Question about Gibson 1957 Les Paul Jr Single Cut VOS Electric Guitar (Faded Cherry)
Guitar is very quiet - Gibson 1957 Les Paul Jr Single Cut VOS Electric Guitar (Faded Cherry)
    Problem Solver:
  • 7 Answers
Make sure its the guitar by trying in another amp, and if it is the guitar take it to a guitar shop, theyll figure it out
Posted on May 11, 2011
MY Marshall JCM 2000 100Watt head is quiet TURNED fully on stand by OFF and ready to plug guitar into the INPUT Jack. Soon as I plug into the INPUT Jack cracking noise hissing noise.
I would suspect a bad cable. Also, these symptoms show up if you mistakenly use a speaker cable (unsheided) as a guitar cable (shielded).
Dec 12, 2016 | Marshall Music
Why is my Fender Blues Deluxe Amp making a crackling sound without an instrument even plugged into it and when I do plug in, it quiets when I touch any place on the guitar?
You probably need a new input jack on the amplifier. When they get loose the connecting wires can crackle, but plugging a guitar in stabilizes them (no more crackle).
Feb 11, 2015 | Fender Blues Deluxe Reissue Tweed Combo...
Hi ive had a fishman pick up installed under saddle of my accoustic guitar its fine but something is wrong becuase wen im slapping the strings and tapping guitar the sound goes very quiet for around 1...
It is possiblle that the sudden pulse from the pickup due to tapping is saturating the input of your amplifier, and that is what actually kills the signal. Try this into a different amp as a test. Once you do the test I can offer some suggestions to try.
Apr 23, 2011 | Fishman PRO AG-094 Under Saddle Acoustic...
I have a Flextone II XL 212 combo. When I mute the strings it's quiet, but when I play there is always a hum/buzz with the note on any voice or preset. I've tried different guitar and cord. It's not a...
You have analyzed the problem... with the strings muted, the unit is quiet... that means the problem is with the guitar or cable picking up the noise. Move the guitar around near other things to search out the source which is probably magnetic fields... orient the guitar differently to sniff for the source. OFTEN lamp dimmers generate higher frequency components that can couple into the guitar pickups. The problem is fairly common.
You likely are in an area that has magnetic fields. Also you may have the settings on the amp that accentuates the noise. Eliminating this noise, especially at low levels, can be difficult if you have devices like flourescent lights that have magnetic ballasts.
You might also try running a different source into the amp such as a walkman player to verify the audio can be cleanly amplified. If that works, then the amp is OK.
Nov 26, 2010 | Line 6 Music
My tuner reads D when it should be on E. It is set for 440. Please help. Thx
Test on another guitar first... If it only happens on yours, then you guitar MAY have a resonance in the neck or bridge that cross couples to your D string that MAY be the strongest vibration which the tuner is looking for. Try damping your D string while tuning the E strings by placing a finger on the D string to quiet the D..
Sep 19, 2010 | IntelliTouch Communications Intellitouch...
I play Gibson USA Sgs, one with 490/498 humbuckers and one with 57classics....The Amp has a loud buzz like feedback all the time on the overdrive channel.
If the amp is quiet with cables unplugged at the same settings as observing the buzz, the amp is OK.
In this case, cables and/or shielding and wiring in the guotar is suspect.
Guitar pickups are sensitive to magnetic fields and you can search out these fields by moving and orienting your guitar to find maximum buzz.
If the amp has objectional buzz with teh cables UNPLUGGED then the amp needs servicing. Filter capacitors among other things are suspect.
Sep 12, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
My line 6 spider III 15 watt amp isnt working properly. i turn it on but i get this sound when its connected to the guitar. it sounds like when a guitar is not connected to a guitar and the guitar cable is...
While it could be true that you're having a problem with the guitar or cable as the previouse expert suggested, to say that it can't be anything else is false. It could be a jack problem...it would only be apparant when the jack is making contact with a cable. I do think you should test it with another guitar and another cable but if that is not solving the problem then I bet it's a problem with the input jack of the amo itself or even one of the ionternal components (this is a digital amp and there are MANY components and settings that can trigger a problem like this) If the problem is not solved with a new cable/guitar configuration then it's time to take it to the shop.
Jul 09, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
My boss MT-2 plays is extremely quiet when turned on, the clean channel comes through great, as soon as i turn it on its hardly audible, using the boss power supply, with correct ins and outs, and tested...
It is possible the pedal is DESIGNED to be used with an amplified (preamp within guitar) and yours MAY be a passive guitar. You did not tell us what guitar you have.
Many of the processors for guitars depend on having a "line level" signal and that requires that your guitar has a built in preamp.
If your guitar doesn't have a preamp in it, buy a preamp to put ahead of this pedal.
Apr 28, 2010 | Boss Mt 2 Metal Zone Effects Pedal
My Tascam CD GT1 mkii guitar trainer is doing everything except when I plug my guitar into the unit, I can not hear my guitar?
Here is the manual if you don't have one:http://www.tascam.com/details;9,21,23,19.html Make sure your guitar cord is working. Make sure your are plugged into the Guitar/Mike input jack.Do not connect a guitar amp to this jack via line out on the amp or otherwise. Set the Guitar/Mike switch to Guitar. Use the Input control to adjust the level of the input.Adjust your Headphone level using the Output control.Carefully read pages 12, 13, 14 and 15 of the manual.There are various combinations of controls that would make your guitar too quiet to be heard. Example: Mix Balance page 24. Let me know if this helps.
Nov 29, 2009 | Tascam CD Gt1mkii CD Guitar Trainer
Amp goes quiet after working fine for about 15-20 min.
If you are not a tech, I suggest you send it to one. If you are, after signal-dropout spray output transistors (one at a time) with component cooler (freeze spray). If still no results, go to the other transistors & IC's. Chances are that will pinpoint faulty component.
Apr 05, 2009 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Gibson 1957 Les Paul Jr Single Cut VOS Electric Guitar (Faded Cherry) Logo
Top Gibson Music Experts
Michial Gueffroy
Virgil Watts
Are you a Gibson Music Expert? Answer questions, earn points and help others
