Question about Intertherm P3RA-042K Air Conditioner
Air conditioner I came home to find the fan in the outside unit not turning and smoke coming from the unit as well. The house was cool when I got there but I am unsure if there was any air blowing. Any ideas?
    President:
  • 1,796 Answers
Hi!!
It not uncommon for the condenser motor to blow out, if evertything else is ok. The unit will kick in normally and you'll start getting cold air inside. Since the condenser is not doing its job, the unit's thermal protection will cut off compressor until cools down and then will start again.
Replace condenser motor (around $100) ASAP and do not use unit until then, othewise, major damage to the unit can occur.
If helpful, click below. GOOD LUCK
Posted on Apr 14, 2010
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
My air conditioner starts blowing like a fan before my apartment is cooled off, why does it kick off and on like this?
When you first turn it on the fan runs and after a few minutes the outside unit comes on, once the outside unit comes on it take time for it to cool the coils which cool the house, And a/c does not really cool the air,It removes the heat that is in the air.
Aug 04, 2010 | Kenmore Heating & Cooling
I have the York Outdoor Split System Air Conditioner- Model # h4de024S06A, Installed in my home on june 12, 2004. We had no problems at all until last night when we noticed that the Furnace of the Fan is...
I think you may have 2 problems. Thje outdoor fan not coming on would cause the compressor to either go out on high discharge pressure or internal overload. Either the fan is bad or the capacitor is bad or both, which can be replaced.
The second problem is either the unit froze up on you and for the short time that it will cool before it quits. You may want to make sure you cool speed for your indoor unit is set to hi cool speed which is usually black
Jul 06, 2010 | Heating & Cooling
Earlier this week, I noticed that the house felt "stuffy" but the thermostat showed everything to be cooling as expected. Last night, the house was definitely warmer than expected when we got home. My...
If both fans runs (inside and outside), check if the compresor runs , if does probably the unit is low in freon and needs to be recharged after the freon leak has been fixed (remember this is a seal system and it shouldn't leak), but if the compressor doesn't work , it could be the capacitor , the pressure switch (if it's low on freon ) or the compreessor itself.But befor do anything ,if you have a digital thermostat replce the batteries.
Sep 30, 2009 | Ruud UBHC Air Conditioner
Heat pump not cooling
You may have a bad running capacitor on the outdoor unit. It is a round or oval can with three sets of prongs on it. Over time they can either become weak or swell due to an overload.
Aug 10, 2009 | Heating & Cooling
The outside unit on our Ruud heat pump won't turn on. The inside fan blows but the unit outside sits idle - no fan turning, nothing. It was cooling earlier today, but when I came home from shopping, the...
first look for red button neer the copper line set if has one push it second inspect thermostat wires for weed eater damage check disconnect for fuses check breaker at main panel pull disconect and remove cover check stat wire connections look at the capacitor if swelled up on top bad if all look ok put disconect in using insulated object manually push in contactor if unit comes on check for 24 volt ac on yellow stat wire to common if none stat wire could be loose at indoor unit or stat bad hope this helps you
Jun 05, 2009 | Ruud UPMC036 Air Conditioner
Blower Turns off if ac unit comes on. No air coming through vents
This only could 1--2 things, a bad circuit board fan relay or bad thermostat. To check for bad thermostat, take off the front cover to reveal the 4-wire terminial and jump the red-wire (power)-cool,(yellow -y or blue)--- green--fan white-(heat)..........red to yellow-or y=cool. Thank-you-very-much!
Aug 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
My AC unit keeps freezing up on the copper lines going into the house from the outside unit. It also freezes up on the inside lines and the air is not cooling my home down.
Operate your air conditioner with the fan in the on position. But first turn the fan on, turn the temp up or shut the cooling off. Your coil is more than likely frozen over. At night when outside temperature drops the refrigerant pressure and temperature in the system also drops. This action can cause icing of the cooling coil, with the fan in automatic everything shuts down at the end of a cooling cycle. Thus no air movement to melt ice on previous cooling cycle.
May 09, 2008 | Heating & Cooling
Intertherm P3RA-042K Air Conditioner Logo
161 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
