and not work correctly, also it is not uncommon for a switch not to work even if it is engaged.
You need to check all the switches that must all be properly aligned and engaged in order for the engine to start. As for the light blue wire, I am not sure 100% however typically blue wireds on wheel horse equipment are used in the ignition system. Depending on your model it may be the main ignition power line which runs from the ignition switch (S) connection or (start) connection, then goes to PTO interlock switch, then goes to the Pedal interlock switch, then finally to the starter solenoid. Which sounds like where you have to look because along this blue wire at many points and switches, there is a problem either with a connection (the lose blue wire) or a bad interlock switch along it's way to the starter solenoid. You should also check the PTO interlock switch because it also is connected to a kill relay that will prevent the engine from starting id it is faulty (that light click your hearing, the starter solenoid would be a louder click).
There is a typical ignition service manual available at http://www.mywheelhorse.com/graphics/file/Engines/Engine-Electrical_Service-Manual.pdf It has the typical wireing diagram and all the information you will need presuming you have enough electrical background to use a multimeter.
The website at http://www.scribd.com/doc/47347708/Toro-wheelhorse-Demystification-Electical-wiring-diagrams-for-all-WheelHorse-tractors has diagrams specific for each model but you have to make an account (free) to use the website, and lastly the website http://www.mywheelhorse.com is a invaluable website for anyone who owns a Wheel Horse. Let me know what you figure out!
Nov 12, 2013 | Toro Garden
I am working on a neighbors huskee slt4600h lawn tractor that wont start. I replaced the battery and it started once. When I tried to restart it all I get is a click from under the seat when the key is...
That doesn't sound good... make sure the wires have good connection to the battery terminals. If its not that then your gonna need a new starter...
Feb 09, 2011 | Garden
My huskee lawn tractor will not turn over! The battery is fully charged, it is a 25hp with a 50inch cut, i replaced the selnoid last year!
The arm that engages the cutting blade tends to wiggle. Make sure it is pulled toward you (unengaged) before trying to start.
May 09, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Loud knocking sound
Apr 10, 2010 | Garden
My mower quit. I changed the coil and it started
Sounds to me as if the replaced coil might of fried when you shut the tractor off, several older lawn tractors have a coil that has just one wire going to them and this is grounded out by the key switch to shut the tractor down what happens is when the key switch gets warn it sometimes will feed 12 vdc or battery positive power to the coils instead of shorting it out in which case when you replace a coil in a lawn tractor it is best to replace the ignition switch along with the coil. If this is not a electrical problem it could be as simple as a plugged fuel filter that juat happens to let enough fuel thru as it sits to run for a little while but not enough to run fulltime. Hope this Helps, Don
Oct 20, 2009 | Garden
50'' Huskee lawn tractor only turns in one direction
the brand huskee is now manufactured by MTD
Parts are available from tractor supply company at www.tractorsupply.com
there are pages of not very encouraging reviews about the huskee mower or about the tractor supply company but you can contact them to see what you can get
as for the problem , if it is a zero turn unit it may be a clutch arrangement needs adjustment
If you do not get any help from that company, you could ring around the mower repairs shops to get an idea as what could be wrong as the principle of operation will be the same .
also there are sites that have pdf versions of the workshop manual for huskee
May 20, 2017 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
