Posted on Mar 26, 2011
Lanier 5618. Misfeed "B"
fares
Level 1:
New Friend:
  • Contributor 67 Answers
  • Posted on May 31, 2011
fares
Contributor
Level 1:
New Friend:
Answers
67
Questions
0
Helped
15716
Points
86
Check registration sensor actuator
1helpful
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
BYPASS MISFEED, FEED FROM TRAY IS OK
the bypass tray does not have paper sensors, so when you print you need to specify the dimensions of the paper ion the print driver and in the machine system features-tray paper settings..
Misfeed from the rear tray. The rear tray feed is not working. When it tries to feed it bends the right corner of the paper and then I get a misfeed message. I can't use the printer to print 4x6 photos...
there could be a teenie piece of paper stuck in the feed path causing this to happen, you have to visually inspect and ensure it is clear. Use plain paper to test.
rollers may also contribute to problems with feeding paper its good you tried that too.
lastly maybe the photo paper is too thick for that printer?
Paper misfeed
Hello sir; Pull out the paper tray ,check the paper senser is moving freely,clean the paper pick up roller, it will take care the problem.
I JUST CHANGED THE TONER AND THE COPIES ARE PRINTING OUT WITH A HEAVY THICK LINE ON THE SIDES
Indication Cause and remedy Page
Drum replacement
required indicator
Steadily
lit
Replacement of drum cartridge will be needed
soon. Prepare a new cartridge. 70
Blinking Drum cartridge must be replaced. Replace it with
a new one. 58
TD cartridge
replacement
required indicator
Steadily
lit
Replacement of TD cartridge will be needed
Blinking TD cartridge must be replaced. Replace it with a
new one. 57
Misfeed indicator Blinking
A misfeed has occurred. Remove the misfed
paper referring to the description of "MISFEED
REMOVAL".
63
SPF misfeed
indicator Blinking
An original misfeed has occurred in the SPF.
Remove the misfed originals referring to the
description of "D: Misfeed in the SPF".
67
Power save indicator is
steadily lit.
The unit is in the preheat mode. Press any key to
cancel the preheat mode. 54
The unit is in the auto power shut-off mode.
Press the start ( ) key to cancel the auto power
shut-off mode.
54
The paper tray indicator is
blinking.
The paper tray is not installed properly. Push the
tray into the unit securely. –
"CH" is blinking in the
display.
The TD cartridge is not installed. Check if the
cartridge is installed. 57
"CH" is steadily lit in the
display.
Side cover is open. Close the side cover
securely by pressing the round projections near
the side cover open button.
"P" is blinking in the display.
The paper tray or multi-bypass tray is empty.
Load paper. 15, 17
A misfeed has occurred in the paper tray or
multi-bypass tray. Remove the misfed paper. 63
A letter and a number appear
alternately.
The scan head locking switch is locked. Unlock
the scan head locking switch. 9
alternately.
The unit will not function. Turn the power switch
off, remove the power cord from the outlet, and
contact our Technical Assistance Department at
1-(630)378-3590 in the USA or 905-568-7140 in
Canada.
Misfeed on lanier 7320
I like your pictures.... Have you tried to clean the feed roller with a slittly damp rag with Simple Green or WD-40? You can try that and wipe the extra off. They both clean the rubber roller's. If that works good, that means the feed rollers are worn and need replacing. But you may also need the paper pick-up feed clutch. You said you can still run paper throw the by-pass. Good Luck
1helpful
4answers
Paper Misfeed Problem
When you close the doors does the message disappear? If so then the paper pickup roller is worn. Open the cassette remove all paper apart from one sheet. Spray a alcohol based cleaned on the leading edge of the paper. Try and do a copy this will issue a jam and also clean the pickup roller. repeat a few times then clean out the cassette and dry off place new paper in the cassette and try. Also there maybe a piece of paper behind the cassette. Remove cassette and reach in and remove paper lodged at back.
Thanks Jason
Misfeed indicator
It could be comming from the paper feed mechanism above the paper tray. Make sure its installed properly. It could be as simple as cleaning the feed tires.
Sounds like a dirty sensor or a small piece of paper stuck. Check the feeder, left side, underneath. There should be a switch actuator
in the paper path that is visible. Also, on the right side, check all of the openings for anything stuck. If you have no luck, get some canned air and blow out everything. If its still jammed, it can be easily unplugged in the back of the machine, and the machine section will still operate.
k24674
ADMIN Andrew
ADMIN Andrew
